Question about Rockford Fosgate Punch 801S Car Audio Amplifier
Can i use this amp to push my TRF2215. 15 - Rockford Fosgate Punch 801S Car Audio Amplifier
    Genius:
  • 1,144 Answers
Would need specs on amp and subs watts ohms
Posted on Jul 16, 2009
I have a 800 watt sony amp pushing 2 memphis pr's should the amp get hot
Yes the amplifier will become very warm or "hot". It is a good idea to place it in an area that will recieve plenty of ventilation and air flow. Some companies sell cooling fans for larger amps.
Jan 02, 2013 | Sony Xplod XM-554ZR Car Audio Amplifier
2006 Grand Vitara 6-Changer CD Player will not eject cds. 'Push Eject' error comes on.
this is a longshot, try unplugging it, wait about 30 seconds and plug it back in.
Sep 17, 2012 | 2006 Suzuki Grand Vitara
SEIKO CLOCK MODEL QHR016 HOW DO YOU SET UP TIME, DATE AND ALARM ?
Once the 'SET' button is pushed & held, & the numbers are flashing, turn it around to the face & use the ALM/TIME set buttons to adjust the numbers correctly. Then, continue on pushing the 'SET' button to cycle through the number positions & adjust everything else in the same way. Then, for language & temperature readout choices, push the 'OPTIONS' button & use the same ALM/TIME set buttons to cycle through the options, making your preferred choice. Be sure to push the 'WAVE' button to choose your proper region so it can receive the time signal. Worked for me. I use lithium primary AAA cells for the longest life.
May 20, 2011 | Seiko QHR016SLH Clock Radio
Hi i just got 2 new infinity 860w reference 8'' subs 250 rms each and pushing it with sony 600watt amp pushing it but very low sound and no bass why the othier speakers i have in 10'' hit the bass fine but...
The amp may no thav eenough to push these subs, these are top of the line subs, they probably require a bigger amp, if you are running other speakers through this also, you certainly need another amp, or a bigger one with more channels. also double check all your wiring.
Mar 29, 2011 | Jl Audio 12W7 Car Subwoofer
Seems as if the amp is putting out minimal power...its hard to say since i have 4 subwoofers in the vehicle...one set is ran by a sony amp pushing 540 rms in a vented enclosure and the other set is being...
do you have caps before your power going into the amps, might not be getting enough power, check your settings on the amp, gain output make sure it in stereo and not mono and check your crossover, or splitter
Jan 10, 2011 | Kenwood eXcelon X1200M Car Amp
Stop lamp switch how do you adjust this
the stop light switch is spring loaded & pops out when the brake pedal is pushed in & pushed in when the brake pedal returns you need to adjust it so as in is pushed right in & lock it in that position, then check if the brake lights come on when the pedal is pushed in you may have to re adjust it to get it right.....hope this helps.....cheers
Jul 26, 2010 | 1997 Hyundai Elantra
Describe your Poulan "" Push
Please change your are filter,or clean it, I hope this helps you and thank you
Sep 10, 2009 | Poulan "" Push Mower
Problems with my txi 6006 amp
check all connections then check the subs voice coils to make sure there not burnt smelling, or burnt looking.then check the cars charging system you might have to add an extra battery,and or cap.
Jan 09, 2009 | Hifonics Titan TXi 6006 Car Audio...
Cartridge jammed in printer
Try pressing the "copy" button and then the black "start" button. I did this a couple of times and the printer started working again.
Other people have had success when they open the lid, pull down the gate (to expose the cartridges) and then push in the little button on the left (to fool the printer into thinking the lid is closed). With that button pushed in, try pressing the "copy" button and then the black "start" button. The printer will make some working noises. When you close everything up again, it should work.
Aug 15, 2008 | Office Equipment & Supplies
Rockford Fosgate Punch 801S Car Audio Amplifier Logo
76 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
