Question about Sony DVP-C650D Multi-disc DVD Player
Sony DVP-C650P: Grid-like overlay on picture
When using my 6-8 year old DVP-C650P CD/DVP player, for the first 30 minutes or so there is what looks like a screen or grid pattern all over the picture. Sometimes this goes away; sometimnes not. This does not happen when watching cable or a separate VHS player.
Any idea as to what causes this problem?
/s/DVD Challenged in Nashville
  • 859 Answers
SOURCE: unlock region code on Sony CD/DVD Player DVP-NS57P
Let me see what I can come up with. Our board here still doesn't notify we experts of all requests all the time, so I would have been back to you earlier.
Posted on Sep 06, 2008
  • 2992 Answers
SOURCE: Sony CD/DVD Player DVP-NS50P not playing my avi files DVD+RW
You need to convert avi files to dvd format before burning, otherwise the player won't recognize them. Google "avi to dvd" and you'll find a number of free or pay programs that will do the conversion for you.
Posted on Nov 19, 2008
SOURCE: Unlocking Code Required to make the Sony DVP-PQ2 DVD PLAYER MULTI-REGION.
sony dvp-fx811 - multiregion codes wanted
Posted on Dec 21, 2008
  • 2692 Answers
SOURCE: multi region code
An option.
 Download DVD fab or another like product which takes off the region code completely using a PC then copy the DVD onto another DVD using the DVD burner,or find someone who can do this for you.
Posted on Jan 07, 2009
  • 35 Answers
SOURCE: Sony DVP-NC600 Multi-disc DVD Player No Disc Error
The only other thing I can suggest, having repaired many Sony CD/DVD players, is to get a can of compressed air and try to blow any dust out from the laser assembly. Since you've already cleaned the lens (the most common problem), you also might have dust down inside the assembly. Try blowing with the air nozzle down inside, around the gap between the lens and the cover surrounding it. Do it from at least a couple of inches away, if the air is too powerful you can damage the wiring inside the assembly.
If this fails to correct the problem, your laser output may have diminished over time and the only repair is to install a new laser assembly. The cost of this part will most likely not be worth it to you since the unit is quite old now.
Posted on Mar 02, 2009
Our DVP-FX820 DVD player is 16 months old. You can hear the sound when it plays but can't see a picture.
Please try adjusting the backlight. If the issue persists, try resetting the player. To reset the Portable DVD Player, remove the battery of the DVD Player, then reconnect it after 1 minute and check if it helps. If the issue still persists, then the player requires service.
you can get the unit serviced at:
Jul 21, 2010 | Sony DVP-FX810 Portable DVD Player
Manuals for sony dvp-ns57p
please check the link below:
on the bottom of the page after the description, you will find the Owner Manual.
please check it, it should give you all the solutions you need.
thank you.
May 18, 2010 | Sony DVP-NS575P DVD Player
Look in your manual, (I have a 46H83) and got the PDF manual several years ago. It has a "one-touch" convergence. Not very good 3x3. I found a better pattern internally and another on HDNET on Dish, 10 minutes early on Saturday 6 AM MDT, moves around. It is flawed on its overscan scale. A DVR helps.
This combined with nominal spacing from the AVSforum board allowed me to make an overlay of vinyl (static stick and cheap but stretchy) and draw lines on it to be matched with the internal grid. On a second pass I reduced the overscan. This takes a lot of work/time for 8x7 points of convergence. Do it in 15 min sessions--you don't want to burn in the pattern or you. The overlay grid allows absolute alignment not just piecewise. Unless you move/turn the TV around you only need this once every few years. -Ken
Aug 18, 2009 | Toshiba 57H82 57" Rear Projection...
Sony Portable Cd/DVD Player DVP-FX810, "loading", "check disc"
Hey Teddybearman, I have exactly the same problem as you have. Did you manage to find out how to fix it?
19 July 2010
Jun 07, 2009 | Sony DVP-FX810 Portable DVD Player
Pictures taken from sony digital camera (6 Mega pixel) are not clearly seen on SONY DVP FX720. Is there any settings we need to do to get good quality?
change the format eg 640 x 480 to a higher resolution ...a good quality uses about 250kb per picture most jpegs use 50kb to save space
a really good picture can use 500kb.
May 15, 2009 | Sony DVP-FX720 Portable DVD Player
Sony DVP-FX810 Portable DVD Player, region code 4 to mutiregion code.
1. Switch on the player
2; open the CD compartment
3. Enter the following code (using the remote): 2812
4. Highlight the region
5. Change to 9 (for Multi-region) using the 'Enter' button
6. Hit 'Clear' to exit
check with different region DVD
Sep 24, 2008 | Sony DVP-FX810 Portable DVD Player
Unlocking dvp-fx810 sony dvd player
The unlock method should work for DVD players bought in regions 1 (USA) and 3 (south East Asia)
You need to use a One4All Universal remote for regions 1 & 3
2. Pop open the CD compartment
Apr 13, 2008 | Sony DVP-FX810 Portable DVD Player
Dvd player frequently pauses or freezes while trying to play audio cd's
You tried cleaning the lens right?  That's the first thing I would do. You may have to actually open up the unit and use some windex on a cotton swap to clean the lens. Be very careful not to overwet the cotton swab. Use the other end of the swab to dry the lens.
The red wavelength of light from the laser might not be getting through the lens properly, which is used for the Audio CDs, where the higher frequency laser is used for the DVD material.
Oct 31, 2007 | Sony DVP-NS55P DVD Player
My sony dvd is powering off about one minute after I turn it on.
1. Press Display.
2. Go down and select Setup.
3. Move to the Right and Down to select Custom, Press ENTER.
4. Move down to the center box.
5. Move Right to select Auto Power Off, Press ENTER.
6. Change it to Off, Press ENTER
7. Press Display and you should be done.
Aug 11, 2006 | Sony DVP-CX985V Multi-disc DVD Player
Sony DVP-C650D Multi-disc DVD Player Logo
59 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
