Question about ViewSonic PJ255D DLP Projector
Vt45 projector turns off without notice.
The projector turns off while in use. It doesn't really needto be "too hot". It may be in the first few minutes of use.
Help! We've already had it repaired once before. It sometimes seems to help when the filters are vacuumed very clean. That's the advice we received before.
Any suggestions will be truly appreciated. :D
  • 4 more comments
  • adent42 Aug 12, 2008
    Exakt same problem with.
  • alester Sep 19, 2008
    I have had the exact same problem with more than one of these projectors. Any suggestions would be appreciated.
  • PowerhouseAG Sep 24, 2008
    We had that same problem, but now the lamp won't come on at all, how can I reset the filter timer without the lamp. It went for a long time giving the error message to change the filter (which we did, but it still gave the message). We're a very small church and can't afford to replace the bulb again (we just did about a year ago)
  • argonowt Nov 05, 2008
    My projector was exactly 1 year old and working fine till it started to switch off after around 3 mins. I've cleaned it out and reset all counters. This has had no effect. the fan is working and I don't believe it is to hot. Also once it has powered down no LED's are lit. I need to disconnect from the mains and wait for a period of time (not sure 5-15 mins) till it will respond. Any help gratefully recieved
  • loKey73 Nov 22, 2008
    I have the same issue- intermittent power failure, the standby light won't even come one until all of a sudden it does then you start the projector it warms up and then a couple minutes later POOF! it has no power, not simply turned off but literally no power, as in no standby light or anything
  • Anonymous Nov 22, 2008
    SAME HERE.
You've probably replaced your projector since this question is a year old, but I had the same problem. The problem is with bad capacitors. A friend of mine works at a television repair center and was able to replace the bad caps with generic off the shelf replacements. The cost was less than ten dollars and my projector is as good as new.
Posted on Dec 01, 2008
  • 563 Answers
Hi there
What brand is this Projector ?
Check if the unit has a Filter Timer ? If it does have one - check the hours on it and reset it.
If the problem stil occurs or there is no filter timer in the Menu - check that all your fans are running.
Hope this is of help
Posted on Mar 27, 2008
How do I reset my nec projector model vt700 lamp time without remote
How to Reset a NEC Projector Lamp Timer ... - RelampIt
www.relampit.com/Projector-Lamp-Timer/NEC-Projector-Lamp.php
How to Reset a NEC Projector Lamp Timer. Make sure the projector is in standby mode; Press the Off or Help button on the remote control for a minimum of 10 ...
NEC reset lamp without remote Questions & Answers - Fixya
www.fixya.com/tags/reset_lamp_without_remote/browse/nec
My bulb warning had just recently appeared a few weeks prior, so I thought the bulbmust ... ...reset the Lamp timer o an NEC MT1050 projector. ... ...reset lamp usagetime without the remote on NEC VT490 HelloPress the MENU button on the ...
reset lamp hours nec projector without remote Questions ...
www.fixya.com > Forum > Tags
Find solutions to your reset lamp hours nec projector without remote question. ... My nec vt48 projector gets hot and turns off. It ... Question about VT700 Projector.
Replacing The Lamp - Nec VT700 User Manual [Page 58]
www.manualslib.com > ... > Projector > VT700 > User manual
Jan 29, 2016 | NEC Office Equipment & Supplies
How do you reset the lamp on a NEC VT45 projector.
holding down the "OFF" key on the remote control for 30 seconds
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jan 21, 2014 | NEC VT45LPK Projector Lamp for VT45
Epson PowerLite 410W projector (used for a smart board in a classroom) won't project anything or even turn on. Power button (maybe lamp indicator light? I don't really know anything about this...)...
It seems you assume that it is not an overheating problem.
The problem is, the bulb gets really, really hot when using the projector. It doesn't matter whether it has been there without any usage. As you switch it on, it will start to get hot.
But the lamp or other parts of the projector should not get too hot. To control the temperature, air is moved through the projector with the help of fans. Air enters through air filters and move through the projector absorbing heat from hot parts. This prevents these parts from getting overheated.
But what if air doesn't flow freely? Then the parts CAN get overheated.
First, switch on the projector and check whether you can hear the fans working.
Next, switch off the projector and remove power cable.
After about 30 minutes, remove the cover and check whether the air filters are blocked. If they are, clean them with a small brush.
This would probably solve your problem.
Sep 23, 2011 | Epson PowerLite 410W LCD Projector
I have had my dell 4210X ceiling mounted projector / smartboard in my classroom for a few months. In the beginning I could turn everything on and use the blank screen option throughtout the day. ...
Have you checked the air filter for dust etc
what leds come on as it shuts down.
I suggest that you take it down and run it on the bench normal way up and see what leds come on etc
Mar 24, 2011 | Dell 4210X DLP Projector
Steady red status light on NEC VT45 projector. Would not POWER ON. LAMP was replaced with a new one
the power supply on that model seem to go bad after a while. the caps aren't properly reted it's power needs. they dry up. if you are good at soldering, replace c1 on the board (big cap) with a cap that has a slightly higher voltage rating. or replace the whole power supply. you might not be able to get one from nec, but you can try www.projectordoctor.com
Dec 16, 2009 | NEC MultiSync VT45 Multimedia Projector
Light and fan will not turn on.
the temp sesor may be defective. check fuse or relay
Sep 19, 2009 | NEC MultiSync VT45 Multimedia Projector
VT45 Projector: Blue pixels throughout screen
If the problem is what I describe as a blue haze over the entire image projected, I was told this is a defect in the cable - we have a Dell Video Projector 2300 - and it takes only a dell VGA cable.
So, the problem is in the cable - solution is replace cable.
Feb 28, 2007 | NEC VT45LPK Projector Lamp for VT45
Flashing red status light on NEC VT45 projector
make sure the doors are shut all the way! there is a little button there.
Feb 13, 2007 | NEC MultiSync VT45 Multimedia Projector
ViewSonic PJ255D DLP Projector Logo
163 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
