Question about Technics SL-1210 Turntable
I got a problem with one of my technic quarts mark 2 turntables ...... thay sit at the same speed when the pitch is on ( 0 ) but if u put them both on pitch -3 one is faster than the other one do u no whats up with it or where i can get them fixed ???
    Champion:
  • 287 Answers
I work on them. Do they have the slide controls like the 1200's do? they can fail or need a little di-ox-id cleaner in them . There is also a fine speed adjustment which can be adjusted. www.megaone.com/larry
Posted on Jul 16, 2009
Pitch light pulsates when i press start
the pitch adjuster is supposed to blink that is how you adjust the pitch. hope i understood your question right.
Jun 15, 2012 | Panasonic Technics SL-1200MK2 Turntable
There are 2 problems with the my deck: 1. The +-0 light for the pitch will not work but everything else about the pitch works fine. 2. The deck will not change from 33bpm to 45bpm, I have replaced the...
Hi, please do this test for me. With the deck running on 33 speed and the pitch control set to 0 use your finger on the platter centre and speed it up manually as much as you can. Doe's the quartz lock lamp come on? If not then open the deck up and loosen off the fixing screws on the circuit board that has the 33/45 buttons. Try to change speed with the board loosened off. If none of the above makes any difference replace the quartz lock neon. Use only original Technics neon. As a matter of interest have you done any mods to the deck? Cheers John,
Sep 29, 2011 | Technics SL-1210 Turntable
My stanton t50 turntable plays too fast even when the pitch fader is at the slowest speed
You need to calibrate your pitch control. This requires a small precision screwdriver (similar to something you would repair eye glasses with). If you look under the turntable where the pitch control is you will find 2 small holes, 1 marked 33 and 1 marked 45. Turn the turntable on and set the pitch control lever to zero pitch. While the turntable is spinning insert the screw driver into the pitch calibration hole under the turntable and twist the potentiometer back and forth until the turntable pitch is zero (I believe clockwise is faster, counterclockwise is slower as you look up from the bottom of the turntable). This is a fine tune adjustment and will not require much turning to adjust the speed (1 or 2 mm's) either way should start to bring you into zero pitch. The platter speed can be verified by the little dots on the rim of the platter. They should appear stationary in strobe light on the power switch when you are at zero pitch. When you are adjusting the speed you will observe the dots on the platter rim spinning clockwise and then counterclockwise as you adjust the fine tuning. Fine tune the speed until the dots appear stationary and you will be back to zero pitch. You have to adjust the turntable at both speeds 33 and 45 using the correct fine tuning hole under the turntable. My personal experience is it is easiest to do this with 2 people. 1 person to hold the turntable level and running, while the other adjusts the fine tuning. Hope this helps.
Oct 22, 2009 | Stanton T.50 Turntable
Pitch Control Problems
More than likely the pitch needs to be calibrated. Although not very hard, I would suggest getting this done by a professional, as it does require opening up your turntable.
Here are instructions - TECHNICS PITCH CALIBRATION
If you cannot perform this, then find yourself a good technician who knows what they are doing.
If this does not work, more than likely either your pitch control, the pitch gain, or one of the IC's need to be replaced - at this stage, only a qualified service tech can help you.
- OPTiC
Master Tech
Digital Analog Therapy
Technics Repair : Technics Turntable Parts
Aug 28, 2009 | Technics SL-1200 Turntable
Pitch Control issues on Technics 1200 mk2
The pitch pots have been altered.
there located under the platter & cover on the main circuit board.it's a peace of **** to sort them.
if you help e-mail me djtatty@hotmail.com
Jul 20, 2009 | Technics SL-1200MK5 Turntable
Help for technics 1200 MK2 and 1210 Speed is too fast
On the 1200MK2 the pitch control slider is for just that purpose. Disregard the 0 setting and use the illuminated strobe marks on the platter to adjust to nominal speed. When they appear to be motionless you are there. The control on the 1210 may be a knob but the same principles apply.
http://en.wikipedia.org/wiki/Technics_SL-1200
Apr 04, 2009 | Technics SL-1210 Turntable
Technics Turntables
Sounds like you need a new pitch control. YOu can purchase a pitch control separately and install yourself, however soldering is required. You will have to solder off the old board, and solder on the new board.
You can purchase the PART HERE
- Davis
DJ PRO AUDIO
www.djproaudio.com
www.repairnyc.com
www.1200s.com
Jul 16, 2008 | Technics SL-1200MK2 Turntable
Technics 1210 Mk 2 Pitch Fade Problems
You have to understand any sort of calibration meter will only tell you if the pitch control is faulty - or excessively too fast/too slow. If your units are just 'off' then that is a matter of a simple calibration of your pitch controls back to original factory specs. Also, just so you know, the pitch controls on the 1200s are not really calibrated when they leave the factory. They are basically installed, set a default setting, then shipped off. So, you'll often times have 2 turntables with sequential serial numbers, but they are both off.
Here is a tutorial on calibrating your unit back to original factory settings: TECHNICS SL1200MK2 / SL1210MK2 TURNTABLE PITCH CALIBRATION
You can also print this out and give it to the technician who serviced your units. Also ask him what kind of calibration meter, or unit did he use to test? Just curios.
- TWEAK AV LAB
The ORIGINAL TURNTABLE Technicians.
Dec 02, 2007 | Technics SL-1210 Turntable
Turntable pitch control problem
sounds like the pitch needs replacing or tighting. Get them serviced. Ask your equipment supplier shop. Good way to check the decks are in sync is to place the pitch on each marked seting ie 0 / 2/ 4/etc making sure both decks are set to the same pitch adjustment speed. Look at the light from the on/off switch and check the 4x circles on the deck platter and make sure they are the same as each other. If you never used this before. set your eyes and pay attention, you will notice the pattern. I mix this way to get tunes roughly in time without listerning to the track - DJ EZ helped me with this years ago. peace DJ Nyce
May 30, 2007 | Technics SL-1200 Turntable
Technics SL-1210 Turntable Logo
69 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
