Question about Karcher 2500 PSI Pressure Washer
Broken cam pulley
I have a broken cam pulley on a gc160 motor . i need to know how to replace it and set the timing if necessary.any how to diagrams would be very helpful
2 Suggested Answers
SOURCE: Honda GC160 5HP engine
Broken timing Gear.
What would cause this,
Posted on Aug 27, 2011
I am changing the oil pump on a ford fiesta TdCI and I need to know the cam belt timing marks or a diagram on the cam belt
Set the crank to 0 degrees according to the timing marks on the damper, look on the cam pulley for a mark and line it up with the mark on the head. Put the belt on WITHOUT moving the cam or the crank.
Jan 27, 2017 | Ford Cars & Trucks
2005 CHRYSLER TOWN AND COUNTRY CYLINDER HEAD REMOVAL
Nope. You are not removing the timing chain or moving anything related to the timing so it is not necessary to have the engine set to TDC. coincidently I just pulled off a set of heads on a caravan 3.3 liter yesterday at work. I had both off in about an hour and a half. Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
Feb 25, 2012 | Chrysler Town & Country Cars & Trucks
HOW TO SET TIMING ON 96 TOYOTA CAMRY 2200 MOTOR
Click on the following free direct Link. It has the Timing: Pulley, Belt and Mark Diagrams for your 1996 Toyota Camry. Plus additional Instructional and Directional Diagrams.
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/1996/make/toyota/model/camry/1996_toyota_camry_timing_belt_diagram_marks.htm
Mar 28, 2010 | 1996 Toyota Camry
Timing marks on 1999 Ford Ranger 2.5L.
Rotate the engine so that No. 1 cylinder is at TDC on the compression stroke. Check that the timing marks are aligned on the camshaft and crankshaft pulleys. An access plug is provided in the cam belt cover so that the camshaft timing can be checked without removal of the cover or any other parts. Set the crankshaft to TDC by aligning the timing mark on the crank pulley with the TDC mark on the belt cover. Look through the access hole in the belt cover to make sure that the timing mark on the cam drive sprocket is lined up with the pointer on the inner belt cover.
  1. Loosen the alternator retaining bolts and remove the drive belt from the pulleys. Remove the water pump pulley.
  2. Loosen and position the power steering pump mounting bracket and position it aside.
  3. Remove the four timing belt outer cover retaining bolts and remove the cover. Remove the crankshaft pulley and belt guide.
  4. Loosen the belt tensioner pulley assembly, then position a camshaft belt adjuster tool (T74P-6254-A or equivalent) on the tension spring rollpin and retract the belt tensioner away from the timing belt. Tighten the adjustment bolt to lock the tensioner in the retracted position.
  5. Remove the timing belt.
To install:
  1. Install the new belt over the crankshaft sprocket and then counterclockwise over the auxiliary and camshaft sprockets, making sure the lugs on the belt properly engage the sprocket teeth on the pulleys. Be careful not to rotate the pulleys when installing the belt.
  2. Release the timing belt tensioner pulley, allowing the tensioner to take up the belt slack. If the spring does not have enough tension to move the roller against the belt (belt hangs loose), it might be necessary to manually push the roller against the belt and tighten the bolt.
The spring cannot be used to set belt tension; a wrench must be used on the tensioner assembly.
  1. Rotate the crankshaft two complete turns by hand (in the normal direction of rotation) to remove the slack from the belt, then tighten the tensioner adjustment and pivot bolts to specifications. Refer to the necessary illustrations. Make sure the belt is seated properly on the pulleys and that the timing marks are still in alignment when No. 1 cylinder is again at TDC/compression.
  2. Install the crankshaft pulley and belt guide.
  3. Install the timing belt cover.
  4. Install the water pump pulley and fan blades. Install upper radiator hose if necessary. Refill the cooling system.
  5. Position the alternator and drive belts, then adjust and tighten it to specifications.
  6. Start the engine and check the ignition timing. Adjust the timing, if necessary.
Nov 25, 2009 | 1999 Ford Ranger SuperCab
I need a diagram for a timing belt for 1994 ford ranger 4cyl. 2.3L. A free Haynes manual would be great, but all my searches don't come up with an answer, Possibly a pdf manual or something. This has put...
Hi:
If you go to the online Autozone.com, and look up trying to buy a timing belt, for your truck, they offer a simple how to guide to install it. It is free for most jobs. If you want the full deal, for less than $20 you can get a one year subscription to your truck from WWW.alldatadiy.com It is money well spent if you need help.
