Question about Polaroid i531 Digital Camera
Problem with i531
I have the i531 and when I turn it on the green light will flash the screen will not come on then it turns off and it i even replaced the batteries a number of times.
    Problem Solver:
  • 6 Answers
Re: problem with i531
I had a Polaroid i531 that would beep 3 times then shut down & the lens wouldn't retract.
I fixed it like this:
  1. Inspect the lens from all angles and you'll see that the lens assembly is out of sync. (My was looking upward ever so slightly)
  2. Using gentle finger pressure, press in the opposite direction of the abnormal lens direction
  3. I heard a snap, then I powered the camera on.
  4. Camera now works.
Posted on Jun 28, 2008
0 characters
3 Points
How do you turn o and off flash
Your camera has 4 modes flash function : 1; Flash Off ( flash will Off in any shoot) 2. Flash Fill in ( flash always On) 3. Auto Flash (Camera decided flash) 4. Red Eye reduction flash ( Camera decide flash).
You can set your flash base on your need.
Nov 29, 2010 | Polaroid i531 Digital Camera
Kodak easyshare c340 wont turn on
My EasyShare was doing the same thing your post describes, which is how I came to be at this website. I tried the one suggestion of turning on camera (I did so to the 'Auto' setting), then pressing the |O|/i button, which is the button below the 'delete' and above 'menu' next to the screen. That didn't work for me. I then tried the suggestion with the other modes on the power dial, no luck.
I then, from the off position, turned the dial the other way, to the 'favorites' icon, and it worked! I didn't have a memory card in at the time, so it made a noise almost like saying "uh-oh", with the message 'no images in favorites'. I then turned it off, then turned it to 'auto' again, good to go! The lens opened, green light remained on in all modes.
If this helps even one person, I'm glad.
Dec 06, 2008 | Kodak EasyShare C340 Digital Camera
Sin flash?
when i turn on the camera the light keep blinking then the camera will just cut off. the flash is not working
Oct 26, 2008 | Polaroid i531 Digital Camera
Can't take pictures with the flash
I would suggest returning it for one that will take pictures when the flash is turned on. Doesn't sound like you are doing anything wrong, just sounds like the camera is faulty.
May 22, 2008 | Polaroid i531 Digital Camera
Camera wont turn on
for self diagnosis.please let me help you before leaving a bad feed back.
Apr 30, 2008 | Kodak EasyShare C533 Digital Camera
Im not an expert in camera however i can suggest you to reset the camera. if not resolve then, the battery connnection failure to connect when the camera boot up. please do a series of check up of the battery connection. if you affraid to do so, the; maybe you can let the repairman do it for you.
Mar 23, 2008 | Polaroid i531 Digital Camera
well! you did not come back i assume that you solve your problem, if not then tell me more about the problem.
Feb 23, 2008 | Polaroid i531 Digital Camera
Won't Power Up
I have the exact same issue. It needs to be returned to the manufacturer. Make sure you have your receipt or they wont take it back if it was made after the manufacturing date (Mine was made in April 2007). The warranty only lasts one year from purchase. You have to call them and get authorization for the return. Good luck!
Dec 13, 2007 | Polaroid i531 Digital Camera
My camera has a black screen even when is on
It does not look good.
Here are some problems which could be with this camera:
LCD broken or bad.
CCD problem.
Since you go have some light on the green light, then that appears to be a LCD problem. this can happen if the camera had an impact to cause the LCD to be damaged or disconnected in some way.
For further help:
Go to:
Ask for your model.
Sep 18, 2007 | Vivitar ViviCam 5100 Digital Camera
Polaroid i531 Digital Camera Logo
134 people viewed this question
Top Polaroid Digital Cameras Experts
Steven Wander
Steven Wander
Are you a Polaroid Digital Camera Expert? Answer questions, earn points and help others
