Question about Conair Professional Ceramic Hair Straightener - Black
My straightener won't heat up anymore
Heelloo, uhmm one day at like 2/3 i was straightenning my hair, so i pressed the button thinking i turned it off only to find oout at like 11 that i didn';t and now everytime i plug it in so is it broken?
and is there anyway on fixing it ?
3 Suggested Answers
geokohler
  • 304 Answers
SOURCE: Straightener not working!!!!
It sounds to me like the thermal cutoff switch has blown. Straighteners have these as a safety device similar to a fuse to protect against fire in the event it gets too hot. These are not very costly to replace. Here is a link to where you can buy them and what they look like:
http://www.welco.com.cn/?gclid=CJiWv7TN2ZQCFQpzHgodl1LXQQ
Make sure you get one of the exact same cutoff point as the one designed for yours. If you put in a higher temp device it will be harder to blow but will make it dangerous as it may cause a fire if it over heats. Some shady repair men will just bypass this and it will work again fine but this is a dangerous practice as it directly puts you of danger. If you do have it repaired at a shop demand for the old thermal cutoff from your unit when you drop it off so the tech will know you know what is wrong with it and that you will check to make sure that it has really been changed. This will also not give him the chance to over charge you when he knows you know it is only a 1 dollar part and easy to change.
This device is very easy to change, If you can open your unit you could easily do this yourself. The part, as you will see on the site where you buy them, only has 2 wires one coming out of each end. You simply cut out the old 1 and replace it with the new one. You do not even have to worry which end goes where. It is like a fuse, it works the same either direction. You have to buy some wire crimp connector to connect it, you can not just solder it in due to the heat in the iron. In a pinch you could just securely twist the ends of the leads with the leads from the old cutoff if you clip the leads from the old cutoff real close to the device. This will leave you with plenty of wire to get a good twist. I always use the crimp connectors so it looks more professional.
Anyway, I hope you found this to be helpful and if you need more help feel free to ask me. I will stay with you on this until we have it fixed.
George
Posted on Jul 25, 2008
SOURCE: Professional Ceramic Hair Straightener - Black: My straightener light turns on but it doesn't heat...
Have a look at www.ghdfix.com
Posted on Jul 27, 2010
My remington straightener won't work properly. HELP?!
Try wiggling the lead where it goes into the straightener and then the plug. If it works it may be a broken cable in the lead
Jul 29, 2012 | Remington Keratin Therapy 1-In. Hair...
I just got my Infinity by conair model cs32 straightener and it will not turn on or heat up. Please help.
If you just purchased it today or up to 30 days after purchase, TAKE IT BACK!!. If you start having problems from the beginning you will possibly always have them.
Sep 14, 2011 | Conair Infiniti Instant Heat Ceramic Hair...
I have two irons. one if them won't turn on anymore and i noticed the light kept fading out. the light on the other one flickers and it stops working halfway through straightening. any solutions?
Most likely it is the power cord. We have the same iron and the power cord has a break in it just as it comes out of the swivel. You can turn it on and hold the power cord tight up against the swivel and it should stay on. I was able to fix it by stripping the cord down to the wire soldering and adding shrink tubing to the connection. That lasted for about 1 year and it has done it again. I may have to replace it but not sure how to take it apart.
Sep 19, 2010 | Conair Infiniti Instant Heat Ceramic Hair...
Hair straighner .
Does not seam to "light up" ?
Light goes on ??
Not heating - but the light on ??
If so - the heating element has failed..
Time for a new one I am afraid ;o(
Aug 20, 2009 | Conair Professional Ceramic Hair...
My conair straightener won't heat up
that same thing is happening to me! but iv had mine for almost 2 years...exact same hair straightener, its happening to many people! i dont know if this is the problem but alot of people wrap their cords around their straighteners (i did too) and it twists the cord that conects to the hair straightener and makes it loose. i still have not found a way to solve this problem.
i would just go out and buy a new one, and if your looking for good but inexpensive i suggest vidal sassoon. they get really hot and have many settings and many different types. mine has worked greats
just remember not to wrap the cord
May 31, 2009 | Conair Professional Ceramic Hair...
My hair straighteners will not come on. I have changed the fuse and this made no difference
see that happened to me u just have to thro it away and get a new one trust me it wont work again 3 of my family memeber r butician hair ppl or whatever salonist wehatevea u wanna call them so i get free straightener hair dryers and stuff so i dont have to worry :)
Dec 20, 2008 | Conair Professional Ceramic Hair...
Conair Professional Ceramic Hair Straightener - Black Logo
4,138 people viewed this question
Top Conair Irons Experts
ashburton
Glenn Smart
Glenn Smart
Piyal Perera
Piyal Perera
Are you a Conair Iron Expert? Answer questions, earn points and help others
