Question about Radio Communications
I forgot how to reset my pro 99 scanner any
I forgot how to reset my radio shack pro 99 scanner / any tips welcome.
  • 25 Answers
This link to the owners manual should contain the info you are looking for:
support.radioshack.com/support_electronics/doc72/72815.pd
Posted on Jul 16, 2009
How do you replace/update scanner race frequencies on pro-99 scanner? do i set back to factory specs? i have winn-99 to help for frequencies. is there a web site to download frequencies directly to win 99...
There's no need to reset the scanner -- entering a new frequency into a selected channel automatically deletes/overwrites the old information. You should be able to download directly from www.RadioReference.com.
Need the manual for your scanner? You can download and print it, at no cost, here:
http://support.radioshack.com/support_electronics/doc72/72815.pdf
Bill B.
Listening in - professionally - since the 60's
Mar 11, 2011 | Radio Shack Pro-99 Handheld Scanner
How to re-set to original programming ?
To RESET your PRO-2096:
- Power the scanner OFF.
- Power the scanner back ON.
- Insert a pointed object (paper clip end, ballpoint tip, etc.) into the RESET opening on the back of the scanner and gently press the button inside.
If the RESET does not clear your problems you may need to INITIALIZE the scanner. Instructions for this procedure are on page 77 of the scanner operating manual. If you need a copy of the manual, you can download and print it, at no cost, here:
http://support.radioshack.com/manuals/ome20-496.pdf
Bill B.
Listening in since the 60's
Jan 25, 2011 | Radio Shack Pro-2096 Base Scanner
My radio shack pro96 back belt clip broke. where can i find another one to replace... thanks
Hi, my name is John. Welcome to FixYa. You can get it at Radio Shack for a little of nothing. good luck and thanks for choosing FixYa....John
Nov 02, 2010 | Radio Shack Pro-96 Scanner
Unlock my scanner radio shack PRO 2055
Hi,my name is John. Welcome to FixYa. Hold down the L/O button until you hear it beep twice, then all channels are restored. good luck and thanks for choosing FixYa. John
Oct 27, 2010 | Radio Shack Pro-2055 Base Scanner
Need to do a master reset on pro 84 sanner but don't have manual
To RESET the PRO-84, turn the scanner OFF, then hold in the 2, 9 and HOLD keys and power the scanner ON. The word CLEAr will appear on the display to confirm the RESET.
While the manual for the PRO-84 has not been posted by Radio Shack, it is essentially a red PRO-83. You can download/print the 83 manual here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/RadioShack-OlderManuals/Pro-83/pro83.pdf
For a comprehensive database of active frequencies in your area, visit:
Bill B
May 19, 2010 | Radio Shack Pro-84 Handheld Scanner
How to reset radio shack pro 97
As soon as the Scanner is turned on press the keys 0 and 1, this should reset it back to factory settings.
Here http://wiki.radioreference.com/index.php/Pro-97 is a link to a Wiki page about your Scanner.
May 14, 2010 | Radio Shack Pro-97 Handheld Scanner
Scanner problems Its stays on Auto-Scann and buttons dont work
Resetting or initializing the scanner may clear your problem.
To RESET the scanner:
- Turn the power OFF, then turn it ON again.
- Insert a pointed object (paper clip end, ballpoint pen tip, etc.) into the RESET opening on the side of the scanner, then press and release the button inside the opening.
If the above doesn't clear the problem, try the more drastic INITIALIZE procedure. NOTE: this step will erase all data that you have programmed into the scanner and restore it to original factory settings. To INITIALIZE the unit:
- Turn the scanner OFF then ON again. The scanner briefly displays the DSP boot version, then "Welcome to Digital Trunking" displays.
- Press "0". The scanner displays "System Tests Select Test Exits if no Key Press"
- Press "1". The scanner displays "Factory Unit Erase Memory ENTER if Yes CL to Exit"
- Press ENTER. The scanner displays "Initializing Clr Main Mem V-Scan is OK Please Wait"
- Do not power the scanner OFF until INITIALIZE is complete. When the process is complete the scanner will display "M0000" on the top line and "Bank 0 Ch 0" on the bottom line.
If neither of the above steps works for scanner I recommend that you take it to your nearest Radio shack and arrange certified repairs.
Need the manual for your scanner? You can download/print it here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/RadioShack-OlderManuals/Pro-96/pro96.pdf
For a comprehensive database of active frequencies and systems in your area, visit:
Bill B
Apr 21, 2010 | Radio Shack Pro-96 Scanner
Clearing out old channels on a radio shack pro 95 scanner
Turn it on, and when "Welcome" appears, press zero, then press one. It will display a message indicating it is initializing to the factory state.
Mar 21, 2010 | Radio Shack Pro-95 Handheld Scanner
Radio Shack Pro-508. The lock out key and program
Need to do a hard reset, turn power off, then back on. Hold down [CLEAR], press the reset button on the back then release [CLEAR]. I found it in the manual for the Pro-2018.
Oct 17, 2009 | Radio Shack Pro-2018 Scanner
Radio Communications Logo
171 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
