Question about Sony Video Game Consoles & Games
My psp2006 ver5.03 cant read games
My psp2006 ver5.00 .I bought it from Singapour.It was already modified. When i upgrade it to ver5.03 i can't get access to my game. . I have tried chickhenR2 ,PSPgen A ,but still it does not work.Please can anyone help me
    Problem Solver:
  • 13 Answers
PSP UMD Repair: Not reading UMD discs
I have seen many PSP's stop reading UMD discs and for the most part they are repairable with the least amount of opening your PSP.
First we will do some trouble shooting with what might be wrong with your PSP unit.
About 35% of the time I find that there is something stuck in the UMD gear. It is different every time, sometimes its a piece of dust, plastic, soda, and even hair.
Another 25% is the Disc Spinning motor. This will not let The disc in the UMD spin.
About 20% is the Laser motor, this might be hard to spot since it could be something in the gears.
About 10% is the actual laser itself. It will not focus the laser to read the UMD disc.
The Last 10% is the Motherboard. This is the worst outcome, since there is very little what we can do but replace the motherboard.
So first what we need to do is find out what is actually wrong with your PSP.
With your PSP in hand.
Turn on your PSP and remove any UMD that might be in there now.
If you open up the UMD door and look down inside you will see the Laser assembly.
If you look to the left there is a black tab that sticks up, this tells the PSP that there is a UMD in the drive.
If you press this down with a small probe, you should see the disc motor spin and the laser light up red
*** CAUTION DO NOT STARE DIRECTLY AT THE LASER ***
If the Motor is not spinning. is it moving slightly? Maybe a little twitch?
I would lean more towards the bad motor problem BUT would not say for sure, I would recommend that you take the parts out and see if there is another problem also.
If the laser is not lighting up then it could be the laser, I would try and check the cables to the PSP and see if there is a bad connection.
If both are running well then lets put a disc in and get your ear up close so you can hear what is going on in there.
On a working PSP you will hear the disc start to spin up, then you can hear the laser start to twitch, followed by the laser motor moving the laser down the rails.
Can you hear the disc spin up? If not I would take the disc out again and press the switch with your probe again. if the disc motor is spinning again, look around to see if the metal housing is obstructing the disc when you put it in.. there could be to much pressure for the disc to spin freely.
Can you hear the Laser focus? This might be hard to hear it will sound like a little tick. If you cant hear it tick I would move on and inspect this internally later.
Can you hear the Laser move down the rail? This will be a smooth sound of the gears, it should not be a really clicky sound.
If you can't hear it move down the track OR it is very clicky follow this.
It would look like this if your UMD door was off.
You should open the UMD door and carefully manually move the laser to the right side of the assembly.
Use a sharp THIN probe to manually move the WHITE gear under the metal housing. It is quite hard to see it in the photos so I put a red star around it.
I usually try and scrape the gears themselves to make sure there is no gunk or debris in the gear.
After this try and see if it is reading UMD again.
This fixes it about 35% of the time.
If none of this is working, it is time to open your PSP unit Or send it in for repair.
If you know what's wrong you can replace the problem here
Replace UMD Assembly
Replace UMD Disc Motor
Replace UMD Laser Motor
Replace PSP Motherboard
All photos and content copyright © Llamma Corp. 2002-2006
http://www.llamma.com/PSP/repair/PSP_UMD_Not_Reading_Discs.htm
Posted on Jul 19, 2009
XBOX HAS 3151335AB8000F00C0000034 ERROR STUCK ON THAT SCREEN IT SAYS REINSERT DISC AND IT FAILS CANT GET OUT OF UPDATE SCREE
normally that error happens when system have been modified with custom firmware.
If your system is modified then you must upgrade to the latest firmware in order to bypass the update loop.
if your system is not modified then you need to update your system manually by going to www.xbox.com/support and download the latest update and update it through a USB.
Thanks
www.1RepairStop.com
Aug 31, 2011 | Microsoft Xbox 360 Console
I Upgrade my PSP 3004 to Firmware 6.38 i cant able to play crack games how to modify... please Help me also i cant able to download grade to 6.35 help me to custome firmware 6.38 to play all crack game...
Hi!
No, the 6.38 Firmware update patched all of the exploits and if you upgraded you will no longer be able to hack it or play "cracked" games. They also patched the ability to be able to revert to a former version (6.37 or lower). So, unfortunately, you're stuck. Sorry.
May 11, 2011 | Video Game Consoles & Games
How can i modified psp3004??
unless the firmware version is 5.00 or 5.03, you cant. If it is 5.00, upgrade to 5.03. Then use chickHEN to get it modified.
Feb 01, 2010 | Sony PSP (Piano Black)
My psp doesnt read the games inside my memory card
1. Does your PSP have a customized firmware (CFW) already?
2. If you just bought a new PSP, definitely it can not read the games inside the memory stick. You need to upgrade the original firmware of your PSP into customized firmware CFW.
Jan 21, 2010 | Sony PlayStation Portable (PSP) Console
My psp2006 version 4.01 needs upgrading to 5.33, please help
well just download the official firmware from sony or just mod it wit a panodras battery and files
Oct 28, 2009 | Sony PlayStation Portable (PSP) Slim...
My PS2 won't load God of War 1 or 2 anymore
if it is a double layered game (backup...u need to burn it with layerbreak set on auto and on DAO if that don't work try incremental instead.
Also...if your system is modified with a chip...try and get a MArs pro chip instead...not modbo or matrix infinity....those chips have a hard time reading GOW
if your system isn't modified...try changing the laser...it could be getting weak
Jun 21, 2009 | Sony PlayStation 2 (PS2) Console
My psp does not want to read games
Jun 15, 2009 | Sony PlayStation Portable (PSP) Console
Ps2 not reading game cd
sometimes when you have a console from a different country it wont read the disk.
Sep 25, 2008 | Sony PlayStation 2 (PS2) Console
AFTER UPGRADE MY PSP CANT READ ISO FILES SO I CANT PLAY ANY GAMES
your ISO Games....
Presumably these are 'backup' of yours or others games ??
Do you have 'any' level of homebrew installed to be able to read your ISOs ??
If this is the case - you will need to revert back to the original firmware. . . if you need more detail, please comment.
Aug 16, 2008 | Sony PlayStation Portable (PSP) Console
Video Game Consoles & Games Logo
222 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
