My Whirlpool Thin Twin washer works fine until it gets to the spin cycle at the end of the rinse (not the final spin) it spins up fine, but won't stop, it just sits spinning endlessly until you manually advance the timer to the next part of the cycle. The timer works fine for all other cycles and positions. I checked the drain hose for clogs, it was full of water but I couldn't see an obvious blockage. The unit is in a small tight closet so I'm pulling it out tonight to get a better look at everything. Is it normal for the drain hose to have about a liter of residual water left in it after the drain cycle? I'm really hoping this isn't a timer issue since the other positions in the timer seem to work fine. Thanks!
How old is the unit? It may be part of a recall for a dual pressure switch update kit. It's free of charge if it is one of them.
Testimonial: "It's about 10 years old, I looked online but I couldn't see any recall for the pressure switch, and it's not part of the fire/burn hazard recall."
Yup let hope it doesn't brake down
