Question about Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2 OHMS => Model PV2000 Car Audio Amplifier
Problem with the setup of the mono bi amp feature using peaveys cs3000h amplifier
I setup in mono bi amp mode to power my 118 subs along with 2 other speakers for the mid/highs and on the crossover setting the dial has to be at 40 hz to get noticeable response from the subs. This setting should be around 125hz or higher. The setup is exactly as the manual shows. It appears the crossover is backwards from what is normal. Any thoughts??
This amp is relatively new. It says on the cover its a cs3000h
  • 32 Answers
My recommendation would be to double check the back of you crossover and make sure everything is hooked up correctly. If you crossover is convertible like my DBX223 xl is from Stero to Mono and Three way to two way the connections on the back changes roles.
Posted on Jan 27, 2010
Well I have a Peavey pv10 mixer. I'm going out of the outputs on the mixer to my amp. Then the outputs on the amp go's to my main speakers. I'm not sure where to add the powered sub. If you need more info...
The easiest thing to do is add an outboard crossover; something like a Rane AC 22S. Set the mode for stereo 2-way & mono sub out. L & R mains out from the mixer to the crossover, mono sub out to the sub and high out's to the full-range speakers.
Oct 12, 2013 | Peavey PV10 USB Mixer
How do I wire up my 4subs in bridged to my peace 2600
Please state the subs impedance, but assuming 4 subs with 8Ohm Voice Coil you CAN'T run them in parallel in Bridge Mono because this amp's minimum impedance is 4Ohm in bridge and 2Ohm stereo, maybe a series/parallel connection work, but what's the advantage to run them in Bridge mode? This amp delivers 900W per channel at 4Ohm, you can run a pair paralleled for each channel in a safe way and without the high-risk of your amp being destroyed, besides, amp power at 4Ohm Bridged is NOT recommended for continuous use, let me know your results...
May 13, 2012 | Peavey Pv 2600 Power Amplifier
I have an old soundstream reference class a 5.0 and a set of mb quart pwe 254 10 duel voice coil subs. i would like to know how to wire this set up for the most power. parrallel the voice coils then run...
The Soundstream Class A 5.0 will deliver its full power at 1 ohms mono.
I think your subs are two dual 4 ohm voice coils.
If you wire the voice coils for each sub in PARALLEL, that's 2 ohm for each sub. To get 1 ohm mono, you need to hook up the subs in PARALLEL to the amplifier, in bridge mode. That's the way to get to 1 ohm mono. Please add a fan to your setup as the amplifier will get very hot. You will need to use a relay to hook up the amplifiers and fan(s) to or you will damage the remote ouput of your HU (if you hook up the fan straight to the remote of the HU) as the remote output of the HU is not designed for the amount of current a fan draws.
Good luck. If you need help with the relay issue, have a look here:
Jun 27, 2011 | MB Quart PWE-254 Car Subwoofer
I have 2 peavey sp 5 and a pwavey 2600 amp . i wanna know can i hook a peavey 118 passive sub to one of the sp5 and how would it sound?
You would send high as well as low to the sub and unless the sub had a built in crossover it COULD get muddy sounding. The specs SEEM to indicate the 118 DOES have a low frequency crossover so it SHOULD be OK... How would it sound? An 18 inch sub normally adds to the sound of a system... You MAY need to PAN over to send more power to the one side with the extra load on one side. Often people use two sub's... one for each side so it is balanced.
Jan 19, 2011 | Peavey SP5 2-Way PA Cabinet (800 Watts, 15...
Hello, What is the proper way to connect an Ashly XR1000 Crossover and a Pyle Pro PTA1400 power amp to my Peavey XR8600 so I can use 2 subs? The subs are not powered, but do have a passive crossover...
