Question about Casio Triple Sensor Pathfinder PRG60-1AV Wrist Watch
Casio Pathfinder 2273 Reassembly Help
My Casio Pathfinder got water into it - I disammbled and dried out but there are two very small springs laying on top of the PCB when I took off the plastic cover that holds the batteries - I can't see where the springs go and I can find any detailed part manuals on the web - any help or advice would be appreciated - Dan.
  • Anonymous Mar 16, 2008
    this make any sense, should be more specific or take some foto?
  • Jennifer Mullins
    Jennifer Mullins Dec 04, 2016
    Hi -- I had the same problem when I went to replace the batteries. I ended up stretching the spring out. So I sent it to Casio and since the watch is an older model, they said that they could not fix it.
    I know this answer isnt much help, but to save you the trouble of sending it to Casio, I would recommend taking it a place that repairs watches.
Hi there these small springs sit under battery connector tabs (Below)copper colors tabs so that theres enoughe spring pressure, for your watch to run. Hope this makes sense and remember its just a watch so dont stress out, lifes short and you never now when that meteors going to come in and vaporize us.
Posted on Dec 27, 2007
When using the barometer or altimeter on my my pag 40 - 2271 it shows err. How do I fix it? Do you know what page in the users guide shows how or gives directions on how to fix?
Same problem with my SPF-40, module 2273, after a small helical compression spring, silver color, fell out. I could not determine where it is suppose to be located. It could be the barometric reference spring for sensing the barometric pressure.
Nov 18, 2010 | Casio PRG-40T-7 Pathfinder
How di i change the batteries in my Casio Pathfinder 2782
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Sep 20, 2010 | Casio PRG-40T-7 Pathfinder
    How do I replace the batteries on my Casio Pathfinder PAG40B-2V watch?
    Thank you for contacting FixYa.
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
    Sep 19, 2010 | Casio Pathfinder PAG40B-2V wristwatch
    I have a casio sea pathfinder spf-51 and i opened the case to see if i could change the battery myself.Unfortunately one of the 3 springs fell out and i cant see where it should go.Can anyone help me with...
    mcdevito75 here, My best advise is to see how the other 2 springs are situated in the watch, then simply follow suite with the 3rd spring. BE VERY CAREFULL THOUGH AS< ANY OR TOO MUCH RESURE ON THE CASIO DISPLAY WILL RUIN IT. If you can"t find the spot for this spring, look for a small watch repair shop in your area for help, it"s better than ruinning your watch.
    Jul 17, 2010 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
    Casio module 2273 battery change
    did u ever figure out how to get the retaining clip?
    Mar 13, 2010 | Casio PRG-40T-7 Pathfinder
    Problem with casio sea-pathfinder watch
    For all Casio watches go to www.casio.com select "Support" then "Manuals" then "Watches".
    You will then be able to enter the 4 digit number in the square box to get the manual for your watch or module inside is actually what the instructions refer to.
    The problem of changing functions automatically is called "Auto Display" and can be stopped and started in Sea-Pathfinder SPF-40 (modue 2273) by pressing the bottom left button for 3 seconds.
    Nov 13, 2008 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
    Casio spf 40 Module 2273
    Your Watch is in Auto or demo mode. Hold down the "Mode" button for 3 - 5 seconds and it will return to time keeping mode.
    Cheers,
    Murray
    Nov 19, 2007 | Casio PRG-40T-7 Pathfinder
    Casio Triple Sensor Pathfinder PRG60-1AV Wrist Watch Logo
    598 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
