Question about Garmin StreetPilot C330 GPS Receiver
My garmin 330 doesn't show maps
No map data available shows up on the screen
  • 1 more comment
  • Anonymous Dec 27, 2007
    can not get maps of streets, can not put in street address. tried over and over to get the same results.
  • ejsullivan21 Dec 30, 2007
    I have same problem except with garmin 550. -
  • Anonymous Feb 24, 2008
    yes same problem
  • 174 Answers
Did this problem occured after trying to install an update?
Try doing a hard reset on the Garmin
First remove the faceplate from the Garmin C330. To accomplish this there is a small indentation under the word Garmin where you can get a finger nail in and pop the faceplate off. On the right side of the unit is a reset button.
Posted on Dec 31, 2007
  • audiqv8 Jan 10, 2008
    Go to setting, then Map, then Mapinfo. Verify that Mapsource is loaded. You should see something similar to the following..
I have lost all my maps on my garmin nuvi 255W-
Do a hard reset on your GPS. Download and install Garmin Express from Garmin. Plug your GPS into your computer. The software will identify your GPS and allow you to download new maps to it.
Mar 19, 2017 | Garmin Nuvi 200 205 250 255 260 W
All of a sudden my garmin 3790LMT shows "no map data available" how to fix?
Is the SD card containing the map (and update) inside the Garmin device yet ?
Sep 16, 2016 | Garmin Nuvi 3790 LMT GPS
Earlier today i updated my garmin 880, and now i can't search for anything. "no map data available" continues to pop up every time i try to enter anything... also only major highways/interstates...
It's most likely that the map is either not selected or locked. You can find the solutions to these problems at
Try starting at paragraph 5 of the above link, selecting maps. If that doesn't solve the problem the map is probably locked so go back to paragraph 2.
Apr 12, 2011 | Garmin nuvi 880 Car GPS Receiver
Garmin nuvi 1100 gps. Screen says no map data. Is there a default setting?
The map may have become unselected.
Press TOOLS, the spanner symbol on the page that shows WHERE TO and VIEW MAP
Press SETTINGS or LOCALE on some models
Press MAPS and then at the bottom of the screen press MAP INFO
Your map name should be displayed. THere should be a tick beside it. If there's no tick press the map name and it will tick. The map is now selected and should work ok.
Feb 27, 2011 | Garmin GPS
No data available and no maps downloaded
it may just be that the maps are deselected. to correct this go into the tools/settings/map and then at the bottom of the screen in the middle you will see map info tap that and then at the next screen it will show you the maps which are installed if there are any without ticks just tap the box. tap ok and try again if. if there are no map choices then you will need to reinstall the maps on your unit
Apr 26, 2010 | Garmin nuvi 780 GPS
Maps on SD card not recognized by Garmin C330 GPS
I dont thinki the 330 handles 4Gb SD cards I think 2Gb is the maximum that is why it isd taking so long and runds out of space so cannot properly load the maps.
Jul 22, 2009 | Garmin StreetPilot C330 GPS Receiver
Maps don't show after downloading upgrade.
sounds like you might not have the new map set selected
settings -> map -> map info (make sure the NT 2009 map is checked)
Mar 17, 2009 | Garmin nuvi 350 GPS Receiver
Cannot find my map data anymore
Have you checked the wrench menu, map info, the preinstalled map should have a check mark, if not tap on the check box, it should now show a detailed map screen when you go back to the main menu and select show map.
May 03, 2008 | Garmin nuvi 350 GPS Receiver
Garmin c330 no map data available
Did you try to perform a map upgrade to 2008? Turn on the Garmin and from the main menu touch the wrench,
then press Map, then look for Map info.
This will show the the current map version installed
Jan 12, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
366 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
