Vizio E701I-A3 70-inch LED-backlit LCD TV - Smart TV - 1920 x 1080 - 1 Logo
brian daniels Posted on Mar 02, 2016
My vizio E701I-A3 led tv screen is black how do i fix it
5 Related Answers
gopakumarg43
  • 76851 Answers
  • Posted on Apr 24, 2015
SOURCE: I HAVE VIZIO 70 MODEL E701i-A3 TV WAS ON SCREEN WENT BLACK I PRESS A BUTTON ON THE REMOTE AND THE SOUND WENT OFF. AFTER THAT THE TV WOULD NOT RESPOND AT ALL.
Try a hard reset to this set, and check. If it do not help you, contact any service technician.
There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
steveo367421
Steven Brandon
  • 462 Answers
  • Posted on Jul 05, 2016
SOURCE: Vizio E701i-A3 no audio or video have backlighting; should I replace all 3 boards or just main board
Just the main board
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
AJIN G
Electro Med Services
  • 6694 Answers
  • Posted on Jul 10, 2016
SOURCE: I have a Vizio 70" led model E701i-A3E it started getting white spots then it just went black has sound but no picture. What parts do I need to buy to replace to fix this do I buy all three boards
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
http://electro-medical.blogspot.com/
Lawrence Oravetz
  • 10558 Answers
  • Posted on Sep 06, 2016
SOURCE: I have a Vizio E701i-A3 Edge lit LED TV. I looks like an 8 inch strip of the LED edge lights along the bottom are not working. Do I need to replace the light or the T-con?
It could be the ballast for that section of leds. Led failure is rare but possible.
shaun hancock
  • 167 Answers
  • Posted on Oct 15, 2016
SOURCE: I have a Vizio E701i-a3. Sound with no picture. What's my trouble
Have you checked the "Mute" button?
The backlight on my Vizio E601i-A3 is not coming on. How can I tell whether it is the power board or the LEDs themselves?
Vizio had a recall on this model TV resulting from the issue your having, below is a link to the recall. What they said was recently Vizio put up a special bulletin on its website stating a number of its 60-inch E601i-A3 and 70-inch E701i-A3 HDTVs may lose the picture (but maintain audio) due to a bad "chip assembly". The "chip assembly" is actually in the main board, Ive fixed a number of this model TV's by replacing the main however Ive also seen the lamps fail as well so its kind of a guessing game as far as where the issue is at unless you have some high end test gear to troubleshoot the set.
Vizio Issues Recall On Large Screen LED LCD HDTVs
I have one vizio e701i-a3 with black screen but with audio. I change the t con board and the main board. But the problem continue. I need help please
Sounds like display panel fault. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
My TV has blacked out I have nothing, no sound,no screen, no light from the TV, my cable box is lit, along with my amp box I checked all the wires what is that I need to do now?
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen - Troubleshooting ... LG LCD TV REPAIR - NO ...
How to fix vizio black screen - YouTube
? 1:05
https://www.youtube.com/watch?v=Qw1yOtt_KAo
Dec 22, 2011 - Uploaded by jay saw
Mine keeps saying not support for my 360 with an hdmi but it was just ... Must have been one of those... alternate reality things. We click on a video "how to fix vizio blackout" and get a video of ... Trina Foster In EASY How To REPAIR Black/ Blank Screen LCD HD TV Main Board Repair Replace Vizio ...
Vizio 70" E701I-A3 - Picture went out like *snap* th
When my TV have no logo when i turn it on. I changed the power board and the main board already. The problem still there. I bought a bad main board? Or I need to change my T con board too?
T con board responsible for final picture on screen of set. And visible distortions are caused by it. The inverter board powers the back lighting so you can see the picture. If screen is totally black that could be the issue.
How to fix my led screen, it has no picture i have purchase and replace the led driver.
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Command voltage to switch ON the LED driver section, should come from the main board's system control section. It do not come now.
2answers
Vizio e701i-a3 has sound but no picture?
plz first tell us that backlight is in working condition or not
Vizier 70" TV issues
MY VIZIO E701i-A3 has sound but no video /back light on /screen only show dark blue sreen please tell me if it repairable or not?
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
