Question about Casio Exilim Ex-fh20 20x 9.1mp Digital Camera
Cannot open battery cover - Casio Exilim Ex-fh20 20x 9.1mp Digital Camera
Cannot open battery compartment to change battery's
All you need to do is slide the battery cover to the Open position, then open the battery cover to access the batteries. If it doesn't open easily you may have some corrosion on the batteries holding the cover closed.
Mar 01, 2016 | Casio Exilim Ex-fh20 20x 9.1mp Digital...
Cannot open battery compartment on remote
Either push the finger / thumb indentation down and along remote or release the small catch at one end of the cover using finger nail and lift the cover off with same finger nail
Jan 12, 2016 | Televison & Video
I don,t know how battery cover opens so i can install the batterys,
The battery cover is the bulged part of the plastic, on mine it's a gray color compared to the black body. with the LCD screen to the left and the gray cover to the right, gently press down on the part of the battery cover nearest the LCD screen and press to the right.
That should open it up and get you to the batteries.
Mar 05, 2011 | VuPoint PDSST410VP
I have put fresh batteries in my Canon Power Shot S1 camera and it still will not come on? Can you help me?
Contact failures may have occurred between the camera and the batteries.
Confirming that the [Memory Card / Battery Cover] is securely closed
If the [Memory Card / Battery Cover] is not securely closed, the power of the camera may not turn on.
Close the [Memory Card / Battery Cover] securely, and then turn the power on.
Clean the battery terminals with a dry cotton swab that has a fine and soft tip, and then re-insert the batteries.
If your camera uses four AA-size alkaline batteries supplied with the camera, follow the procedure below. In addition to Alkaline batteries you may use optional nickel metal hydride (NiMH) batteries.
1. Be sure that the camera power is off.
2. Slide the battery cover lock in the direction of the arrow, and push the battery cover slightly forward. Then open the cover.
batts_step1.gif 3. Insert the batteries as shown.
batts_step2.gif 4. Close the battery cover.
batts_step3.gif * For the PowerShot S2 IS, PowerShot S3 IS, and PowerShot S5 IS the batteries are inserted in a slightly different order, please refer to the decal inside the battery door for the correct order.
Installing batteries in cameras with 2 batteries. If your camera uses two AA-size alkaline batteries supplied with the camera, follow the procedure below. In addition to Alkaline batteries you may use optional nickel metal hydride (NiMH) batteries. Please see the various examples to find which type matches your camera.
Example 1:
  2. Slide the battery/memory card cover lock in the direction of the arrow (1.gif), and press down while opening the cover (2.gif).
  3. Insert the batteries as shown and close the battery / memory card cover.
Example 2:
  2. Slide the battery cover lock in the direction of the arrow, and open the cover.
* For the PowerShot A300 and PowerShot A310 the battery polarity is reversed.
Dec 05, 2010 | Canon Cameras
I have a sentry safe model so500 & the batteries are dead, so I can't open it. I know the combination, I just can't open it! HELP!!! thank you, Lesley
Locksmiths agree on How to install sentury safe batteries
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
Aug 07, 2010 | Sentry Fireproof Safe
How come my battery wont charge on my brand new Nikon S 8000? There isn't an indicator light showing the status of a charge...also I had it charging for 24 hr but still battery exhausted message.
We had this same problem...battery indicator light not showing and battery not charging. We found out by accident that if the battery cover is open, it won't charge. So open the battery cover, open the USB cover, shut the battery cover and then plug in the USB as normal. It worked for us, hope it will work for you too.
Jul 20, 2010 | Nikon COOLPIX S8000 Digital Camera
I can't the open battery cover
The proper way to open the battery cover is by pressing the back with your thumb (little pressure) and push it down (opposite to the Camera).That's how it is done...trying some other way will break the locks.
This link will help you out
http://www.youtube.com/watch?v=gtNOxv1t7LU
Oct 06, 2009 | Samsung SGH-S5230 Cell Phone
My Sentry S3807 just will not open. I have the combination right and the key, but it won't open. The batteries could be shot, I suppose, but how do I get in?
How to install sentry safe batteries
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Aug 26, 2009 | Sentry Fireproof Safe
I need to open my I425 to check the battery
There must be a small tabe like structure on the battery's cover. Push it inside and at the same time pull the plastic cover downwards. The cover will surely open up and you and chek the battery.
Aug 22, 2009 | Cell Phones
Sentry S3807 safe-cannot open
locksmiths agree on how to install sentury safe batteries
to install batteries, turn the electronic lock case to the right and remove.Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Jan 26, 2009 | Sentry Fireproof Safe
Casio Exilim Ex-fh20 20x 9.1mp Digital Camera Logo
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
