Question about Freezers
Akai frizer 1 year frizer, the motor stop working, and restart after i shake the motor and pipes !
  • 55 Answers
On the top of the motor there is a plastic cover which contains a thermal button,try to hit it in this spot and if it works you might change it with another
Posted on Nov 18, 2007
Why would a chest freezer stop working not even had it a year yet had a little over six months
-Never know. It could happened any time.
-If you still have receipt then call the factory and get it fix for you.
Most appliance come with 1 year warrantee. So you better hurry before 1 year.
Good luck
Dec 12, 2017 | Freezers
Danby freezer
If it stopped working after being moved, check all the electrical connections. Also check no pipes were broken in the move. Is there any noise from the compressor?
Mar 23, 2014 | Freezers
Kenmore 6.9 cu. ft. chest freezer stopped working
It looks like a bad ignition switch or capacitor. This is not that expensive. Probably not the compressor. Unfortunately, one small part stops the whole show.have a friend who is a tech look at it.
Jan 24, 2013 | Freezers
Have a True Freezer. It will kick on but when shutting down it shakes like crazy
This can be due to poor mounting of teh compressor. If the freezer is old then the mounting bushes can be worn out and must be replaced. Also check on the mounting bolts as if these are loosely fitted the compressor will ******** moe specially when the motor stops due to the force.
Jan 04, 2012 | True Freezers
Our Matsui MC170 FridgeFreezer has stopped working. It is just out of the 1 year guarantee period. It has always been very noisy with a harsh rattling sound when the compressor was operating, but this has...
I'm more than happy to have a look at the item in question to give you a professional opinion leaving you documentation to pass onto Curry's who should then legally look after you with this purchase from them.
Mar 22, 2017 | Freezers
The freezer door was left open last night. At noon today the motor was running, but now the door is closed the motor won't run and it won't get cold. Is it possible the motor burned out? It's only two...
More likely the start relay on the side of the compressor. To find out if this is bad first unplug the refrigerator. Remove the lower cover from your refrigerator Then take the cover off that is on the side of the compressor,you will see wires going to this. Now you should be able to see the start relay plugged on to the side of the compressor and unplug it. Now the best way to tell if it's bad is to shake it. If it rattles, it's bad and needs to be replaced. If not, most of the time it's ok. But rather than saying the compressors bad, you might want to replace it anyways because it does not cost much. A quick check on the compressor is to remove the start relay. You will see 3 pins connect a multi meter set for continuity. You should have continuity between any of the 3 pins. If you do not the compressor is bad. If you replace it and it doesn't work then the compressor is bad and you'll need to call a repairman. (Note that compressors are very costly and are normally not worth fixing).You can enter your model # at for diagrams and illustrations or to purchase a start relay. A 3 in 1 start relay will also work fine. All parts come with installation instructions. Not all models are available.
Oct 22, 2010 | Frigidaire 13.7 cu. ft. / 388 liter...
Our BEKO AP930 fridge freezer ice maker stopped working and we replaced the ice sensor but now the water dispenser isn't working. pipes connected correctly and there is a water suppky, Any ideas??
i had a similar problem with mine and the advice i got(possibly on here) was to leave the freezer door open to let the water supply pipe in the door defrost,put some blankets/ towels in the freezer to stop the
food defrosting,it worked for me and only took about 10 mins.
Dec 30, 2009 | Freezers
Paddle won't spin
I have a White Moutain freezer motor that is two years old and had the same problem as yours. During my last batch of ice cream the motor was spinning but the beater wasn't turning. I removed the motor and the square drive was spinning but I could stop it with my finger, there was no power like a gear or clutch was shot. I called the 1-800 number on the motor and they said they would send me a new motor. I didn't need to show a receipt or anything. All they wanted me to do was return the broken motor and they even supplied paid postage. I recomend you call them and ask for a new motor.
May 26, 2009 | White Mountain Freezer F69206-X 6 quart...
Freezer stops
hi thanks for the question i would replace the thermostat what happens is the fridge will get nice & cold then shut off and not come on again shake it it comes on replace the thermostat thanks the appliance doc
Sep 25, 2008 | Freezers
Freezers Logo
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
