Question about IO Magic Corporation GigaBank (I250HD35) 250 GB USB 2.0 Hard Drive
I/O Magic Hard drive- blue logo light blinking and drive not work
I had left the I/O Magic on for a long time and I decided to rearrange my plugs so I could turn everything off at night with one switch. It had been in a power strip I did not turn off before. Now it blinks and I tried to let it sit and warm up but then the light turns itself off (after an hour or two). I'm just wondering from this post is the best solution to #1 buy another power cable and try to get it to work, at least long enough to get the stuff all backed up, OR #2 should I skip that step and just remove it from the casing, install it inside my computer and then run a check on it? I'm a little worried of #2 choice because it seems like after that there is no going back and using the external hd as a back up
  • sameermadhu Jul 16, 2009
    The computer is not recognizing it and the blue logo keeps blinking. I do not know what to do.
    I tried that. Every time the blue logoi light blinks, I hear a tick in the power box.
  • 285 Answers
Hi there...
So the computer is not recognising it as a hard drive again? It sounds like it is getting power, but just not be recognized by the computer. Please confirm.
Posted on Jul 16, 2009
  • Dean
    Dean Jul 16, 2009
    Ok try this, plug the drive in to the power outlet (directly in this time) and put your ear to the power box on the cord, listen carefully and note any sounds when the light on the drive is blinking. It is probably actually most likely to be the power cord at fault.
  • Dean
    Dean Jul 16, 2009
    Ok if you are hearing ticking in the power box then it is most likely that your power cord has failed and you need a new one. This seems to have happened to a few others with the same drive. Grab a new power cord and be sure to use it in conjunction with a surge protector or surge protected outlet.
    Please rate this solution on FixYa!
I have a SimpleTech 500 GB external hard drive (Model 96300-41001-013). It has been working fine for the past 2 years and all of a sudden when I turn it on, the blue light around the logo on top blinks...
Listen closely to the drive, if it sounds like it is clicking then it is probably not getting enough power through the usb. You should have received a cable with a split dual USB plug for extra power. Make sure that both large USB plugs are in the computer while the smaller one is attached to the drive, this will give it enough power to start working. If it is not clicking and has plenty of power then it could be that it is mapped to a drive letter that is already in use. Under device manager, (right click my computer and select manage then click on disk management) If you see the device in there then you can right click on the bar graph representation of the disk and select to change drive letter and paths. This will allow you to remove the conflict and have it show up again.
Aug 20, 2013 | SimpleTech 250GB USB2.0 7200 RPM External...
Red light on, but PC does not detect it
Remove the drive from the case and fit it to a new case. The interface in the old case has failed.
Jul 08, 2013 | Computers & Internet
Computer is not recognizing my external hard drive
If the light won't blink, there could be problem with the power source. Do scanning hardisk for errors manually ( take off the hardisk from the case, assemble it on other PC Desktop)
May 06, 2010 | IO Magic Corporation GigaBank (I250HD35)...
Not recognizing external harddrive in "my computer". I/O magic blue light continually flashes blue instead of staying solid light
There are a few possibilities, the fact the light is blinking generally means the power adapter is fine.
The options left are a faulty driver in your PC, a failed circuit board in the enclosure or a failed circuit in the drive itself.
First try the drive on a different PC and see if it works. If it does reply back and we can look into the failed driver. If it doesn't then take it to your local PC shop and have the technicians move the hard drive into a new enclosure.
If it works in the new enclosure buy the enclosure and your on the way. If it doesn't, then the hard drive itself is the problem. If that is the case you will need the help of a data recovery pro to retrieve your data. If this is the case reply with your location(Country, State and City) and I will assist you in finding a reputable pro to assist you.
Hope this helps FixYa,
Chris
Oct 26, 2009 | IO Magic Corporation GigaBank (I250HD35)...
Steady blue light, blinking lights doesn't heat up
I read in another posted solution about a magnet in the grey float that is in the water reservoir. I removed the grey float and rubbed on the front of the unit by the steady blue light and it apparently resets the sensor. Presto Magic! it worked! Machine back to normal and operating perfectly.
Jun 13, 2009 | Saeco Starbucks Sirena Espresso Machine
My 500 gig io magic doesnt respond any way it can be fixed?
Is the blue light blinking? I had the same thing occur to my I/O Magic 250 GB USB drive a couple of days ago. I did an online chat with I/O Magic tech support and the guy said you can RMA (return) it if it's in warrantee, but otherwise too bad. Mine is out of warrantee. Since the enclosure contains an ordinary hard drive inside, just carefully peel off the little metal plate at the back of the unit, undo the two screws and slide out the drive. The are two plugs and four screws to free the drive. To get your data back once you've got the drive out, you've got three choices: buy a new enclosure ($20+), buy a toaster ($50) (it's like an enclusre, but you just pop a drive into the top, like bread into a toaster), or open up your computer and connect the drive directly as any other. Oh and don't buy another I/O Magic product again.
Dec 28, 2008 | IO Magic Corporation GigaBank (I250HD35)...
Blinking blue light
the only blue light that i know blinks is the Kmart blue light special .. we need model of things you're working with to properly diagnose.
is it external drive ? with a blue light blinking ? is it connected in usb ? sounds like if its external drive with blinking light could be bad hard disk or bad controller card inside that translates ide to usb.
Jul 29, 2008 | Computers & Internet
IO Magic 250gig external hard drive
Unfortunately the hard drive within the external case has died. The clicking noise you can hear is the read / write heads trying to find anything on the platter and failing, this means that any files that were on the drive are lost. There are many tricks on the net that give hope of recovering data off a dead hard drive but most just corrupt the data completely. If you have files that you must have and can afford the extremely high price for data recovery there are services available through most hard drive manufactures, most notably through Seagate.
May 07, 2008 | IO Magic Corporation GigaBank (I250HD35)...
Drive not being recognized; blue logo blinking
I have an I/O Magic 320GB drive. It's easily taken apart by gently removing the silver-colored aluminum sticky plate (by the power switch, USB, etc). Then you remove the two screws and remove the black plate. After that you can push out the entire drive harness and remove the screws and connectors to take the hard drive out. It's easily swapped for a different HDD, and the drive is easily placed as an IDE internal drive. If you hook it directly to your computer you can run diagnostics on it and perhaps data recovery software like "Recuva". Most external drives are pre-formatted as FAT32, single partitions but can be reformatted to any other format.
Oct 28, 2007 | IO Magic Corporation GigaBank (I250HD35)...
IO Magic Corporation GigaBank  (I250HD35) 250 GB USB 2.0 Hard Drive Logo
74 people viewed this question
Top IO Magic Corporation Computers & Internet Experts
Mohamed Ismail
Mohamed Ismail
Falling star
M_Butkus
Are you an IO Magic Corporation Computer and Internet Expert? Answer questions, earn points and help others
