Question about Coleman Roadtrip Grill LXE 9949-750
Orange flame comes out of left side burner
1 year old coleman model 9949-750 grill was working fine one day and the next day I had only an orange flame on the left side. Right side works perfect. Phoned Coleman and they said must be the regulator and that is not warrantied. Should take it to the nearest Coleman service center (3 hours away!) I called the company that supposedly deals with these and they told me that they don't really repair them just sell parts (really only the regulator). I don't think it can be the regulator because it feeds both sides and one side works fine. I tried to blow out the tubes in case there was something blocking and this had no effect. Any suggestions?
I blew out left burner with My air compressor, now it works like new.
Posted on Sep 11, 2009
  • 32 Answers
Try cleaning the orfice that feeds that tube sometimes you can get debris in the lines when changing tanks that can clog them or the valve itself.
Posted on Sep 04, 2009
Testimonial: "I had done all that and nothing was working. Finally just decided to keep using and after awhile it was working great again"
How can you clean the burners on the colmanroadtrip gas grill
Yellow flame is blocked burner clean out with Air line ,or wire brush ,prick out burner holes .
Aug 10, 2014 | Coleman Roadtrip Grill LXE 9949-750
Orange flames on two Blue-Flame heaters, dual fuel, currently running propane.
Could be that the burner needs cleaning dirt in the burner tubes
Nov 02, 2012 | Blue Flame Heating & Cooling
Left flame has orange flame.
From what you described, it sounds like the burner's venturi valve is clogged. Probably by a spider's nest. Remove the burner and clean it.
Hope this helps and Happy Grilling. Thanks for choosing FixYa.
Jul 30, 2011 | Coleman Roadtrip Grill LXE 9949-750
Hi my coleman 533 has orange flame not blue it has good pressure i have taken jet of end of generator and cleaned it
Orange or yellow flame is usually an indication of too much fuel, or not enough air mixture. Make sure all areas where burners would receive air from, are cleaned of spider webs, debris etc., and be sure when set up, nothing is close to it that would block that air flow from entering.
May 27, 2011 | Coleman 2 Burner Dual Fuel 424-700G Grill
We have a spirit grill with 3 burners. I can light the grill, but burners 1 & 2 don't have a nice line of blue flame like burner 3. Burner 2 is especially bad with orange flames on the right and left...
Are you sure there's adequate gas in the tan? If so do the following:
Disconnect the LP tank from the grill hose. Wait 5 minutes and reconnect to the tank. Open the tank valve VERY,VERY SLOWLY, until it is full open. Light your burners individually and turn to highest flame setting, before lighting the next burner and so on.
If that solved your problem GREAT. Remember to turn the tank on that way in the future.
If it didn't you'll need to remove the burners and clean each one.
Hope this helped to get you back up and grilling again.
Feb 18, 2011 | Weber Spirit? E-310 Propane Grill
My grills right burner flame is strong and orange an has a strong gas smell.The left burner is fine. Whats the problem?
The hole for the air to enter is plugged with ****...take it apart and clean it out...
heatman101
Aug 18, 2010 | Grilling
Side burner on propane gas grill burns with orange flame ratheer than blue
here is a link to a page that shows what the colors of the flame should look like and what causes the orange instead of the blue flame. http://www.appliance411.com/faq/gas_range_flames.shtml
I would begin by checking to be sure you do not have a spider or a cob web in the burner partially blocking the gas or the air intake.
May 12, 2009 | Weber Gas Go-Anywhere Grill
Burner flame on GE 5 BURNER cooktop (JGP637) is orange
You have trash, corrosion or a mis-aligned part.
Check and repair these and you will be fine.
Feb 20, 2009 | GE 36 in. JGP628 Gas Cooktop
Flame problem
check the holes the flames come out of, they may be clogged, you may need to clean with a wire brush, if rusty then replace the burners. easy to replace
Sep 25, 2008 | Thermos QuickSet 462836203 (LP) Grill
Coleman Roadtrip Grill LXE 9949-750 Logo
614 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
paulcarew
Raymond Ramirez
Raymond Ramirez
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
