Question about BenQ T904 19" LCD Monitor
I keep getting a little blue screen pop up that asks me to select input, d-sub or dvi. I select either then hit enter on my monitor but it keeps popping up. Any ideas how i can fix this.
  • BenQ Master
  • 3,866 Answers
You probably got a loose connection inside you monitor or your cable is loose, check both ends
1. check the end that goes to the video card
2. chec kthe end that goes into the monitor
3. if that does not shore it up it maybe a short inside so you may want to check that.
thanks
Posted on Jul 16, 2009
How to switch from analog to digital mode
Any contemporary monitor is able to switch analog/digital mode automatically if connection from signal source to monitor is set up properly.
Connect digital output from your graphic card to DVI input of the monitor. Disconnect any other signal cables from monitor and switch on both devices (PC & monitor). Wait a while. Monitor checks its inputs and a activates digital DVI, because it is only one active input on it.
If none picture excluding error message of monitor is displayed, go through these steps:
1) Check whether your monitor is set for automatic input selection. If monitor buttons have no response try to use analog input to activate screen (any picture, desktop background...) and then get monitor menu access by pressing menu button.
2) Find out what connector type has your graphics card in PC. Possibilities are: DVI, HDMI, DisplayPort and some their options. See Wikipedia for connector look if you are not sure.
Remember that blue D-SUB (VGA) connectors are analogue and you cannot activate digital mode through analog VGA cable.
3) Use appropriate cable to connect monitor to PC.
Example: Your PC has HDMI output. Use HDMi-to-DVI cable. Your monitor input is DVI and common DVI-DVI cable is not suitable in case you have PC with the HDMI.
Note that DVI-to-DVI, DisplayPort-to-DVI etc. cables are available. You must buy right one.
Be aware that "Auto" button is inactive in digital mode of monitor.
Nov 18, 2013 | Belinea 1930 S1 Monitor
I want to connect my Xbox 360 to my aoc f22+ monitor so I bought a hdmi to d-sub cable to plug the Xbox into the monitor as it didn't have a hdmi input. The screen just shows a blank image and the only...
You need a HDMI to DI cable not HDMI to d-sub cable. The sellers that are selling that cable do not tell you that it will only work with special video cards that output analog to the HDMI connector. HDMI is digital and so is DVI so they will adapt to each other. Keep in mind that this is for video only, sound will not work on the monitor because the DVI port does not support sound. You will need to add a set of speakers to the Xbox
Aug 27, 2012 | Computers & Internet
A blue display box continually pops up with Input Select D sub DVI. I am thinking it is something to do with the monitor. What is wrong?
This monitor has two types of video inputs, a 15 pin VGA D-sub connector and a DVI connector.
If the video card has a 15 pin D-Sub then connect the video cable to the 15 pin D-Sub connector on the monitor.
If the video connectors are DVI then connect the video card and monitor with a DVI video cable.
You will also need to configure the monitor for either the D-Sub or DVI video input.
Aug 03, 2011 | BenQ FP91G+ 19" LCD Monitor
I'm using a lenovo L195 LCD monitor, and my Graphic Card is Geforce 9300 GE. It is said that both the card and the monitor support DVI. When I try selecting the DVI signal input from the button on the...
If it's got a DVI input then it can handle a DVI signal.
There is no reason to have two cables plugged in unless you have two screens. If you've got two leads plugged in then the second one is probably turned off by default. I remember when I had a dual monitor set up, I had to turn on the second output in order to get both screens working.
You haven't said if you removed the d sub when the pc was off, but I get the impression that it was on at the time. Try unplugging the d sub while the pc is off, check the dvi cable is inserted correctly on both ends and then turn your pc on. It should now be working.
If that doesn't work then turn your pc off again, plug the d sub back in and start it up. Go to your display settings and turn on the dvi port, you want it to display a copy of the first screen. if you extend your desktop then you'll only be able to see half of it at a time. This isn't an ideal solution and your graphics card will be doing double the work, so try it the proper way first.
You might not notice the difference though.
Feb 04, 2011 | Lenovo L195 Monitor
Benq FP222W
Your monitor must have multiple inputs (Dvi,D-sub) so it searches when you start for which input is connected.
If menu popping up intemittently is your problem,The culprit is generally defective (Leaky) Key switches.You need to pen up monitor and replace.
Normally BenQ has a 3 year warranty.
Dec 28, 2008 | Computers & Internet
DVI connection fault
I had the same problem, you must call Viewsonic to change your screen. The DVI input on the screen is dead.
Jul 08, 2008 | ViewSonic VX2255 Monitor
Annalog power safe mode
Could be a could a couple of things
#1 Ensure the video cable is connected to the correct jack on the tower (Some systems have both an integrated video card and an Expansion card. See if there are 2 blue 15 pin vga ports, if there are 2, connect to the other one.
#2 You may be using DVI (White connection) and have the imput select set to D-Sub (Analog) Use the input select button on the monitor to sleect DVI
Jul 06, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
No display.
http://support.dell.com/support/edocs/monitors/2005FPW/En/setup.htm#Using%20the%20OSD
Make sure the proper input is selected
1: D-SUB for Blue VGA cable
2: DVI-D for White DVI cable
The option selected should be indicated on the power save screen.
If changing the input select and rebooting the computer have no effect an no video from the computer is ever displayed, then the monitor is in need of repair.
Jun 30, 2008 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Benq Fp737s
Hello Guys!
The problems you face may relate to the key switch panel,one or more of the key seems to be leaky.Clean all switches with switch cleaning fluid like WD40 or most reliable solution is replacing all these switches.
Please rate this solution.
Samir
Apr 09, 2008 | BenQ FP737S-D 17" LCD Monitor
Westinghouse ltv-19w6 source won't change
Have you tried to click the source button on the tv? It is the second button from the bottom on the right hand side of the screen.
I doubt your tv/monitor is turning off, it just isn't getting any input. D-Sub is the "pc monitor part".
Try clicking that button, give it sec, the hit it again. It will go through all of it inputs. If TV is what you are trying to find, it is directly after the Video input (green letters, top right hand side of the screen.) Keep hitting the button until TV shows up.
Good Luck!
Oct 23, 2007 | Westinghouse LTV-19W3 19 in. LCD...
BenQ T904 19" LCD Monitor Logo
496 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
