Question about Nokia 2610 Cellular Phone
The phone now displays "Local Mode" or "Test Mode" and no longer works. What's wrong & what to do?
I dialed ##8378<SEND>, then clicked
Typing ##8378 Send brings up the phone test screen. When you select #2 (Field Test) and then select OEM monitor and select "enable" the phone resets and enters test mode.
In test mode you can press the volume up button to bring up the test menu. You can navigate this menu using the 1 and 3 keys on the number pad.
The most notable screen in test mode is found by pressing 3 until you reach SHDR protocol monitor will bring up the screen that displays real time reception and transmission information.
Other screens display other system information, but I caution against "playing around" with these menus too much.
To temporarily hide the test mode screen you can press the volume keys again. To take the phone out of test mode completely follow these steps:
1. dial ##test or ##8378 and press send 2. select 2 (field test) 3. scroll down to and select 10 (OEM monitor) 4. scroll down and select Monitor DISABLE 5. the phone will reset and return to normal mode.
Feb 13, 2011 | Casio G''zOne Type S Cellular Phone
Code manuelle
T205/T19x
*#06# -> Displays imei
*#300# OK -> List the Software & Hardware Version
*#301# OK -> Full Keypads Functional Test
*#303# Ok -> Set Default Language to English
*304# OK -> Set OFF engineering mode
#304*19980722# -> Set ON Engineering mode
*#305# OK -> Location: 1 OK
*#307# OK -> Engineering Test Mode
*#311# OK -> Phone code changed to default code
*#400# OK -> ADC, Cal val*
*#402# OK -> Adjust Display Intensity/Contrast
*#403# OK -> List the manufacturing Informations
19980722 OK -> Master Unlock code for Phone & Sim Lock
*#302# OK -> Acoustic Test*
*3370# -> Enhanced Full Rate
#3370# -> Deactivate Enhanced full Rate
*#72837726# OK -> Confirm?, Data Saved
1234 OK Phone Code Default
*#0000# OK -> Settings saved, restore set phone to default language
Dec 19, 2010 | Motorola Cell Phones
If fuse blown error shows, fuse (1.6mamp) if it replaced to (0.5 amp) then it works.
change the fuse with (0.5 amp).
If it doesn't work try this:
From Samsung site:
1 Press MENU # 1 9 3 4 in sequence rapidly. The LCD panel should now display TECH.
2 Press MENU, and then press ENTER. The LCD panel will display Tech Mode.
3 Press the left arrow (4 Press ENTER. The operator panel will display [YES].
5 Press ENTER. The toner warning message should be gone.
6 To exit TECH MODE, press MENU # 1 9 3 4 in rapid succession, as if you were dialing a phone number. The operator panel should no longer display TECH.
Then you don't need to use fuse after that.....
Sep 27, 2010 | Samsung SCX 4521F All-In-One Laser Printer
I just dropped my phone (nokia 2320c) in the bathroom and when I put the battery back in and turned it on it displayed a white screen with the words "test mode" in red. It seems as though my phone is...
If you have a problem of local mode test mode in Nokia 2320 Classic. You can solve this problem by following a few simple steps as given in this post.Lock at the diagram bellow that will help you to solve Test Mode Local mode problem in Nokia 2320 Classic. Before removing this part that is identified with red line in above diagram replace battery and if batter can not solve this issue dis assemble mobile phone. Find parts that are shown in diagram with red lines and remove them to solve Nokia 2320 Classic Test Mod Local Mod. Smartphone Repairing
Apr 12, 2017 | Nokia 2320 Cell Phone
While i am try to switch on my mobile it displays like local mode or test mode
try to remove the capasitor on top of battery terminal,,remove the 2 capasitor..
Jun 10, 2010 | Nokia 6030 Cellular Phone
My phone recently fell down but when i switch it on it was okay then i wanted to change the sim card and i switched it off,it didnt go on,all it displayed was test mode then after afew hours, local mode on...
If the phone was locked in various networks ,the test mode is an error message witch usually happens when you try home brew devices to unlock it for more than once or this could mean that you used a public phone card to open it,from witch the error results!
Dec 18, 2009 | Nokia 1650 Cell Phone
My nokia 1208 reads test mode or local mode and wont turn on
hey you have to bring your phone to a cellphone repair shop for it to reformat, but your phonebook will be erase once its been reformat.
Oct 25, 2009 | Nokia 1208 Cellular Phone
Touch screen isnt working properly
Try factory reset in test mode. To enter test mode, dial 3845#*990#
Dec 28, 2008 | LG KU990 Viewty
Displays test mode
To exit test mode, turn off phone.
Press *3001#12345#. Scroll up 1 to FIELD TEST (some phones may say NET MONITOR instead of FIELD TEST) and SELECT. Scroll to ENABLED and press OK. Turn phone off and then back on. Signal strength is the upper or lower left number. After test mode is enabled it will stay in your regular menu. To easily get in or out, press MENU, up 1 FIELD TEST and SELECT or OK. Dial 00 to get out and 01 to get back in.
Jul 03, 2008 | Cell Phones
Nokia 1600 displaying local mode
just remove the battery and short the battery polls (+, - ).
Dec 03, 2007 | Nokia 1600 Cellular Phone
Nokia 2610 Cellular Phone Logo
135 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
