Question about Ricoh Aficio AP3800C Laser Printer
Error message keeps showing to "reset black toner".
Error message keeps showing to reset black toner. The toner is already in place. What should I do now?
    Sergeant:
  • 157 Answers
Try to reset the toner by taking it out and putting it in again.
Posted on Jul 16, 2009
How do i reset ricoh sp 1200s drum unit
why toner life end message keep on showing on sp 1200s prints.
Aug 04, 2012 | Ricoh Office Equipment & Supplies
Waste Toner Error Message For Samsung CLP 550
Dr. P,
Printer will display "Waste Toner Tank Full/Not Installed" error message if the waste tank is full of toner or not installed.
  • Open the waste tank door and check for the waste toner tank.
  • If the tank is full or not intalled, install a new tank.
If you have user guide, it will show you how to install the waste toner tank.
Sometimes you will also get this error message if the Waste Toner sensor is covered with toner powders.
  1. Remove your waste tank and look for the black plastic on the right side after removing the waste tank.
  2. You sould find small openings on each side in the black casing.
  3. Use Q-tips or thin cotton object to clean the inside the small opening.
for user manual just click here:
If this solution works, please don't forget to rate it fixya
For any more question just ask me.
Thanks
Iqbal
Apr 14, 2008 | Samsung CLP-550 Laser Printer
I am getting the Replace Waste Toner error on my Ricoh CL3000. I have already emptied and cleaned the waste container, and blew off the section of the printer I install the waste bottle onto, but I'm...
not a solution - but a problem... i emptied the toner waste bottle in my MPW2400 and a new error message appears...says there is no toner and it keeps dumping toner from the new cartridge until it is coming out of every orifice of the machine. What is that about?
Sep 06, 2011 | Ricoh CL3000E Laser Printer
Printer keeps saying to clean the corona wire. I cleaned it several times but the message keeps popping up.
To clean the corona wire in the brother laser printer, it said to remove the drum/toner assembly from the printer. This is very easy to do, you simply pull down the front of the printer, and press a small green tab down and pull. Then the toner and drum assembly will quickly come out.
After that, it says you must clean the corona wire by moving a small green square back and forth several times. It seemed kind of strange to me, but I did it anyways. In the upper right corner of the drum/toner assembly, there is a small green/blue square that can be moved back and forth. I did this several times.
I then placed the unit inside, and the error message went away for a minute. However it still wouldn't print and the error message came right back up. I was a bit frustrated since I have only owned this printer for about 2-3 months.
But then I realized something: The toner button had been blinking for about a month. I had already purchased a high yield black toner cartridge for the brother laser printer (Tn-330/TN360). I purchased it online, and had it stored for when I eventually ran out of toner.
I thought perhaps the error message had something to do with the old toner. Maybe it was out?? So I once again opened the front of the laser printer, and removed the toner/drum assembly. I pressed a green tab, removed the old toner, and then added the brand new high yield black laser toner cartridge. The whole process was very simple (you gotta love today's technology).
I then quickly "cleaned the corona wire" a few times again just to be safe. I re-installed the toner, and the printer was up and running. So apparently it will throw this error when you are out of toner. Now the printer is running great again, and I really like this printer.
If you are still using an ink jet printer, then you are living in the stone age. I was reluctant to buy a new laser printer, but now I love it. The toner only costs $30-60 and lasts for months. I print hundreds of labels out each month-just to give you an idea of how long it lasts.or get more information Call +877 889 6859 for detail.
Jan 04, 2011 | Brother HL-4040CN Laser Printer
I have M1522n laserjet Hp printer and keep getting error message 10.1000 supply memory error what does this mean
Hello I seen this not the net so you can gave it a go
The HP LaserJet 2300 toner cartridge has a smart chip on the top left side. This chip tells the printer when the toner is low.
Recycled toners do not or can not reset the chip, therefore when you use a recycled toner you may get toner low messages although the toner is good.
Also, you may get the 10.10.00 error. We have devised a work around to fool the printer into not displaying the message.
Place a stip of opaqe tape or paper or the chip. When the printer detects a non-standard cartridge press the green (go) button. It will then reset the LCD to Ready.
Found this info on a recycled manufacturer site.
Feb 12, 2010 | Office Equipment & Supplies
I have M1522n HP Laser printer and keep getting message 10.1000 supply memmory error can anyome explain what this means
Toner life end warning light. replaced with new toner/drum still error
To reset the sensor after installing a new toner cartridge follow these steps.
1. With unit powered on open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press "+" key 10 times until the display reads 10.
5. Press "SET" key.
6. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
7. Close cover and see if Toner Life End error message has gone.
Jul 28, 2009 | Brother DCP-7020 Black and White Copier
I am trying to reinstall the black ink cartridge to a hp2605dn and it keeps saying the error 10.1000
I found this info on the web for you, guessing you are using a recycled or generic cartridge:
Also, you may get the 10.10.00 error. There is a work around to fool the printer into not displaying the message.
Place a strip of opaque tape or paper on the chip. When the printer detects a non-standard cartridge press the green (go) button. It will then reset the LCD to Ready.
No guarantees but it seems plausible.
Jun 19, 2009 | HP Color LaserJet 2600n Printer
Error code 7410
Open the left side door, push in on the drum unit which is above the waste toner bottle until it clicks.
Turn printer off then on.
Jun 16, 2009 | Kyocera FS-2000D Laser Printer
COF36 error on a Bizhub C350
Hi
C0F36 error means abnormally low toner density detected Black ATDC Sensor. Check for the black toner and try reinstalling the cartridge if replaced already. And if the toner crtridges are empty then replace the cartridge.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Apr 21, 2009 | Konica Minolta Office Equipment & Supplies
Ricoh Aficio AP3800C Laser Printer Logo
513 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
