Question about Motorola Talkabout T5100 (14 Channels) 2-Way Radio
Short transmit - Motorola Talkabout T5100 (14 Channels) 2-Way Radio
  • Motorola Master
  • 1,654 Answers
Check your PTT area for debris or sticking. Clean with canned or compressed air, no solvents.
Here's a link to the user manual: http://www.motorola.com/mdirect/manuals/T50-T55_UserGuide.pdf
Posted on Jul 16, 2009
No transmit tx light does not go to red when keyed up. redio was pluged in backwards. has recieve.
its very easy to blow the transmit transistor circuit if shorted
https://www.cobra.com/sites/default/files/manuals/29LTDCLA.pdf
May 10, 2015 | Cobra 29 LTD CB Radio
Cant transmit on Cobra PR 4750 WX.
It sounds like you have a shorted RF output transistor.
Apr 22, 2015 | Cobra Radio Communications
I have a nokia lumia 625 and it does not pick up 5ghz wifi, any clues. It picks up 2.4ghz ok.
You can only get higher than 2.4ghz from your router if you are using a ''wireless N'' router and your phone must be wireless N capable. The fact that you are asking this question, probably means your phone is capable of ''N'' reception, but your router is not ''N'' compliant. You are probably using a ''B'' and/or ''G'' type router, which would definitely only transmit at 2.4ghz. // By the way, even ''N'' can be transmitted at 2.4ghz. The ''ghz'' isn't as important as whether or not the router can transmit ''N'' wifi frequency. You can tell by the download speed. ''B'' & ''G'' won't transmit faster than 54gb per second. The ''N'' speed is upwards of 100gb per second. All three (''A'', ''B'' & ''N'') can be transmitted at 2.4ghz if that is the router's rating. The ghz is not really about ''speed''. It is about the fact that many wireless devices (such as landline telephones) transmit at 2.4ghz, which can interfere with the router's 2.4ghz signal. So, using a router that transmits at 5ghz won't have interference issues with other 2.4ghz wireless equipment. // In short, what matters is that your wireless ROUTER transmits with the ''N'' version of wifi.
Jan 01, 2015 | Nokia Cell Phones
Why does the uniden granr xl go into the transmit mode when turned on
Wrong Microphone, Shorted leads in the microphone plug or a bad transmit switching transistor.
Aug 17, 2014 | Uniden 2SC1973 Transistor for Grant and...
The phone stop ringing & I can't find the problem
(I am assuming you are a business.) You don't have a power problem, you have a line trouble to or inside the phone itself. Phones operate with two wires: tip or green wire transmit the outgoing sound (voice); the ring or red wire transmit the incoming ringing signal. Your ring side is shorting out after the first ring. This short can exist in a local central office that transmits your dial tone to you; can exist in the underground/airial wires to your buiding; can exist in a wire closet (a riser wire closet from the basement wire closet to your floor); or in your the very base of your phone. You can have your service provider to verify the ring side of your service at the basement equiptment room. They may charge to verify any further; however, it is common to have this short appear from the central office. If the central office is transmitting a good ring side signal, pay a local communications company to verify your line from the basement entry point to your office(s). NOTE: FIRST TEST OUT A CORDED PHONE AND SEE IF IT RINGS OK...THAT WILL ISOLATE THE TROULE TO YOUR PHONE IF THE CORDED PHONE RINGS OK. GOOD LUCK.
Mar 26, 2014 | Vtech OfficeMax - Vtech5.8GHZ DSS Cordless...
Feedback through speaker during transmit
ARE YOU TALKING ABOUT THE INTERNAL SPEAKER IF SO THE WIRES TO THE SPEAKER INSIDE ARE BEING SHORTED TO GROUND TOUCHING SOMETHING METAL
Feb 24, 2013 | Radio Shack TRC-503 CB Radio
When i transmit radio will cut off during transmit, after a few seconds of realeasing mic button radio will come back on.
Mic.the in short a be could around? cord Mic the moving witMic the moving you I would need more information about what the radio does. are all the lights working? does it turn off completely? are you moving the Mic cord around? there cold be a short in the Mic wire.please post any details about what it does.
Aug 02, 2011 | Radio Communications
I have a cobra ltd 29 cb radio. I bought a 102 inch whip for it now when I key up my mike I hear my self threw my speaker and I can't transmit what's the deal
its shorting against the "Ground" sounds like. Check your mount on the 102 inch whip, also check coax, get you an SWR meter from RADIO SHACK , check it should be 1.1 to 1.5, if its 3.1 to 4.1 it has a short. Hope you get this fixed....Do not transmit with this short; or you fry the finals.
May 16, 2011 | Cobra Radio Communications
I can't hear people
Make sure you don't try to transmit without a proper CB antenna, it will damage & blow out the power transistors! If you have another CB close by, try listening without the antenna attached If you even faintly hear whats transmitted by the other CB, your antenna cable is probably shorted out... AGAIN don't try to transmit with no antenna or a shorted cable it will damage the unit!
Oct 22, 2010 | Cobra 29 LTD CB Radio
Radio does not transmit
take your radios to a w/shop and let them check the final rfpower
Apr 02, 2009 | Radio Communications
Motorola Talkabout T5100 (14 Channels) 2-Way Radio Logo
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
