SOURCE: KM-3035 scanning issues
the 30/40/5035 series machines have two network cards in them. One for printing and one for scanning. and they have separate IP numbers also. make sure you have scanfile utility running on your pc or wherever you are sending the files and the folder set up in the utility. then set it up on the scanner network card.. Not the printer.
SOURCE: not getting faxes
Press the fax button....look in the tabs to set machine to auto-receive.
press ON HOOK and listen for the dial tone.
SOURCE: Kyocera KM-3035 System Error C0240
this is a printer error
it sound like you tried to update the printer firmware with an unzipped file from an incorrect print system
you need to format the cf card on the PC first then you need to format it on the printer, you will see the card option when you go into the user printer menu. it is print system U
SOURCE: Kyocera-Mita going offline
it sounds like there is an ip conflict... you may need to reserve an ip address just for the copier or failing that change your copiers ip address to one below the ip range... if it still has problems then I would check the network cables.... and see if you get any error codes... copier can go offline if 1. the print card is loose... bad mounting socket on the main board... ip conflict... someone else has the ip address... poor network traffic... the signals over the network cables are degrading too fast... so the copier gets a corrupt file or unfinished file and bombs out... power surge... this causes firmware corruption and the thing just starts shooting wierd error codes... I think I have given you enough to think about...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
SOURCE: km-3035 (kyocera) send email from scanner key,
The E022 error indicates - The mail contained an e-mail address that the SMTP server can not find. Check to make sure that the destination e-mail address was entered correctly.
The link below will take you to the manufactures web page where you can download the Scan System Operation Guide (Function Edition which list the error codes.
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=11796&rid=14242
If you continue to have a problem you can go to www.gfbm.net for more assistance, also they have some Kyocera setup and troubleshooting information.
I hope this is helpful,
Shawn
