Question about AMD Sempron 2600+, 1.83 GHz (sda2600box) Retail Processor
I have a problem in formating the pc. During formating process it stops, And written as 'Hard error Systemroor/system32/ntdll.dll' in blue screen. What can I do now?
    Problem Solver:
  • 9 Answers
Your harddrive has a bad sector that cannot be recovered or passed maybe a series of bad clusters replace the harddrive as they are cheap and fail often
Posted on Jul 16, 2009
No sound no audiono ethernet hard error c0000221
Here is an explanation of your problem - http://support.microsoft.com/default...;en-us;Q314474
and ways of fixing it. Regards.
Download the file here http://www.dlldump.com/download-dll-.../download.html and replace the corrupted file .. it should be in C:\Windows\system32
When you boot up, go into Safe Mode (tap the f8 key as its starting to boot up and select Safe mode from the resulting menu). Now go to the 'problem' dll, right click on it and select rename. Rename it to ntdll.dll.old then paste the new .dll into the system32 file
Hope this helps
Apr 16, 2014 | Dell DimensionTM E520 PC Desktop
Ntdll.dll error
you need to format your hard drive fully and install windows xp 2006
Dec 06, 2013 | Antamedia Internet Caffe
Ie shows error message(, ModName ntdll.dll.) then shuts down when I use USB storage drive. I have removed Internet explorer but still shows the error message and shuts down
The causes of ntdll.dll error messages can vary greatly. However, most ntdll.dll errors result from a corrupt or damaged version of the ntdll.dll file itself, corrupt hardware drivers, or issues between Windows and other programs.
Ntdll.dll errors can sometimes mean that a piece of hardware in your computer is malfunctioning, but this is rare.
Resolution
1.Restart your computer. The ntdll.dll error you're receiving could be due to a one-time, temporary issue and a simple reboot may resolve the problem completely.
2.Reinstall the program if the ntdll.dll error only displays when you use a specific program.
If the software program has any updates or service packs available, install them too. The software's programmers may have identified an issue with the program that caused the ntdll.dll error and then issued a patch for it.
Note: Third party software programs that have been installed on your computer are almost always the cause of ntdll.dll errors. The remainder of these troubleshooting steps resolve ntdll.dll issues only rarely.
3.Check the Windows service pack level you're running and then check Microsoft's support site to see if there is a more recent service pack available for installation. Some issues that caused ntdll.dll errors have been corrected in these service packs from Microsoft.
4.Selectively disable Internet Explorer add-ons. If your ntdll.dll error is displaying when you start, run, or close Internet Explorer, an add-on may be causing the problem. Disabling each add-on, one by one, will determine which add-on is the culprit (if any).
Note: As a workaround, assuming the ntdll.dll error really is Internet Explorer related, install and use a competing browser like Firefox.
5.Rename the NLSPATH system variable. If your Windows system does not have this environment variable, skip this step.
Note: This is a troubleshooting step for this issue only. Be sure to set this path back to its original name if this does not resolve the ntdll.dll issue.
6.Disable Data Execution Prevention for Explorer.exe. As in the previous step, this is for troubleshooting the ntdll.dll issue only. If this doesn't resolve the problem, return the Data Execution Prevention settings to their previous settings.
7.Update drivers for any hardware in your computer where updated drivers are available. Outdated drivers sometimes cause ntdll.dll errors.
8.Test your memory for damage. If you're receiving ntdll.dll messages, one possible cause could be a bad memory module in your system. Testing your memory will either identify a problem or clear your RAM of any responsibility.
Replace your memory if it fails any of your tests.
9.Ntdll.dll errors could occur if you have an Iomega Zip drive on the same IDE cable as the hard drive inside your computer. If so, move the Zip drive to a dedicated IDE controller.
10.Replace the IDE cable connecting the hard drive to the motherboard. If this cable is damaged or malfunctioning, one symptom could be the ntdll.dll error you're seeing.
11.Repair your installation of Windows. If individual software reinstallations fail to resolve the problem, a repair installation of Windows will replace the ntdll.dll file.
12.Perform a clean installation of Windows. A clean installation will completely remove Windows from your PC and install it again from scratch. I don't recommend this option unless you've exhausted all previous troubleshooting ideas and you're comfortable that the ntdll.dll error is not caused by a single program (Step #2).
Note: If a single program or plugin is causing the ntdll.dll error, reinstalling Windows and then reinstalling all of the same software may lead you right back to the same ntdll.dll error.
13.While extremely rare, if everything else has failed, including the clean installation from the last step, you could be dealing with a hardware issue with your hard drive.
If so, replace the hard drive and then perform a new installation of Windows.
Jul 20, 2011 | Microsoft Internet Explorer 8
STOP C0000221 erro de hardware desconhecido systemroot system32 ntdll.dll
You may receive one of the following stop error messages while working on your Windows XP computer.
STOP: C0000221 unknown hard error
Path\File_nameSTOP: 0xC0000221 unknown hard error
C:\Winnt\System32\Ntdll.dll (or another specific file or driver)
STOP: 0xC0000221 STATUS_IMAGE_CHECKSUM_MISMATCH
Path\File_name
Note: The error message may be discussed in many different formats-blue screen or message box. It depends on when the corrupt file was detected.
