Question about Acer NSK8458AN Keyboard
My keyboard has several keys that have little green charactors on them. For example the u has a 4 and the "i" has a 5 and the "p" has an * I have hit something that turned this feature on and now i can't turn it off. Help
  • 339 Answers
You can put your keyboard in "Numlock" mode if you have a lot of numeric data to input and use these keys for numbers rather than the normal letters. The key sequence varies by manufacturer but it's typically going to be labelled with a rectangle around text such as "NUM LK" and is activated by holding in the FN key and then pressing the labelled key. Deactivation is the same.
As you've found out the hard way, it can be really confusing when this happens accidentally.
Posted on Jul 16, 2009
Windows keyboard shortcut commands
There are many. Do a Google search for "Windows Key Combinations" and you should find several links to a list of the available commands. The "Windows Key" is that key between the Ctrl and Alt key on your keyboard that looks like a window with 4 panes in it. You hold down the Windows Key while pressing any one of several others, depending on what you want to do. afor example Holding down the Windows key and pressing R will open a "run" box. The Windows Key plus E will take you to "My Computer". the Windows key plus D will immediately take you to the Desktop, etc., and so forth.
Jul 14, 2014 | Microsoft Windows XP Professional
How do I get the 1/2 or 1/4 to work
Try CTRL+SHIFT+FN key together, to toggle this ON or OFF
May 27, 2014 | Acer NSK8458AN Keyboard
How do I access the blue letters on keys?
Try holding the Alt or Ctrl key down, if not then look for a Function key or a blue key (not F1 -> F12)
Good Luck,
Bill
Aug 17, 2012 | Acer Aspire One PC Notebook
2eyb6erd er6r
The number 2 is showing up on your keyboard because you have the Num Lk (Number Lock) key on and you are probably hitting the FN key then the K key so the little number 2 that is on the K key appears as what is typed. for example: On my keyboard there is a Big Letter K key and also on that key is a small number 2 which is blue. In order for me to get the number 2 when I type I have to have the Num Lk key on and then I have to Press and Hold the blue FN function key on the lower left of my keyboard then hit the K key and the number 2 is what gets typed.
Apr 21, 2012 | ASUS Eee PC 701 Notebook
How do I choose symbols such as @ from the keys that have several symbols?
Hold down the blue "fn" button when you press the key, it will give you the alternate character.
Feb 28, 2011 | Acer Aspire One PC Notebook
When typing certain letters or numbers other letters and/or numbers automatically appear. Example when i type the "p" a space automatically appears; (p ap er). When i type the number...
Well it could be several things, not the least of things is radiated electrical noise. Seriously, I had several customers get hit with this problem. One test was to hold your hands just over the keyboard. If random characters appear, you sitting within the radius of a strong transformer.
Look around the area you are in, do you see any type of antenna nearby? If you do, rotate your lap top 90 degrees.
Also, the keyboard may be starting to fail. From your description I would suspect that the scan code for the key you pressed is not getting reported back to the CPU properly.
Replacing the keyboard on a Satellite is fairly straight forward. The replacement part from Toshiba only cost $35. and that included shipping.
Don
Nov 17, 2010 | Toshiba Laptop Keyboard for Satellite L10,...
For example, I hit the number '5' and the letter
You are in Num Lk mode. To leave this mode,
press the NumLk key again, a green LED (1) will
go off indicating you are no longer in this mode.
The Num Lk key usually is in upper right corner of the keyboard.
Aug 01, 2009 | Sony VAIO VGN-CR220E/P Notebook
When I hit the 'l' key, the number 3 appears.
press shift + num lock and see if works. you should have a green led under the display. when press SHIFT + NUM LOCK , the green led state should change
Jul 19, 2009 | IBM Thinkpad 560 Series Laptop 20h4241...
Keyboard not responding to EVERY stroke
MAY BE BECAUSE THE KEYS DON'T COME IN CONTACT WITH THE PLASTIC LAYER IN KEYBOARD OR MAY BE COMPUTER DOESN'T GET CORRECT INPUT SIGNALS
Jan 22, 2009 | Logitech 967437-0403 Keyboard
Computer is locked in the green symbols of the keyboard
TO SHUT OFF the green keys, you need to disable the multiligual or French keyboard layouts. For Windows 7:
Click CONTROL PANEL
click CLOCK, LANGUAGE, AND REGION
under REGION AND LANGUAGE
click CHANGE KEYBOARDS... etc.
click KEYBOARDS AND LANGUAGES
.......for example, by clicking on a keyboard name (ie. US or and UNITED KINGDOM for example) and then clicking PROPERTIES to the rtight, you can see the actual key layout.......
On the list of installed languages, click anything multiligual or French, and then click REMOVE found on the right-hand column
click APPLY
click OK
Then you've removed the French.
Otherwise you have to click the LEFT ALT key and then the LEFT SHIFT key to swich back and forth between the green keys and the white keys.
Jan 04, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer NSK8458AN Keyboard Logo
760 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