Nov 10, 2009 | 1994 Ford Ranger Supercab
Replaced water pump and now i need to know how to reset timing
I hop you are replacing the belt and tensioner/ idler pulleys. the crank pulley has a notch approx 12'oclock. the cams will be marked rear cam "I" and front cam "E" .. put both letters at 12 o clock. there should be a notch at the top of the cover for the cams at 12 o clock. thats all there is to it. to tension the belt, after you have it all timed up. put some tension on it, tighten tensioner bolt, turn the engine 2 revolutions, then double check your marks, push down with you thumb between the cam sprokets with 20 lbs of force, the belt should delfect about 10MM if its too loose, loosen the tensione rbolt an dturn it tighter a little more an dck tension again. If you get it too tight it will whine and wear the cam journals, too loose and timing will not be correct.
Sep 18, 2009 | 2001 Kia Sephia
Opel Corsa timing belt replacement
You need to find the timing marks on both crank and cam pulleys, set it, then take of the belt ane dont let any pulley move! Put on new belt and set the tension of the belt.
Jul 31, 2009 | 2000 Acura Integra
1989 Isuzu pickup how to align timing marks on cam and crank?
The Isuzu is a strange animal-when you do the timing belt you set it with #1 TDC "BUT" the distributor is timed with TDC #4 I found this the hard way and finally had to buy a cd with the procedures on it. Send me an e-mail address and I will forward the associated pictures &
info to you.
Jim Young
jmysr@hotmail.com
TIMING BELT & SPROCKETS R & I
NOTE: Some procedures may differ slightly due to engine
construction.
Removal
1) Remove all necessary air ducts. Position No. 4 piston at
TDC of compression stroke. Align timing marks. See Fig. 2. Remove fan
and fan shroud. Remove belts. If necessary, remove radiator and
splashguard.
2) Prevent engine from rotating and remove crankshaft timing
pulley retaining bolt. Remove upper and lower timing belt covers.
Remove spring from tension pulley. Loosen adjusting bolt and move
pulley toward water pump. Remove timing belt.
CAUTION: Ensure pistons are at TDC when rotating camshaft or damage
may result.
Inspection
1) Handle timing belt carefully. Avoid twisting or kinking
belt. Do not allow belt to become contaminated by water, oil, dirt or
other contaminates. Inspect belt for cracks or damage. If necessary,
replace.
2) Measure tension pulley spring length and force. Spring
length should not exceed 2.76" (70.2 mm) and spring force should not
be less than 197-347 lbs. (27-48 kg).
3) Replace tension pulley spring if not within specification.
Installation
1) Pull tensioner fully toward water pump side and
temporarily tighten retaining bolt. Ensure No. 4 cylinder is at TDC on
compression stroke by rotating crankshaft until keyway aligns with
mark on front crankshaft seal housing (12 o’clock). Rotate camshaft
until timing mark on cam gear (arrow) aligns with mark on upper
camshaft cover (notch). See Fig. 2.
NOTE: When timing marks are aligned as stated above, No. 4 piston
is at TDC on compression stroke.
2) Position timing belt over crankshaft sprocket, oil pump
sprocket, camshaft sprocket and tensioner in that order. Ensure belt
is positioned in sequence given and without slack between sprockets.
Loosen tension sprocket adjusting bolt allowing spring tension to
tighten belt. Tighten adjusting bolt temporarily.
3) Temporarily install crankshaft pulley bolt and rotate
crankshaft 2 complete revolutions in opposite direction of engine
rotation, until marks on crankshaft and front oil seal retainer are
aligned again. See Fig. 2. Loosen tensioner lock bolt, allowing
tesioner spring to fully adjust tension. Tighten tensioner lock bolt.
4) Install timing belt covers. To complete installation,
reverse removal procedures. Tighten all bolts to specification. See
TORQUE SPECIFICATIONS table at end of this article.
Fig. 2: 2.3L & 2.6L Timing Alignment Marks
Courtesy of Isuzu Motor Co.
Jun 05, 2009 | 1989 Isuzu Pickup 2WD
Mazda b 2500 how to set timing when the timing belt has broken in
My sincere apologies for the delayed response.
I am personally going back to answer your unanswered questions.
I do not know if you still need this information, but I am going ahead and answering it anyway. You may want to Print the Diagrams for future use.
CLICK
on the following LINK. It has the Timing Belt and Mark(s) Diagrams you will need.
If you would: Before Clicking: Let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
Again my apologies...
http://www.2carpros.com/car_repair_information/year/1998/make/mazda/model/b2500/1998_mazda_b2500_timing_belt_diagram_marks.htm
Apr 19, 2009 | 1998 Mazda B-Series
Karcher 2500 PSI Pressure Washer Logo
278 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
