Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp 46" LC46D62U suddenly will not respond to remote or manual
It is stuck on one channel. cant turn it off unless I pull the plug
    Problem Solver:
  • 9 Answers
Check for bad capacators on the boards they often have a rise in esr and confuse the chipsets
Posted on Jul 16, 2009
I need a manual for a Sharp 19NV88BK television. The volume is stuck in the stereo mode, cannot lower it manually or with the remote. TV responds to remote except the volume.
Remove wall plug to the television.
Sit down, drink half cup of tea.
Put new batteries in the remote.
Drink other half cup of tea.
Put wall plug back in as all the power internally should be dissipated.
Try remote again.
Remote still not working? Clean buttons with wet cloth and dish liquid, turn remote upside down, wait 5 minutes. Clean buttons with damp clean cloth.
New Remote
http://www.sharpremotes.com/index.cfm?page=4
Manuals are here
Sharp Corporation Sharp Global
Nov 29, 2016 | Sharp Televison & Video
How to trouble shoot backlight issue Sharp LC46D62U
either no voltage reaching it, not being turned on, or bad if the backlight.
Jun 11, 2012 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
MY Sharp LC46D62U wont turn on
Power and OPC LED lights flashes?Common on Sharp LCD tv.Tv is still useable.Tv have Tuner signal board problems.Every times Power and OPC LED lights flashes.Just push the remote power button again and wait.Sometimes Power and OPC LED light will flashes require push power again wait again Power and OPC will flashes two or three time push power button and wait.Must do this two or three time before the backlight will light up and tv work.
Jan 07, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
SNOWY screen--can't find the right channel for Dish Network
Press INPUT button on your TV remote and select right input.
Nov 02, 2009 | Sharp AQUOS LC46LE700 46 in. LCD HDTV
Can't turn off TV unless unlug the power.
Check ur cable or air tv signal.
Turn off and on agian ur your cable box ,if u have free over the air signal u must ajust ur in door or out door antena.Clean ur off/on on ur tv with a little DW40 on the rag clean the switch.Change ur batteries in ur remote,every year,solve most ur tv remote prob.
Aug 09, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Audio with digital channels, no audio with analog channels
I was getting a constant mono setting for all channels with no option to set it to stereo. I called Sharp, and they said that in order to receive stereo sound, you cannot use a standard coaxial cable. You need an S-Video or HDMI cable. This not only resolves the mono audio issue but also resolves the analog (vs. stereo) issue. Hope this helps!!
Feb 10, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Left speaker on sharp LC46D62U blown/not working
1ST YOU MIGHT WANT TO CONFIRM IT IS THE SPEAKER. IF YOU HAVE A HEADPHONE JACK ON THE SET PLUG INTO IT. IF THE LEFT SPEAKER IS STILL WEAK THEN YOU WILL HAVE TO REPLACE THE AV BOARD IN THE SET.
Jan 05, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos 46 In TV Problems:
Sharp list no issues or service tips for this model but I am sure most freeze ups are and issue of weak cable signals or defective cable receivers. If this has truly been elimnated the main digital pcb in the TV could be issue or more likely the TV may need the latest software upgrade. This is most likely only able to be facilitated by a Sharp auth. service center.
Dec 11, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Can't change channels!!!!
take the batteries out of the remote...now check if you can change channels manually on the big screen. if so the remote is stuck on one signal that channel u said. get a new remote. if still same trouble on big screen look hard at the buttons and make sure none are jammed. also try to get to your setup menu and auto-program the channels it should search everything and then try changing channels. new stuff alot times plugs come loose, goes back to the factory workers...not pushing them tight have a tech check that at your home.
Aug 18, 2007 | Samsung PCJ522R 52" Rear Projection...
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
344 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
