Question about Dual Electronics CECT P168 Cellular Phone
I68 phone won´t turn on. Charging shows as usual.
My i68 stoped working and it wont turn on anymore.
I plug charger and shows normal charge and then completed charge.
My pc doesn´t show unit either when plugged in.
It wasn´t damaged in anyway.
Hope you can give me some light on this issue.
Thanks.
Claudio
I have the same problem
Posted on Jul 16, 2009
Iphone wont charge
The battery might be damaged, but in most cases you can just let it be plugged in like you normally do. It doesn't show "recharging" because it has been too drained.
Turn on your phone after 15 min. in the charger.
If it still doesn't work, then you have to ask a store that supports Iphones.
Aug 06, 2014 | Apple iPhone 4S
Tip
How do you fix your phone if it wont charge? ...
All you need to do is shut down your device, remove the battery if possible and use something small, such as a toothpick, to 'lever up' the little tab inside the USB port on your smartphone or tablet. Do so very carefully and gently, then reinsert your battery and plug it in again.
or this.
  1. Turn the phone off.
  2. Remove the battery.
  3. Wait 10 seconds.
  4. Plug in the charger.
  5. Insert the battery.
  6. Turn on the phone.
How to fix phone that won charge properly AndroidPIT
SOLVED Why won my Samsung Galaxy II charge Samsung Galaxy II
How to fix phone that wont charge
How to fix Samsung Galaxy S6 that not charging Troubleshooting Guide
Why is my Samsung charger not working Google Search
on Dec 12, 2017 | Samsung Cell Phones
HP 584037 battery not charging anymore, the yellow light turns white or switch off after just 20s - and the PC does not work either just with the charger. Still , the charger delivers normal tension -...
sometimes you can take the battery out and put it back in (Re-seat Battery) or the cord on chrger could be broken inside near the plug some computers wont recognize and deactivate charging if there is a short in the charger could just be the battery is bad if it has been progressively getting worse
Jan 01, 2014 | Computers & Internet
Phone won't come on
my name is Larry and i have the exact same phone. If ur lg isnt turning on and wont charge it could be couple things . either the charging port on ur phone needs replaced and or ur charger has gone bad i would take it to a cell phone repair shop close to you.
Mar 25, 2013 | Net10 LG Optimus Logic Cell Phone
My samsung rant wont charge. it charged yesterday but today after plugging it into the charger the Samsung name lights up and then it says "low battery please charge" but it wont charge, i did drop it in...
Phone not charging.
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Aug 10, 2010 | Cell Phones
NOKIA 6600 wont charge and turn on
hey,
how about check your charger .. maybe there is a problem with your charger... try another nokia charger
Cheers
Aug 28, 2008 | Nokia 6600
Motorola A1200 Problem
Easy step by step solution!
Hey guys had the same, Try this solution before buying a new battery/charging cable (it might not be the problem):
I did these steps after playing around with it for awhile and am at the stage where my phone turns on fully and says "Battery Charging" when plugged into the charger. It is now charging normally again... Finally! (I had the flashing moto logo too when charger plugged in) I believe this problem occurs because the battery is completely drained and is unable to turn on to charge bcuz the phone needs to be on to be charged, happened to me because i left it in a jacket pocket and forgot about it for weeks. Anyways...
1. You need a USB data cable for it, it should have come with the phone, if not than any USB data cable that fits the phone's charging slot should work (charge cable for the ps3 controller will work or maybe a cable from a digital camera with the same end)
2. Connect the phone to your computer via the USB cable and a USB port that works. Make sure it's plugged in and leave it (even if nothing happens and the screen on the phone is still blank). Although the screen is black, the phone is still charging via your computer (it's just too low on battery to produce the light on the display screen to load up your phone).
3. This might take anywhere between 15 and 45 minutes so be patient and leave it plugged in, beats buying a battery of charger with your money for something that can be solved for free.
4. At some point your computer will make the usual processing noises signalling that it is finally recognizing the phone as a usb device and shortly after your ming's screen will turn on stating that the battery is charging. Success! One of two things will happen, if you have previously installed the ming's drivers to your pc it will just recognize the phone. If you are like me and do not have the drivers installed, you may choose to do so via the cd that came with the phone or just not do it at all.
5. If you want to just charge it via the computer then congrats, your job is done, just leave it plugged in and wait until it is fully charged. If you wish to switch to your regular outlet charger please proceed to step 6.
6. At this point drivers installed or not, either safely remove device from the computer or just unplugg it. Now return your phone to your usual outlet charger making sure its connected. When plugged in you'll notice the moto logo appear (no longer flashing). After about 5 seconds that logo will disappear. At this time flip open the phone. The usual turn on sequence will play out and it will now load up with the battery charging screen similar to the screen from when it was plugged into the computer. Congratulations your phone should be back to normal now.
NOTE: This charge will take longer than your normal charging time but that's just for this time since your battery is super low it will be back to normal after that. Also if this did not work for your phone then now is the time to see if the charger/phone/battery is the problem.
So I hope this helps you out and eases your state of panic. I hope I saved you guys some money with this solution and that your mings are up and running again. I know i was pretty content when the problem was fixed. Please reply with any comments, questions or concerns you may have. Enjoy your once again working mings.
Jan 24, 2008 | Motorola Mobility MING A1200
Motorzor
you simply fried your battery by overcharging it. Just get a new one, let it fully charge and fully die twice before you start normal charging. Then you will want to only charge it for about 2 to 3 hours or find a charger that has a smart chip that tells it when to stop charging once the battery is full.
May 13, 2007 | Motorola Mobility RAZR V3
Dual Electronics CECT P168 Cellular Phone Logo
483 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