Here is a link to the manual: I didn't look at the manual for the crossover but this is probably the way I would do it. Look at page 13 in the manual : Come out of the Main out (31 in the diagram) into the main in of your crossover. Go out of your crossover Hi and Mid out setting back into Power amp In 1 (labelled 32 in the diagram). Hook your speakers that you normally use to the output jacks on the back of the Peavey. Make sure you match the output impedances. Go out of your crossover low output into the Pyle power amp and out of the Pyle into your subs. Make sure the impedance ratings of all your speakers match the output impedances of your amps. You will only be running in Mono mode as that is the signal output of the Peavey mixer. You can run faux stereo by using the Main monitor Out as 1/2 the pair and the Main Out as the other 1/2 to both channels of the crossover but you won't be getting a true stereo pan mode.
Aug 22, 2010 | Peavey Xr 8600 8 Channel Powered Mixer
How do i connect my pv2600amp to my peavey subs and top speakers, i have the leads but what do i do?
Line outs Left and Right from mixer to power amp Left and Right inputs,
Power amp outs to Subs(if they have passive crossovers built in check specs on subs).
From Subs then to Main spkrs. Make sure power amp is set in stereo mode using this way.
Alternative: You will need at least a 2-way stereo crossover unit inline after mixer and before power amps if the subs don't have a built in passive crossover. Most of them do have passive crossovers in the subs these days. Then separate amps or one channel would drive the subs and the other the main speakers. True stereo would require at least a 2 way crossover and two stereo power amps if hooking them up this way.
There is another option as is common with many sub setups. Send the signal to the mains using L/R outputs from mixer and a separate Mono output to the subs only. Putting only bass/kick and low frequency outputs in this send would help too.
Oct 13, 2009 | Peavey PRO-12 (00497070) Main / Stereo...
How would i conect a ep2500 amp two 2 subs @ 4 ohms, or 8ohms
hey" i got 2 behringer 2500 amps and i have 2 peavey speaker that are 4 ohms 2000 watts eachand want to mono the amp separte,and i want to run 1 amp to each speaker so can you help me?
Nov 26, 2008 | Behringer EUROPOWER EP2500 Amplifier
This will depend on the amplifiers capabilities.
I will give 2 different scenarios.
#1 Stereo configuration
If the amplifier supports an RMS power output close to the RMS input power of the subwoofers then run the amplifier in stereo mode. For example 150 watts RMS X 4 channels driven at 20-20khz. (If you can provide a model # for the subs and the amp your looking at I can help you further with this decision.
Wiring for this is easy and simply involves matching the connectors for 2 of the channels (Front or Rear) to each of the subwoofers.
#2 Mono Bridged mode.
If the amplifier is lower power but mono bridgable you can bridge two Pairs of channels and power each of the subwoofers this way.
Generally speaking a 2 channel bridgable amplifier will be able to at least combine the wattage of each channel into a single monural channel and in many cases its actually higher.
So you would bridge the front 2 channels into a single bridged mode for one subwoofer. and then you could bridge the read 2 channels into another bridged mono channel for your other sub woofer.
For example if you had bridgable amplifier thats 50 watts RMS X 4 you coudl very likely (Generalization based on quality of amplifier) send 150 watts RMS to each subwoofer.
Again I would need to know what amp you're refering to to provide specific wiring instructions. Many Bridging amplifiers either have a single switch that will send them to bridged mode or you would use the positive + terminal from one channel and the negative - terminal from the other channel or a combination of both.
Sep 17, 2008 | Kenwood 12" 4-Ohm Single-Voice-Coil...
Proper mode settings
Hi bongodboss
The user manual for this amp has good instruction on how to connect it. You can download a copy from here.
Page 9 has info about using the amp for "bi-amping" The amp is only a stereo unit, so to do a 3-way system, you will need at least 1 amp mono in bridge mode for lows, and other stereo amp for mods, and another stereo amp for highs. You could use the internal low pass filter for the bottom end, and a 2 way crossover for the mids and highs. Much simpler doing a 2 way system with composite bins for mids and highs, and subs for lows. You only need the 2 amps and use the low and high pass filters inside the EP2500. If you need anymore help on this, I am happy to talk to you more.
Jul 10, 2008 | Behringer EUROPOWER EP2500 Amplifier
Car Audio & Video Logo
93 people viewed this question
Top Peavey Car Audio & Video Experts
Tom Chichester
Are you a Peavey Car Audio and Video Expert? Answer questions, earn points and help others
