Question about Campbell Hausfeld 20 - Gallon Air Compressor
Air compressor wont turn off
I have a air compressor, i believe its blue in color campbell hausfeld, itll will run till 100 psi to 120 then it blows a breaker, let me friend use it and broke the switch, its stuck on auto which is ok but now wont shut off. not sure if he messed with the wires, theres 4 wires that go to the regualator, and guy said he had them off so im thinking they arent in the right spots, anyone have any idea or have a comprssor like this that can look at the wires and see where they go, or do i tneed to replace the switch, even thought the swithch is broke i can still move it with a flat head....and help with work...thanks guys
  • 98 Answers
If the wires werent put back right the unit would not run at all , you may have to replace pressure switch when it broke it may be keeping the contacts in the closed position.
Posted on Jul 21, 2009
My Campbell Hausfeld WL610002AJ Cycles one time turns off at 140 PSI and next time it cycles makes noise and sounds like it locks up.
The model you are using is only rated for 120 psi that could be part of the problem, at 140 psi you have all ready exceded the max load on the psi regulator. You can adjust the regulator so it will turn off at 120 psi and then it would not put a strain on the compressor.
Apr 09, 2013 | Air Tools & Compressors
My campbell 0.33 runs but won't built a pressure
Check that the drain cock on bottom of tank is shut off,or leaking.?
Jan 28, 2013 | Campbell Hausfeld 0.33 HP 2-Gallon 100 PSI...
My compressor runs way too long to fill up to 150 PSI. It fills up quick to 120 PSI then just takes forever to get to 150 but finally does. It's only 1 year old with very little use. 17 gal, 1.1 horse,...
The pressure switch should be at the factory setting of about 120# max. Not to be hurtful,but what you discribe is normal. Even a 2 HP 220V is minimum for a compressor.. You go by the CFM Rating. You and I can not afford a two thousand dollar 12 CFM Unit. Your compressor is simply too small, to do much. It is pushing against tank pressure so much,after 90# that the reed valves can't hold it. Set it at 100 to 120. It is not designed to run up to 150 max. Now if it is,an oiless compressor , it won't last long. My Campbell- Hausfeld lasted 31 years. Got a new one two years ago
Mar 13, 2010 | Air Tools & Compressors
900 CFM 120 PSI 8 YRS OLD BLOWS OFF RELIFE VALVE BLOWS OFF AT 150 PSI NEED A DRAWING OF REGULATOR
when the regulator switches off it will push a needle into the blowoff valve. it blows off air in cilinderhead and pipe going to checkvalve. when it is blowing off constantly please check blowoffvalve under regulator. when it keeps blowing after stopping please clean up checkvalve very often smal rustparts causes these problems. good luck.
Feb 10, 2010 | Campbell Hausfeld Single Stage Air...
Need new pressure regulator for Campbell Hausfeld
their web site is chpower.com can order on line if not to old can check warranties also they can direct u to service location in ur area
Feb 01, 2010 | Campbell Hausfeld Air Tools & Compressors
My air compressor can pump air in but when it get
when it reaches 120 psi it will cut out usually will cut back in at around 70- 80 psi if it struggles to restart at cut in pressure it may not be bleeding the head pressure om your compressor . this is done by the pressure switch which when shuts off releases a small squirt of air under it . to solve this problem you may need new switch . there is also the non return valve to check
Nov 12, 2009 | Campbell Hausfeld 28 - Gallon Air...
The compressor bleeds off air at 120 psi and the motor won't turn back on to fill unless it drains completely.
ok buddy your pressure switch has gone faulty this can happen i reccomend replacing with a new one off ebay for cheap buddy
Nov 02, 2009 | Campbell Hausfeld 13 - Gallon Air...
Campbell Hausfeld Air Compressor auto shut off switch not working
i have the same one and mine was broken by my kids , i had to replace the entire component, DONT RUN COMPRESSOR with out the regulator working IT CAN EXPLODE IF OVERFILLED,a must fix situation i believe i got mine from sears , a great unit ive used it painting and with many air tools over many years now , well worth fixing mine is a little loud but dependable good luck.
Mar 15, 2009 | Air Tools & Compressors
No air pressure past 60PSI on a 125PSI Campbell Hausfield WL61110
Your comperssor is oilless type and suffers from short cylinder / piston life. When the compressor no longer reaches cycle pressure the cylinder / piston should be replaced. These parts are available at www.chpower.com I believe that the part number is wl210300aj. Not expensive, enjoy.
Dec 13, 2008 | Campbell Hausfeld 26 - Gallon Air...
Campbell Hausfeld 20 - Gallon  Air Compressor Logo
308 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
