No power to speaker and it keeps blowing 2 internal fuses
  • Larry Stiles
    Larry Stiles May 11, 2010
    I would need more info on make and model ,but it sounds like you could have shorted a shorted output circuit. Does it blow fuses even when the speakers are disconnected?
    Scholar:
  • 113 Answers
Hiya Unfortunately thats a sign of the outputs faulty or maybe power supply. It will have to go to someone with experience to repair. Sorry bout that...
Posted on Jul 16, 2009
My 2006 dodge ram 2500 diesel keeps blowing fuse
The Internal light is normally tied to your dash lights on a factory installed radio. Find the main p[lug on the back of the radio and unplug it then try it with a new fuse if it still blows then it is the wiring if it does not blow the fuse when the radio is unplugged, chances are the radio is bad and will have to be repaired or replaced.
Sep 16, 2014 | 2006 Dodge Ram 2500
WHY DOES MY ACOUSTIC RESEARCH AR3 TOWER SPEAKER BLOWS INTERNAL FUSE..FIX?
Check to see who the manufacturer is. The Acoustic Research name was sold a couple of times. I think yours may be Recoton. If so, you may be able to get some help from them.
Aug 24, 2014 | Audio Players & Recorders
Why does the fuse keep blowing?
Hmmmmm. Are we talking about your internal or external fuses; Do they blow at the moment you put power on it, and what about the switch of the used voltage ?.... And was it straight away , since when you bought them; Then just send them back, Second hand?, too bad, you're ripped off .
Jul 21, 2014 | Behringer Eurolive B212d-wh Active...
Fuse keeps blowing up as power is turned on..help.
Greg, If the fuse keeps on blowing there is a problem with the internal amp. It was probaly caused buy a electrical power surge, Or a (********) up Sub patch cord,
Oct 04, 2012 | Athena AS-P4000 Subwoofer
M audio bx8 blows a fuse
best solution wrap the blown fuse with a piece of tin foil and put it back into the fuse terminal and you shouldn't have a problem.
Mar 03, 2012 | M-Audio Studiophile BX8 Main / Stereo...
When right channel is wired it shorts out the power supply. Aragon 8008 when powered up without input and output, no problem. When connected with speakers and line level feed in, the left channel works...
Fuses blow when there is an overload caused by a short circuit. If the speaker you connect up to the amp causes a short. There is either a shorted part in the speaker or the wires to it are touching at some point. Assuming you can sort out the speaker issue and connecting a good speaker with good wiring and it still causes a short and blows a fuse. Then it's likely the output device(s) in the right channel have developed a short themselves. Perhaps as a result of being connected to faulty wiring or speakers.
Jul 18, 2017 | Aragon 8008 MK II 2-Channel Amplifier
My eclipse 33250 premium amp keeps blowing fuses when I then it on
If you have wires connected to it may be connected improperly. Check power and ground connections if they are connected properly then disconnect all RCA cables and re turn on amp if fuses blow then an internal problem exist and you must send it in for repair.
Oct 10, 2010 | Car Audio & Video
What do you do when your amp keeps blowing fuses
First off which fuse is it? The inline fuse from the battery or the amplifiers power supply fuse? Blowing the main fuse from the battery is caused by either the load (your amp) drawing too much current or you have a short to ground somewhere. Maybe there is a tear in the 12Vdc line and it is shorting to the chassis of your car. If the amps power supply fuse is blowing as soon as it turns on your amp has a shorted power supply. This will require internal component changes by a technician. If it is blowing after operation at high volumes I would say change the impedance that the amp is driving. If you are at 2 ohm try to rewire your speakers for four ohm. (go from parallel to series wiring then bridge mono or operate the amp in stereo mode)
Feb 07, 2010 | Infinity Reference 1300a Car Audio...
I have a dual XIA3145 580 watt amp that keeps blowing fuses
Generally, this indicates that there's at least one shorted output transistor.
Disconnect all speaker wires from the 'amplifier's speaker terminals' and disconnect RCA/signal cables from the amp. If it powers up normally, the speakers/wiring need to be checked. If it still blows the fuses, the amp almost certainly has shorted output transistors and will need to be repaired.
I'd recommend using two 10 amp fuses. The amp will power up with 10 amp fuses if there is no problem. If there is a problem, there's less of a chance of doing more damage by using the 10 amp fuses.
Let me know if you have any other questions.
babin_perry@yahoo.com
Sep 04, 2009 | Dual Electronics illumiNITE XIA3145 Car...
Have a kenwood kac849 600w amp keep blowing fuse on amp as soon as power is too it power wire got wet and now this can i bypass that fuse some how
It would be very dangerous to bypass a fuse. If it keeps blowing, bypassing the fuse will only create lots of internal damage and maybe a fire as well. The fuse is blowing for a reason, the amplifier is not going to somehow start working because you bypassed the fuse. You also need to stop trying to turn it on, every time it blows the fuse, it keeps stressing the components inside. You have a shorted power supply, probably water damage as well since the power wire got wet.
I repair car amplifiers for a living, and can tell you with all honesty that bypassing the fuse would be a terrible mistake to make, the amplifier would end up being un-fixable with holes burned right into the board.
Please, just take it in for service or get a new amplifier. That is the only sensible thing to do. The amp will not start working bypassing the fuse, it will only start smoking.
Jul 10, 2008 | Kenwood Car Audio & Video
233 people viewed this question
 Grubhead
Grubhead
