Fisher and Paykel IW709AU Washing Machine out of balance on spin
Fisher and Paykel IW709AU Top Loader Washing Machine. Going out of balance on every spin cycle. Need guidance on possible causes and remedies to fix it.
  • 1 more comment
  • John Timermanis
    John Timermanis Jul 21, 2009
    Hi Benimur,
    My switch is OK and it does work correctly. This has been a problem before and I was able to successfully repair it. The actuating lever when hit with the out of balance drum does trip the microswitch and stop the machine as it should. There is no problem there. The problem is that the drum is so seriously out of balance at all. This has not always been the case. That is why I am thinking that there is another issue that is not allowing the drum to balance as it should or at least reduce the out of balance thrashing around that it is experiencing.
    The blue 'tank' attached to the top of the wash drum has some water? in it and I was thinking that this may be a balancing device to assist the drum in staying in balance (gyro effect???). As there is not much fluid in the tank I am not sure if perhaps it has had a leak? Are you able to advise how much fluid is supposed to be in the tank and if mine requires more, then perhaps I need to repair it and top up the fluid... Could you please advise.
    Thanks John Timermanis
  • John Timermanis
    Benimur did you get my earlier comments? John T
  • John Timermanis
    John Timermanis Jul 22, 2009
    The out of balance the machine experiences is a fairly strong thrashing of the wash drum. The out of balance switch, its mount and the actuator are all fine. Bearings and mounts appear to be fine, no grinding noise or anything of that nature. When and if the drum can get itself into balance, it is smooth and the drum is able to reach a fairly high RPM. The bias spring on the front side of the drum and diagonally opposite the out of balance switch does appear to be a very light spring and not particularly useful for anything. Personally, I would have put a far heavier spring on it. I still need to know if the tank around the top of the wash drum is supposed to be full or half full of water or fluid. It looks to me to be some sort of balancing damper device that perhaps acts as some sort of gyro to stabilise the drum when it's spinning. The previous person who attempted to assist me thought I may have been talking about the fabric softener cup arrangement on the agitator. No I that was not what I meant. The blue plastic tank is quite clearly a water talk of sorts that clips on to the top of the wash drum and spins with it. I would really like to know more about this item, its purpose and how much fluid it is supposed to have in it.... Would appreciate any help I can get on this. Thanks John T
    g and not t and
    President:
  • 1,129 Answers
Make sure the machine is level, use a level on two planes and adjust the feet to achieve a level operating condition.
Posted on Jul 22, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
On several models of Fisher and Paykel, the out of balance could either be caused by a faulty switch (most likely) or the mounting bracket (least likely) for the switch has deformed / out of alignment or developed a crack and therefore triggers falsely the warning message. While the parts are readily available and are simple enough, it is the dis-assembly to gain access to the switch / mounting that maybe of a challenge. Should you be interested, the bracket / mount may be viewed here while the switch may be checked out here. The switch could be checked for continuity using a multitester but the mounting bracket has to be visually inspected.
This of course is assuming that the washing machine has been checked for evenness of load and that it does not exceed the load limit of the machine.
Options then are:
  • consider a DIY (do-it-yourself) repair if and only if very familiar with electrical / electronic components & circuitry, use of a DVM/VOM and safe working practices with electrically powered equipment. Access to a Service Manual or at the very least, a schematic diagram would be an advantage;
  • should you be uncomfortable with a DIY, perhaps your best bet would then be to seek the services of an authorized Service Center (specially if still under warranty) or a qualified professional.
Good luck and thank you for asking FixYa.
Posted on Jul 20, 2009
  • Louie  Role
    Louie Role Jul 21, 2009
    Appreciate your postback and additional information.
    To my understanding, there would be a counter spring  attached to the tub pullig it forward. Check and determine if still atcched and doing its function.Another possibility to consider would be the main support bearing but that would cause a metallic grinding noise.
    Sorry on the fluid reservoir. On the F & P models in my country, I can only think of what you described for fabric softener and/or detergents.
Out of balance
Have you replaced the suspension damper rods on the machine
these also need replacing at the same time.
Jun 13, 2013 | Fisher and Paykel Washing Machines
Fisher paykel aquasmart top loader washing machine continuously comes up with fault 247 when trying to spin. Appears to be a balance problem as rearranging clothes and a restart allows it to...
Hi - you have possibly some restrictions in/around your smart pump unit, inside is a flapper valve suppose to control flow in both directions, often this gets the rough treatments.
Be careful if you wish to have a nosy its located beneath the smart agitator.
Jun 18, 2011 | Fisher and Paykel Washing Machines
Whats a code 43 on a Fisher Paykel Intuitive top loader washing machine mean
That's an 'out of balance' switch problem. Typically caused by a crook microswitch that lives under the main processor housing. Can replace with a generic switch from Jaycar or similar if needed.
Feb 26, 2011 | Fisher and Paykel Washing Machines
Have Fisher & Paykel GWL11 and can't get the washer to spin
Is it pumping out? Make sure the machine is evenly balanced, if it is out of balance it wont spin up. :)
Jul 31, 2010 | Fisher and Paykel GWL11 Top Load Washer
What is error code 136 on a fisher & paykel IW709AU top load washer
136 fault is 'motor stall'...Quite often this is a broken wire to the motor. However it could also be a Motor fault, or Rotary Position Sensor problem. Water damage can cause this fault as well. After a visual check for broken wires or water damage, and if your machine is in good condition, you should consider a tech....Good luck...Nomess
May 20, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
WATER PUMPING IN SPASMODICLLY AND THEN THE BEEPS COME AND MACHINE TURNS OFF. i HAVE A FISHER PAYKEL MW058U TOP LOADER. SAME THING HAPPENS ON SPIN CYCLE.
there r 3 reasons this happens. 1st the out of balance switch is faulty. 2nd the rotor senor near the motor is faulty. 3rd your control board is faulty. have u got an electrical test meter to test the components? please reply 4 more help. 95% of the time the faulty part is the the out of balance switch.
May 01, 2010 | Fisher and Paykel Washing Machines
Tub goes out of balance every spin cycle
If it doesnt bang and crash around or doesnt seem like there it is out of balance (ie try running with nothing in it) then theres probably and electronic component problem
Jul 15, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Out of balance during wash
Ok you need to check your machine is level- if not adjust feet. You aslo need to check the Bias spring is still attached if not get a new one or re-attach it. The Bias spring is a little spring that connects from the top of the front left suspention rod to the top of the plastic bowl cover (this spring is meant to help stop it going out of balance so easy. Cheers
Mar 24, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
219 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
