Question about Sony DRU-810A DVD RW Dual Layer Burner
DRU-810A not booting bootable cds
my sony dvd writer doesn't boot from cds and dvds. it works well on both windows and linux. all things work inside an os. but it doesn't boot from cds...what could be the problem ?
  • 51 Answers
Re: DRU-810A not booting bootable cds
Check your boot order in your bios and set your cd drive to first boot
Posted on Nov 19, 2007
0 characters
3 Points
I have a sony DRU-810A drive but my dvd writter dvd doesn"t working with dvd9 I like having diver update . thanks
You have to update the firmware. Go to
Download the instructions and the file with the recent firmware. I did it, No problems, no difficult.
Feb 10, 2011 | Sony DRU-810A DVD RW Dual Layer Burner
I have a sony dru 820a dvd writer,it is not detecting the cd/dvd when inserted but it makes some wierd sound and does not read the inserted media. it was also interferring with booting of PC but once the...
ur registry is corrupt...
try cleaning the registy
visit my website
go to dowload page in there...get Tuneup Utility...install, clean the registry....
also try runing chkdsk...if u know how to do it...
all the best
Dec 25, 2009 | Sony DRU-820A DVD RW Dual Layer Burner
Can't write dvds
i have same problem. i tried to fix it myself but didnt work its the problem of dvd-writer no problem with software, i know becoz i took my friend's dvd-writer and its woking absolute fine, so better take it to some hardware repair shop.
Oct 02, 2009 | CD & DVD Burners
Eject button not working.
Have you tried to go into Device Manager to see if there is any hardware or Firmware upgrades or try the Sony site! Check the link below.
May 24, 2009 | Sony DRU-810A DVD RW Dual Layer Burner
Sony DRU-810A fails while burning second layer
The Problem Is That You Do Not Have Enough Space In Your Windows Drive.
If You Have Just about 1GB Still May Be Not Enough According To Your ROM
You Should At least Have 4.5GB Free In Your Windows Drive For Disc"s to Perfectly Burn.
Good Day,
Im A FixYa Professional - email -
Jan 12, 2008 | Sony DRU-810A DVD RW Dual Layer Burner
Sony DRU-500A Won't read DVDs... at all.
INSTALL VISTA ANY WAY the problem is that windows can use the drive..
enter setup when the system boots up
go to booting options
and select the dvd rom as the first boot device
ensure the vista disc is in the drive
and save and exir setup
it will tell you to pree any key to boot from cd/dvd
and it will install vista without any hassle
Dec 21, 2007 | Sony DRU 500A DVD±RW Burner
Sony DVD RW DRU-710A won't burn dvds
sounds exactly like my old dead drive. if it cant boot from a cd its likely a bad drive
Nov 02, 2007 | Sony DRU-810A DVD RW Dual Layer Burner
Sony DRU 710 not writing DVDs or CDs
as with all writers eventually they fault at the lens and it gets out of line and cannot read discs, you can try the usual thing of checking Sony for any firmware updates, but first:- Go to my computer>right click>hardware tab>device manager, then down list to cd/dvd drives and click '+' sign and highlight your writer, right click on it and select uninstall. Restart PC and it will be automatically re installed, try again and if no change you will need to replace the drive as they are cheaper nowadays
Jun 20, 2007 | Sony DRU-710A DVD±RW Dual Layer...
My SONY DRU-810A DVD Writer doesn't work with TDK DVD+RW Disc
some dvd brands dont work with all dvd writers, so your option is to try another make, if that works ok then it's not a writer fault it is just that the media make is not compatable. if you start to see problems with all makes of disc then the writer laser is faulty and a replacement drive neccasary.
May 11, 2007 | Sony DRU-810A DVD RW Dual Layer Burner
Problems recording DVD-R 16X
Try this download page to update your firmware from 25/10/05, so if you bought your writer before this date maybe this will work, otherwise buy 8x discs. The faster the discs are burned the more chance of errors there are, you should write at slower speeds for better quality.
Oct 27, 2006 | Sony DRU-710A DVD±RW Dual Layer...
Sony DRU-810A DVD RW Dual Layer Burner Logo
137 people viewed this question
Top Sony CD & DVD Burners Experts
Brian Sullivan
Brian Sullivan
Shahzad  Waseem...
Shahzad Waseem...
Are you a Sony CD and DVD Burner Expert? Answer questions, earn points and help others
