Question about Toshiba 50A60 50" Rear Projection Television
Toshiba 50A60 vertical picture adjustment
I have a 7 year old 50A60, and recently it looks like the picture is stretched out vertically. You can tell when there are words on the screen that they extend beyond the screen to the left and right.
Is there a vertical adjustment somewhere on the TV or remote?
  • Deck Guy Dec 07, 2007
    I just found out that if I disconnect the cable box and just connect the cable directly to the TV, the picture is fine. Does this indicate that there may be a digital tuner or something that is bad? Removing the cable box means I'm changing from a digital signal to analog right?
    Problem Solver:
  • 6 Answers
Try downloading the service manual and go through the calibration excercise. There's also some additional controls behind the right front speaker.
Posted on Nov 26, 2007
Toshiba Color TV CF30D50 picture stretched vertically off-screen both at top & bottom - can find no adjustment knob - ??
The vertical sweep output section of your tV has the fault. Replace all the electrolytic capacitors [5 or 6 of them there] at one time. Height to the picture is more than normal is the fault now.
Aug 19, 2012 | Orion1934 19" TV
CF3273A Toshiba Vertical height and linearity problem, looking for adjustments
I'm not real sure what year this set is. Most sets 5 years or newer have service menu adjustments. Unless someone went in and adjusted it to get it out of adjustment, adjusting is not going to do much good. I would be looking for bad capacitors in the vertical circuit or possibly the vertical output IC. These IC's tend to run pretty hot anyway so they are usually the problem along with leaky caps.
Oct 13, 2009 | Toshiba Televison & Video
Toshiba TV (about 7 years old)
You had parts in the vertical deflection circuit failing, most common are the vertical output IC and possibly several capacitors also in the same circuit.
Sep 11, 2009 | Toshiba 36A50 36" TV
9 year old Toshiba TV. The picture is totally
Symptom shows TV got problem in vertical out deflection section, please check and replace vertical output IC and nearby electrolytic capacitors.
Jun 25, 2009 | Toshiba Televison & Video
Skewed picture
Convergence problem.
Dec 11, 2007 | Televison & Video
Toshiba 32 inch tv made1990
yes,you can adjust it by your remote control,find the service menu and from there you can now adjust the vertical from of your tv.
Oct 30, 2007 | Toshiba 32AF43 32" TV
Picture on 42HDX82 vertically stretchs after about 10 mins
Sounds like a bad cap, spray some freeze around till you can duplicate the problem.
Oct 22, 2007 | Toshiba 42HDX82 42" Rear Projection...
Toshiba TV picture has shifted high
if it cannot be adjusted then there is a problem in tv. your problem is in vertical output circuit Can this be corrected easily ? yes or do I need to start looking for a new TV? I love this one and would like to keep it a while longer. not to look for new will keep it for longer that has a picture that recently shifted upward and now cuts off about 1 inch of the top of the picture. Otherwise it functions properly. your problem is in vertical output circuit please check 1loose contact in vertical output section 2 capacitor defective in v/output. it is a common problem. it is a not a major problem. if you are not tech person get it done by skilled tech. hope this will help.
Sep 30, 2007 | Toshiba 32A33 32" TV
Vertical output problem
you probably just need to resolder the vertical output IC. It will be mounted on a heat sinc. probably 7-10 pins. Part number may start with "LA" like LA7845 or similar, there are others though. You will probably see the rings around the solder joints on the bottom of the board. Good Luck
May 17, 2007 | Toshiba 36AFX61 36" TV
Toshiba 50A60 50" Rear Projection Television Logo
108 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
