Question about Hunter Fan Co. 60 In.Brushed Nickel Stonebridge Remote Control Ceiling Fan
The fan runs but lights won't come on anymore when I use the remote, pull chain or wall switch
  • 25 Answers
I'm betting the circuit board has gone defective.  After shutting off power to unit, disassemble and have a look at it.  Bad solder joints and discolored from heat areas may lead to a repair.  Otherwise, this site has Hunter fan parts.
http://www.eceilingfans.com/
Posted on Jul 16, 2009
Casa Vieja ceiling fan w/remote; worked well. Then wall switch was turned on/off, chains pulled. Everything working: fan high, med and low, and light on/off/dim - except now fan won't turn off !
The chain pulling and switch flipping causes the simple logic in the remote receiver to become confused. Your only hope for restoring normal operation (short of replacement) is to disconnect power at the source, then remove remote battery and press all buttons to eliminate "stuck button" problem. Reconnect power and test operation using only the remote. If normal, you will have to decide whether to disable pull chains, wall switches, or both. If not normal, you will have to try an infinite number of combinations of pull chains, wall switches, and power on-off to get things back to normal.
Aug 11, 2016 | Casa Vieja Dryers
We just recently installed a harbor breeze ceiling fan w/light and remote. During a storm the lights just quit working. What can we do?
Power outages cause ceiling fans to suffer memory loss. The basic "cure" is to disconnect fan power at the source and, while waiting a few minutes, remove the remote battery and press all buttons to verify that none are stuck. Reinstall the battery and test operation. Other factors may affect restored operation such as using wall switches and pulling the chains. The simple brain in the fan canopy can't remember switch and/or pull chain settings at the instant of power loss.
Jul 24, 2016 | Dryers
I have a Heritage Celing fan model M42UL. I connected it to work with the remote control. It does not work with the remote anymore. How can I reconnect it to work without the remote?
Make sure your dip switches match in the receiver & transmitter. If you have a wall switch, make sure it's ON. If there are pull chains on the fan, press the high on remote then pull chain until it's on high speed.
Aug 29, 2015 | Heritage Dryers
Can't turn off fan when light is on
Not sure, but if its a new installation, I would say that the wiring has been done incorrectly. Ceiling fans with lights should be able to work independently. both on / off or 1 on, the other off.
Feb 22, 2014 | Televison & Video
Lights won't work on Harbor Breeze ceiling fan
Ceiling fans operated with remote controls, pull chains, and/or wall switches tend to get confused and just fail. You can try disconnecting power at the source and, while pausing briefly, remove batteries from the remote and push all buttons to eliminate the "stuck button" cause. Then, reconnect power and try various combinations of controls until something works or you give up in frustration.
May 03, 2017 | Dryers
Hunter fan works light broken
Check to make sure light wires are connected at light kit & remote. Otherwise it's probably a bad receiver. If there is a pull chain for the light pull it once & try the remote light button again.
Mar 10, 2013 | Hunter Ceiling Fan Light Switch Control
Why won't my remote for my light on the Hunter fan work? The light also will not come on when I pull the chain.
I usually discuss this exact problem with customers that have a DIY ceiling fan. First; If you just installed this fan you noticed that there are several switches on the fan and on the remote, there is also the switch that originally controlled the ceiling light fixture (If it is a dimmer switch, it MUST be replaced with a single pull switch). All of these can be set wrong. Make sure the circuit breaker is not "tripped."
To start easy; assure that the wall switch is on, (leave all the "pull chains" alone, for now) Check to see that the remote has fresh batteries. press the light switch (on the remote, if it is a dimmer type set it to high, press it several times. If this does not work leave all the switches where they are and pull the light chain once, and again try the remote for the lights only. Hopefully that worked. Now do the same for the fan, press the remote once (on any speed) If that does not work pull the fan chain once try the remote again pressing the same switch, that should work. Now that you have it working remove all the pull chains, so it won't get "confused" again. Good luck!
Feb 09, 2011 | Hunter 27185 Remote Control
The remote controls the fan speed but wont dim or control the light. the unit wont work if the light switch is off so I cant use the fan at all unless the light is turned on
mcdevito75 here, Generally the Ceiling fan motor is hooked up by-passing the wall switch but still to the hot laed going to the wall switch whlie the lights are hooked up to the hot lead after the wall switch, So without the remote, Manually operate your fan and lights. First with the wall switch off the fan should work and the lights no work. Now turn the fan off with the pull chain on the fan shroud close to the ceiling. Now turn wall switch on and lights should work with wall switch and the fan should also work. if so, re-program the remote or change the batteries or even re--place the remote.
Jul 26, 2010 | Hunter Ceiling Fan Light Remote Control
Hunter 52, fan works but light no longer works with remote or chain pull
mcdevito75 here, Don"t the fan lights work off the wall switch, The chain pull should be for fan speed. Check make sure electricity is going to the fan.
Jul 19, 2010 | Hunter 52" Ceiling Fan With Light And...
Hunter Fan Co. 60 In.Brushed Nickel Stonebridge Remote Control Ceiling Fan Logo
133 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
