Question about Handmark Software MobileLists (950142) for PC, Mac
Shake mode is not working propertly - Handmark Software MobileLists (950142) for PC, Mac
How to solution inser sim
Posted on Jul 17, 2009
Propert digital bathroom scales
remove battery. leave out for an hour then put back in. memory wiped then.
Oct 05, 2013 | Televison & Video
Problem with the ceramic electric cooking surface-ECT300BC
Could be that the heating element is burned out and needs to be replaced.
Sep 20, 2017 | Office Equipment & Supplies
Alienware area-51 7500 r4 powers up but will not post. LED on motherboard stays '--'.
It could be your power supply, memory, cpu or the motherboard.
Disconnect all USB devices connected to your PC with the exception of the keyboard and mouse, also if you have any devices other than the video card, disconnect the as well.
Try and see if your pc will boot now.
Try booting into safe mode.
Do you hear any error beeps?
Test the display on another pc to make sure it is working propertly.
I hope this helps.
Good luck and have a pleasent day.
May 17, 2011 | Computers & Internet
Error code - Camera Stablizer is not available.
try resetting the camera if you can. This is a fairly easy procedure which involves either going into your setup menu and choosing "reset," or, removing the batteries for a few minutes. After which, you should have the camera reset to factory default settings.
Another tip for when you get home is to go to to the website and look for firmware updates. Download and install them.
Are you working with a Casio as this error is common with the Casio user.
In Casio EV-7, anti-shake only works in S-Mode or M-Mode and the speed must not be more than 4 seconds, which means the lighting must not be too dim.
If you have set it to the correct mode and lighting condition is not too dim, then you got to perform one more step - to set the anti-shake to on.
" In Record Mode, press Menu button
On Rec tab, select anti shake "
You will be given 3 options, Auto, Camera shake, Image blur.
Select Auto or Camera shake.
2. In connection with this, you may wish to read about the test on anti-shake function for the camera at DP Review
Thank You
May 12, 2009 | Casio Cameras
Shake control
4 shake control u ave 2 press d walkman key right nest to d power key 'PRESS AND SHAKE'
May 01, 2009 | Sony Ericsson W910i Cellular Phone
Display is shaking
More likely your settings. It maybe interlaced mode, try changing the resolution/refresh rate. there is nothing else that will cause the shaking you described.
There is another shaking that can come from the heat given off from the projector, but this sounds like a settings problem.
Feb 19, 2009 | NEC VT47 Multimedia Projector
I have a microtek 17' monitor model is 41f
This can be caused by low Screen Refresh rate. Eg 60Mhz. To increase this go to Display propertes > Setting > Advance > Monitor > Screen Refresh rate
Your graphic driver must be installed correctly to be able to make this change.
Please tell me If this dont fix
Best regard
Dec 05, 2008 | Microtek Computers & Internet
Whirlpool RBS305PDQ11. After self-clean, oven won't heat up.
This seems to be a common problem with these ovens. The oven got too hot and the tco (Thermo cut off)tripped. This will have to be replaced. It is located behind the control board.
Aug 15, 2007 | Whirlpool RBS245PDS Electric Single Oven
Icon that looks like a hand with lines around it
This icon represents Movie Mode Camera Shake Correction In Movie mode, digital camera shake correction can be applied to reduce image unsteadiness and camera shake.
Sep 01, 2005 | Olympus i:robe IR-500 Digital Camera
Handmark Software MobileLists (950142) for PC, Mac Logo
Top Handmark Software Computers & Internet Experts
Laxman Bisht
Laxman Bisht
Tarpan Shrivastava
Tarpan Shrivastava
steve morris
steve morris
Are you a Handmark Software Computer and Internet Expert? Answer questions, earn points and help others
