Sonim Xp1300 Core Ip-68 Toughest Phone Ever Build Logo
J
John DeLong Posted on Mar 01, 2016
Where can I get a user guide for an IP-68 Sonim cell phone?
Sonim Flip Phone Info Help
This is not a well known make or model but there is some help here.
https://www.google.com/search?q=Sonim+flip+phone%2C+keys+locked
Aug 27, 2022 • Cell Phones
The flashligt on my sonim x3 will not turn off even when the phone is powered off.
Send it back under warranty, it is faulty.
First though, try taking a picture with the flash turned on. It has worked for others.
Sonim XP3 - Sonim Technologies
www.sonimtech.com > products > devices > xp3
In mission critical situations, getting the basics right is everything. And for fast, easy and reliable communication, the Sonim XP3 is as dependable as they come.
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk03LD7E5zO0fR_9THIxwCdB8QNDoQA%3A1612128636957&ei=fCEXYLX0Odmo5NoPsaSu8As&q=sonim+xp3+flashlight+won%27t+turn+off
Jan 31, 2021 • Cell Phones
How do i transfer pictures from sonim ip-68 to my computer?
Using your data cable you can transfer photo on your computer
Dec 25, 2019 • Cell Phones
1helpful
HELP my new sonim locked me out while I was trying to create password.. My IMEI is 35169603-111206-3 Missing lots of work calls Andre Miller
All you need to do is contact your phone provider for an unlock code to this issue. If your unable to contact them, you may download an approved list from the internet to use while attempting to unlock the cell phone again.
On my phone i can hear the caller but thay can not hear me it is a sonim xp1
when you call someone and they don;t hear you,it means that the mouth piece which is located at the bottom of the phone and allows people to hear is faulty and will need to be replaced.
When you replace the mouth piece, people can now hear you.
Take care.
2helpful
How to unlock sonim xp1 mob phone.
Hello,the truth is that you can unlock the phone ,but you can't unlock all phone for free.The payment sites are very cheap you could try it out and see.You can the link below to unlock .
Note: unlock is not free, You will be charged to get your unlock code.
The only way by which you can get the unlock code for free is by calling your service provider and requesting for your unlock code.
If you service provider refuses to give it to you, then there is no other place where you can get a free unlock code.
Visit the links below if you are interested in buying the unlock code:
(hubpages.com/tag/cell+phone+unlocking/hot)
and
(mobileunlocked.com/mobile_unlocking.php)
Good luck.
3answers
How can i set my sonim phone so i can send and
Hi,am sure it's related to your sim card (network), not your samsung cell phone. In most cases, regarding mms messages, the problem is from the Service Operator. Have you tried the sim card on another phone? If not, remove the sim card, insert it on another phone and try sending a message from another mobile to you number, or you can do it in vise versa by inserting another sim card on your mobile.
If you can't receive mms messages even it's inserted on another handset, then you need to call the customer care of your Network Operator and tell them your problem, they will help you fix it immediately.
You can check the message center number, but I don't think it's very much important in your case, well, if you wanna try, just check the text message settings and verify that the message center number (which is currently in use) is the same number which is on another phone with the same network (the other sim should be of the same network in your area). If it's different, make the changes and save the settings. Also disable the "Receive Via" or similar settings.. (I can't recollect the exact settings as i don't have the same model with me, please excuse me for this.).
if the same sim card doesn't receive mms messages using another handset, don't bother to change the settings or to make any changes with it, first call the customer care and verify from them, you may make mistakes instead of fixing it.
Have a nice day.
CISCO IP PHONE 7941 -add background images (user preferences,
See Cisco's user guide regarding template modification and customization at http://www.ciscosystems.am/en/US/docs/voice_ip_comm/cuipph/7960g_7940g/7_0/sip/english/administration/guide/7960usrS.pdf
Top Sonim Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Sonim Cell Phone Expert? Answer questions, earn points and help others
