Question about Air Tools & Compressors
Have a campbell housfeld compressor supposed to shut off at 120 but it blow the breaker after 100 is there a way to lower it so it cuts off earlier then 120? i let my friend borrow it and broke the switch, i can still turn in eiyh a screw driver from off to auto, but wont kick off till the breaker blows...said he had the wires off and im thinking he put them in the worong spots, any ideas or anyone that have this and can let me know where they go, 4 wires...
  • 98 Answers
If wires were in the wrong slots you would know once you put power on the unit, the gauge could be damaged and giving you a false reading and the pressure switch may also be damaged.also if you are using an extension chord this may also cause high amp draw.
Posted on Jul 21, 2009
Compressor wont stop running
Hi pickeringstr
Replace your shut-off switch...it is faulty
Bud
Apr 28, 2013 | Air Tools & Compressors
Runs then shuts down blowing breaker on20amp 12 wire extcord
The motor gets overload, check compressor and motor
Mar 21, 2013 | Campbell Hausfeld Wl506206aj
My campbell 0.33 runs but won't built a pressure
Check that the drain cock on bottom of tank is shut off,or leaking.?
Jan 28, 2013 | Campbell Hausfeld 0.33 HP 2-Gallon 100 PSI...
I have a Campbell Hausfeld oil type direct drive 7 gallon compressor. It often works fine but it frequently locks up until the internal circuit breaker cuts off the electricity to the motor. When the...
In our shop we have found the conditions you describe are almost always attributable to the power supply. First, never run a compressor on an extension cord, you are always better off running longer air lines. If you absolutely have to run an extension cord use a least a 12 guage cord no longer than 25 feet. If possible plug the compressor in as close to the circuit box as possible. Lastly the circuit the compressor is plugged into should be rated at least 15 amps, 20 amps is recommended for most compressors. Low amp lines cause the motor to overheat trying to get enough power and usually blow the circuit breaker at the motor and not at the circuit breaker. Lastly, use only compressor oil in the pump and make sure it's not overfull. This will also cause the motor to work harder and trip the circuit breaker.
Dec 17, 2010 | Campbell Hausfeld 2 - Gallon Direct Drive...
Compressor shuts off at 60 psi will not come back on until opsi
If the pressure switch has been changed you will need to reset it if not ,then is the compressor trying to come back on but will not start untill it reaches 0 psi?
Apr 25, 2010 | Campbell Hausfeld 26 Gallon Low Rider...
Campbell hausfeld model fp2003 oiless compressor keeps blowing the fuse as soon as I turn on the switch.
Possible short in the cord. Inspect cord for cracks, damage. You said fuse. However if you mean Breaker it's possible the the breaker is weak so it no longer can handle the pull of the compressor. Pull a identical breaker and switch out with the other if it doesn't trip then replace the other with a new one. I hope this was helpful. Please rate the answer if it was of any help. Good Luck and have a great weekend. Jeff
Apr 04, 2010 | Campbell Hausfeld Air Tools & Compressors
My air compressor can pump air in but when it get
when it reaches 120 psi it will cut out usually will cut back in at around 70- 80 psi if it struggles to restart at cut in pressure it may not be bleeding the head pressure om your compressor . this is done by the pressure switch which when shuts off releases a small squirt of air under it . to solve this problem you may need new switch . there is also the non return valve to check
Nov 12, 2009 | Campbell Hausfeld 28 - Gallon Air...
Air compressor wont turn off
If the wires werent put back right the unit would not run at all , you may have to replace pressure switch when it broke it may be keeping the contacts in the closed position.
Jul 16, 2009 | Campbell Hausfeld 20 - Gallon Air...
Campbell Hausfeld Air Compressor auto shut off switch not working
i have the same one and mine was broken by my kids , i had to replace the entire component, DONT RUN COMPRESSOR with out the regulator working IT CAN EXPLODE IF OVERFILLED,a must fix situation i believe i got mine from sears , a great unit ive used it painting and with many air tools over many years now , well worth fixing mine is a little loud but dependable good luck.
Mar 15, 2009 | Air Tools & Compressors
High/low pressure spring settings
Generally, the pressure switch is not adjusted more than once or twice in the life of the compressor since the discharge pressure can be adjusted with pressure regulator. However the life of the compressor can be increased if lower pressure settings are maintained. Your pressure switch was set at the factory to a setting of about 120 - 150. If your cutout pressure is higher than 150 surely lower.
STEP 1: Turn Main Calibration Screw ( center screw with large spring) clockwise to increase pressure and turn counter-clockwise to decrease pressure.
STEP 2: Turn Differential Pressure Screw (small spring) clockwise to decrease cut-in pressure and
turn counter-clockwise to increase cut-in pressure.
Differential Pressure is defined as the difference between cut-out and cut-in pressure. There should be about 7 to 12 psi difference between cut-out and cut-in.
In our shop we rarely adjust more than a couple of turns because these switches are sensitive.
Good Luck and please post again if you have other concerns about your compressor.
Jan 21, 2009 | Campbell Hausfeld 26 - Gallon Air...
Air Tools & Compressors Logo
48 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
