Question about Sony RDR-VXD655 Recorder
My remote suddenly stopped working.
I have three different identical Sonys, each assigned to a different remote. One of them stopped working, and when I tried to reassign one of the other remotes to that machine the second remote stopped working. I tried to reset the machine and the remote to the factory settings, tried to unplug the machine, making it think that it needed to be set up from scratch, but no luck. How do I reassign these remotes? Do I need to buy replacements?
If you're seeing on the LCD of the DVD player something like "DVD1" every time you press a button on the remote, try this: Change the command mode of the remote to match the player. Do that by holding down the Enter key on the remote and pressing the respective number. In my example above, hold Enter and press button 1 to set the command mode of the remote to DVD1. I had this problem and even unplugging the player didn't help, but the above worked for me.
Posted on Aug 25, 2009
  • msemaj Nov 23, 2010
    I did this procedure a bunch of times. I did this with 1-800-tech support and Sony's online chat support. I was even asked to replace the batteries with good ones. System Menu couldn't be chose until I again tried the manual method of changing the command mode and accidentally rotating the remote's batteries. Then the lcd displayed DVD 3. I was then able to get into the System Menu.
Comcast remote: all of a sudden channel input is slow
Unplug the cable box from the wall socket, wait a few seconds, and then plug it in again. I've heard that this solution works.
Feb 28, 2010 | Televison & Video
Two identical Sony cameras are giving terrible photos.
Actually, it probably is the lighting. The Canon's auto white balance just did a better job of adjusting for the lighting. If you work with the white balance control on the Sonys, they will be just fine. Practice, practice, practice.
Feb 22, 2010 | Sony Cyber-shot DSC-W100 Digital Camera
MY PS3 WORK FINE WITH A/V CABLES BUT DO NOT WORK WITH HDMI CABLE. I TRIED THREE DIFFERENT HDMI CABLES
most of the time i know that you are using a hdmi cable which caxn be broken and not from a good company or the tv has compatiblity issues ttry using sonys hdmi it will work
Dec 31, 2009 | Sony Playstation 3 (PS3) Console
Locked out of the menue ,Need to reset command mode
Indeed, I did the same thing.... I did find the answer in the manual!
Here's a copy of it (pg 23):
Set the command mode for the remote so it matches
the command mode for the recorder you set above.
1 Hold down ENTER
2 While holding down ENTER, enter the
command mode code number using the
number buttons.
Command Mode Code number
DVD1 number button 1
DVD2 number button 2
DVD3 number button 3
3 Hold down both the number buttons and
ENTER at the same time for more than 3
seconds.
4 Let up, press RETURN, all done!
Jul 28, 2009 | Sony Televison & Video
Hp laserjet1300 paper starts to feed the suddenly stops
I would suggest taking the Fuser out and inspecting the paper path for any small debris or paper remnants that my obstruct the path.
Aside from this, I could be the rollers themselves slipping, I would suggest inspecting them for any gloss or smoothness. A good roller should appear almost old-looking as in wrinkled and should feel rough. You can get more life out of old rollers by hitting them with a Brillo pad, though this is not a guarantied fix and can ultimately ruin the roller.
If the paper never leaves the tray, it is most likely the roller right in the front of the tray and/or above the tray in the back. Three, possibly, four are involved. It may be helpful to simply switch positions with the two, or three, that are identical. Their are only two types, and there should be at least two of each, but I am not positive of this.
Let us know what you find. Hope this information has been helpful.
Apr 28, 2009 | HP LaserJet 1300 Printer
Remote Keyboard and Remote Control have stopped workinh
1- Check all batteries and check all switches sometimes adjusting the switches to a different channel position helps.
2- There usually is a button on all three items, mouse keyboard and transmitter press all three.
3- Re-install drivers usuing a corded keyboard and mouse
Apr 25, 2009 | Microsoft Keyboard, Remote Control
Remote not working
There are two causes of remote not functioning, first the eye of the remote is loose contact you must resolder it so it become firm and second the crystal it is a square shape look a color of yellow or blue with the number 500,512,513 whatever the number you have replaced it with identical number.To check the remote if working or not ,try to get a cellphone with camera ,then open the camera then align your remote under the cellphone then push the button of your remote see to it,if it glowing in the camera when you are going to push remote button,if it is glowing then your remote is fine if not then still defected. Try this to find the result.
Hope it may help you;
Regards;
VOTIT
DON'T FORGET TO RATE
Jan 08, 2009 | Televison & Video
Remote stopped working
original remotes of the unit don't require codes. check the battery, otherwise try using universal remote where codes are required for different models
Oct 15, 2008 | Samsung Televison & Video
My Sharp Remote Control Is Suddenly Stop Working
Ok I just dealt with the Sharp customer support for this problem.
1) You need to unplug the TV for 1 full minute and remove the batteries from your remote aswell (this will reset the system)
2) Hold the power button on the remote for 30 seconds with the batteries still out of the remote and the TV still unplugged
3) After the 30 seconds replace batteries then press every button on the remote beginning with the power button in order from left to right and top to bottom (same way you read)
4) Then plug your tv back in and try the remote again.... and the remote and TV should be back in sync.
Aug 03, 2008 | Televison & Video
Open Questions:
Sony RDR-VXD655 Recorder Logo
244 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
