Question about Maytag MGR5751AD Gas Kitchen Range
MAYTAG MAGIC CHEF SELF CLEANING GAS RANGE
ERROR F1 I HAVE TO UNPLUG THE RANGE FRON ELECTRIC OUTLET. ALSO OVEN DOES NOT WARM TO PROPER TEMPERATURE SETTING.
THIS GAS RANGE CAME WITH THE HOUSE WHEN WE BOUGHT THE HOUSE. THE RANGE HAS INSTALATION TAG DATED 1993
CANYOU ADVISE OF HOW TO GET AN OWNERS MANUAL AND REPAIR MANUAL THE STOVE IS A MAGIS CHEF MADE BY MAYTAG. THNX, GEORGE
  • 3 more comments
  • Anonymous Dec 20, 2007
    The temperature is about 25% off on Maytag oven. What should I do?
    Thank you
  • amyn Dec 22, 2007
    At random, the F1 code shows and it beeps and I can't get it to stop beeping- what's wrong with this. It came with the house and could be 10 or so years old!
  • Anonymous Jan 07, 2008
    F7,F0, ERROR
    S WHAT TO DO
  • Anonymous Mar 23, 2014
    control for oven light is out
  • Anonymous Mar 27, 2014
    the more control pad for temperature control is not working properly
  • 473 Answers
Here are the codes for magic chef:
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Posted on Nov 18, 2007
Magic chef self cleaning stove showing code f2
Hay wendy , tech sheet says to replace oven temperature sensor , ( make sure the fans are running properly ,good luck APPLIANCES R EN
Mar 07, 2013 | Magic Chef 31000 Gas Kitchen Range
After oven cleaning F2 appears and I can not open door on old Magic Chef electric range?
Hi charleybead,
F2 error appears when the Oven temperature is too hot. Please check the sensor harness. Replace relay board, if present, or oven temperature sensor (RTD).
Hope it helps.
Thank you for using FixYa.
Sep 01, 2011 | Magic Chef 31000 Gas Kitchen Range
My magic chef gas oven showed the F1 code. I tried to self clean the oven and some wires under the cooktop started to melt and smoke.
Hi nelson1999,
F1 error description is a defective touch pad or clock (ERC). Replace touch pad or clock (ERC). Touch pad is a more common problem.
Hope it helps.
Jan 27, 2011 | Magic Chef 31000 Gas Kitchen Range
I have a magic chef range. I ran the self cleaning on the range. Now when trying to use the oven I get a F1 and a F3 code. I unplugged it for a while to reset and still have the same problem.
F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F3 or F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Nov 25, 2010 | Magic Chef Ovens
An F1 error occurred when self-cleaning. I've
hello there:
On Magic Chef ranges, F1 usually indicated a defect in either the keypad or the electronic control. If the error shows when the keypad is disconnected from control, the problem is usually in the control. If the error ceases with the keypad disconnected, the keypad is usually the cause.
On some models the keypad and electronic control are 1 integral part in which case the whole control assembly usually has to be replaced to correct the problem.
: Until you can get this part replaced you can disconnect the ribbon cable from the board and the error should go away can
: disable the beeping? if this is happening
The buzzer circuit may be able to be separated from the rest of the control. If wired to it, the wire(s) may be able to be cut. or removed
hope this is very helpful for you
Best regards Mike
Jan 19, 2010 | Magic Chef 31000 Gas Kitchen Range
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
Our magic chef oven f1 code keeps coming on
MAGIC CHEF
Range/Stove/Oven Fault Codes
Feb 07, 2009 | Magic Chef 31000 Gas Kitchen Range
Magic Chef Gas Range, model CGR3740ADW
magic chef fault codes
Jan 27, 2009 | Magic Chef 31000 Gas Kitchen Range
"F1" error code on Magic Chef gas range Model 3488XRA
the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
Jan 03, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Have a magic chef oven, f1 display after self cleaning, stove top works fine, any thoughts
F-1 is a fault code.
Disconnect the power plug or turn range power off at circuit breaker. Wait a couple of minutes, then plug the range in or flip the range circuit breaker to ON.
Oven control beeps & displays any F  code error (for example
F11) - Electronic control has detected a fault condition. Press
CLEAR/OFF to clear the display & stop beeping. Reprogram
oven. If fault recurs, record fault number. Press CLEAR/OFF
contact an authorized service agent.
Dec 01, 2007 | Magic Chef CER3725AA Electric Kitchen...
Maytag MGR5751AD Gas Kitchen Range Logo
727 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