Similarly, you may receive the following STOP messages when a critical system file fails to load on your Windows NT and Windows 2000 computer.
<path>\<file_name>STOP: 0xC0000221 unknown hard error
c:\winnt\system32\ntdll.dll
Note: Some other drive may also be given in the message.
On Windows 2000 the following error message may display:
<path>\<file_name>
You usually face this problem when an incorrect driver for one or more hardware is installed on your system. For instance, the error messages described above are displayed when you install a millions of instructions per second (MIPS) driver on a x86 system.
Cause of the Error
This error occurs if the file given in the error message is damaged.
Your Windows XP operating system checks the following files for integrity during system startup:
  • All driver files, excluding the files that loaded using the system loader to start your system .
  • All DLL (Dynamic Link Libraries) on the system. These include, Graphics Driver Interface (GDI), User, Ntdll, Crtdll, Shell, Kernel and several other DLL files on the system.
  • On Windows NT and 2000 computers, all DLLs loaded in the Window server address space are also checked.
The problem may also occur if an Iomega Zip drive is connected to the same cable as your hard disk drive.
Resolution Method
You can resolve this issue by removing the corrupt driver from your computer and then reinstalling a fresh and healthy copy of the driver. You may need to use the Device Manager utility to remove the driver. It is recommended that you clean your registry with the help of a reliable tool, such as RegGenie to ensure that all entries related to the uninstalled driver are removed from the system. After you have completely removed the corrupt driver, restart your system and install a fresh copy of the driver on the system.
If this step does not resolve the problem, you may have to reinstall Windows XP.
It is recommended that you regularly clean your registry with the help of a registry cleaner tool and perform antivirus and antispyware scan using tools, such as Antivirus Plus and StopZilla to prevent such errors from occurring on your system.
GOOD LUCK :-)
Feb 03, 2010 | Intel Computers & Internet
Blue screen error
I see ..either teh installation didnt complete the loading of the files..or you didnt format the Hdd proper...try to reformat it in the NTFS normal mode...and change the installation cd ..cause in the proces there might have been a file it couldn't copy ..and skip it ...keep trying cause sometimes it does that ...if the server went fine ..this means that the HDD its ok ..and the problem is the installation disk ...with xp on ...
Aug 04, 2009 | HP Pavilion zd8000 Notebook
Hard error : STOP C000021
This is a common error
just copy or download ntdll.dll file from the net and replace the file in ur disc
then just make a new bootable iso file and burn into a new cd
restart the comp,install and enjoy
Shreyas
Cheers
Feb 19, 2009 | Microsoft Windows XP Professional for PC
C0000221 Unknown Hard Error\System32\ntdll.dll
From MS's KB:
http://support.microsoft.com/kb/314474
Feb 06, 2009 | Microsoft Office Professional 2007 Full...
Unknown Hard Error
It's probably a corrupted file on the hard drive due a variety of reasons. A simple defrag might fix it but it's unlikely, so it is probably preferable to a Repair function from your XP install CD. These kinds of errors with XP were not uncommon. After the Repair assuming it works and I'm fairly certain that it will, defrag your hard drive and then start getting the new updates for your system.
Illustrated procedures located here
Aug 26, 2008 | ASUS P4VP-MX Motherboard
Windows xp installation
HI,
Here is what the Media test failure check cable eiting PXE ROM means:
Iam sure when we were changing some settings with the BIOS you must have done something wrong.Just reemember if you changed some settings over there.
try change the boot-order in the BIOS
try to disable "network-boot" in the BIOS.
This issue is often caused by either an incorrect setting in BIOS or a bad boot device, such as a bad hard disk drive. To resolve this issue,Isuggest you go through the steps in document CH000229 relating to a similar error message.
Now coming to System32\ntall.dll unknown hard error:
If the ntdll.dll error only displays when you use a specific software program, uninstall the program, reboot your computer, and then install the latest version again from scratch.
Perform a repair installation of Windows XP. If individual software reinstallations fail to resolve the problem, a repair installation of Windows will replace the ntdll.dll file. Remember to install all Windows service packs and other patches after this installation.
Perform a clean installation of Windows XP. A clean installation will completely remove Windows XP from your PC and install it again from scratch. I don't recommend this step unless you have stepped through all previous troubleshooting steps and you're comfortable that the ntdll.dll error is not caused by a single program (Step #2). NOTE:a single program or plugin is causing the ntdll.dll error, reinstalling Windows and then reinstalling all of the same software may lead you right back to the same ntdll.dll error.
While extremely rare, if everything else has failed, including the clean installation from the last step, you could be dealing with a hardware issue with your hard drive. If so, replace the hard drive and then perform a new installation of Windows XP.
Apr 20, 2008 | Computers & Internet
AMD Sempron 2600+, 1.83 GHz (sda2600box) Retail Processor Logo
Top AMD Computers & Internet Experts
David
David
rafnix
rafnix
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
