Question about GE Refrigerators
Freezer won't stay cold. it remains at about 10 deg, not 0 deg like it is set for. fridge seems to be warmer than set point also, but not as extreme. GE model PDW22SISRSS.
  • GE Master
  • 4,654 Answers
Three possible reasons, you have a main control board inside the fresh food section that may be defective. It's hiding behind the controls, then the defrost heater and defrost thermostat inside the freezer. I think I found the board replacement. we just need to look at the board with power unplugged to fridge. We will go from there if you need my help please double check the model number. I found 2 similar numbers but not yours. I will walk you through this if you want, let me know, Thanks Sea Breeze
Posted on Jul 16, 2009
  • 2 more comments
  • John Tripp
    John Tripp Jul 16, 2009
    Here are my sites and email below.
    http://servicepartstec.blogspot.com/
    http://appliancepartseast.blogspot.com/
    appliancepartsse@yahoo.co
    you may need to contact me because Fixya has problems sending your response to notify me that you made a comment, Sea Breeze
  • John Tripp
  • John Tripp
    John Tripp Jul 19, 2009
    zstelly I did a bit more digging and found that the compressor was smoking hot! It appears that the fan that cools the coils is not working. I set up a small house fan blowing over the coils and the fridge and freezer temps seem to be right on the money, 37 and 0 degs. I was able to get the fan out thinking it would be 110v and easy to test, but it is a 12v DC motor so I have no way to test it. Also I am a bit confudsed because the fan has 4 leads. As far as the model number goes it is PDW22SISR SS. My wife just read it to me from the fridge. The funy thing is that the model number is on a small sticker, covering another "model" number. It almost looks like they printed the lable with the wrong model number and had to put a correction sticker over it. anyway, the number under the sticker is PDS22SISR SS. I hope this helps. Thanks again
    Sea Breeze That fan motor is quite expensive everywhere. Can you set you meter on DC voltage and check the wires for 12 volts to make sure it's not a relay somewhere bad. The part number for the motor is
    WR84X10055 http://servicepartstec.blogspot.com/
    Send me the Name Brand of that model number so I can look over some prints. Sea Breeze
  • John Tripp
    zstelly Should the fan run when the compressor is running? or is it triggered by a temp sensor?
    Thanks
    Sea Breeze
    On most simple designed refrigerators they run while the compressor and freezer fan runs. But on refrigerators with a mother board the usually have a temperature sensor that stops and starts the fan depending on the temperature of the condenser. A mother board controls almost all functions on the newer style refrigerators.. They cost more to replace but the save you money over time by controlling defrost time and even knows how many times the door was opened during the day.. I will need to look your model up to see exactly what you have.
    I am pretty sure the PS22 falls in the category of the Artica/Profile If you question the board being good you can unplug and examine both sides of your boards for burn marks or signs of heat or loose solder.
    Here is one possibly similar to yours in 2002 http://www.fixya.com/support/t230703-ge_...
    Have a look at this PDF of the Profile/Artica service manual. I realize it may be a little different but the boards and wiring may be close enough to go by. Sea breeze Trying to get the manual for the PDS22SISRSS may be very difficult because GE don't like to let their manuals out.
    http://appliancejunk.com/ge/refrigerator...
    zstelly I just got my hands on a volt meter and checked the power leads to the condenser fan. I am reading 13.5v when metering across white/red and white/purple.. It seems like it is a bad fan, right?
    Thanks
    Sea Breeze Yes, now check the resistance in the two pin plug connections that go to fan. In The PDF it said something about checking the fan condenser motor around page 46.
    zstelly I ran through the diagnostics on page 49 and ended up at the "repair wiring harness" box. I tested the harness with an Ohm meter and it and everything was good. So I did a bit more probing. 13.5v on pins 3-5 and 3-8. 13.5v at motor. When testing resistance across red and white on the J2 connector, I was only reading 1kOhm. Any ideas?
    Sea Breeze I believe now that you have gone this far you need to unplug the refrigerator and examine both sides of the board for burn marks. Without me pulling up the PDF again what did it tell you the ohm's should be?
    See if you can set your ohm meter to a more sensitive setting and try. And the resistance on the fan motor across the 2 pin plug locations you tested the power from is what? If you plug the fan up to a 12 volt battery like your car will it run?
My ge profile pfs22sbsss model french door freezer drawer was left open overnight and now won't get cold. Any ideas?
THE FREEZER HAS FROZEN PAST THE POINT OF DEFROST;TURN FRIDGE OFF AND MANUALLY DEFROST ALL THE ICE IN THE FREEZER SECTION AND ALL AIRWAYS TO FRIDGE SECTION.
May 10, 2014 | Refrigerators
Refrigerator (Samsung RS2555SL) quit cooling on both sides. Front panel was blinking at set temperatures (34 fridge side/0 freezer side) but inside was warm. I unplugged for 5 min and ran self-diagnostic...
hello dont know if you have the same model
but this may be worht a look
samsung fridge freezer problems
http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01"> name="allowFullScreen" value="true">http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344">
Sep 28, 2010 | Samsung RS2578BB Side by Side Refrigerator
We just bought a Frigidaire Gallery Refrigerator and are not sure what temperatures to set the freezer and fridge to.
The freezer should be between -5 to +5 deg.F. The refrigerator should be from 33 to 40 deg. F. but it is really a matter of preference. I set mine around 5 and 33. I like to get my ice cream out and be able to scoop it and I like my milk very cold. Start with the manufacture suggested and then adjust from there with your own preference.
Dec 13, 2009 | Frigidaire Refrigerators
Gladiator fridge/freezer-freezer not cold enough, stays at 10 deg
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Dec 12, 2009 | Whirlpool 19.6 cu. ft. Upright Freezer...
2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
Mar 17, 2017 | GE Refrigerators
The fridge is cold but the freezer won't freeze
It has seperate cooling circuits as you describe the problem can be a leak of refrigerant in the freezer circuit.if there is no heating up in the freezer condensing coil.It has to be check for the leakage.
Jul 01, 2009 | Freezers
The grill being the condenser coil- The sealed system is low on freon or the compressor isn't working correctly.
Jul 01, 2009 | Frigidaire FRS3R5EMB Side by Side...
GE PFS22MISBBB freezer not cold enough. Temp won't reset.
replace the fan as quickly as possible it may be shorting and causing damage to your control board,
Mar 30, 2008 | GE PFS22SBSSS Stainless Steel French Door...
Refrigerators Logo
1,395 people viewed this question
Top Refrigerators Experts
KJ4QOB
Jim Akins
rodney bartholomew
Level 1 Expert
