Question about Nintendo Wii Console
Wii bowling When bowling how do you remove the bar that tells you to raise the remote and hold B? Thanks Nancy
    Guru:
  • 155 Answers
This will only happen when you are a beginner.... Once you have played a few games it will go away. If you are playing as a guest the bar will always be there.
Posted on Nov 20, 2007
Bought nintendo wii last xmas and had played quite frequently. then after a break in play of a few mths the remote controls dont seem to be being picked up by the sensor. i chenged the batteries and still...
Hello there
Hold the Wii Remote upside-down with the buttons facing downward.
Tap the remote firmly against the palm of your hand three times to remove any dust sitting between the buttons and the electronic circuit board inside the remote.
Turn the remote upright and press one of the buttons. If the problem continues, Open your Wii Remote's battery door
Check that your Wii Remote contains two new "AA" batteries or a charged battery pack. Check that no corrosion is present on the battery's metal elements/connectors.
Use a cotton swab to clean the remote's battery element/connectors if corrosion is present.
Check that the Sensor Bar cable is inserted firmly into the back of your Wii gaming system. The Sensor Bar needs to be centered above or below your television so the Wii Remote can transmit signals to the gaming system.
Stand three feet away from the Wii gaming system/Sensor Bar.
Aim the remote and press any button to test the device.
If the remote is not working, stand five to 10 feet away from the gaming system and try the device. The Wii Remote works best three to 10 feet away from the gaming system/Sensor Bar.
Move any objects blocking the signal from the remote to the gaming system/Sensor bar--candles, other remote controls (TV/cable box) and wireless computer devices/cellular phones.
Also, if any sunlight is coming in through a window, close the curtains or blinds to keep the light from interfering with the remote's signal.
Turn off and unplug your Wii gaming system. Leave the unit unplugged for one minute. Plug the gaming system back in.
If the remote still aint working;
Turn the Wii system on. Press and hold the red "SYNC" button for 15 seconds when the "Health and Safety" screen appears on your television. The "SYNC" button is behind the small door on the front of your Wii unit.
Release the "SYNC" button. Remove the battery cover and batteries/battery pack from the back of your Wii Remote.
Press and release the red button located under the battery compartment. The blue lights on the front of the remote will blink
Press and release the "SYNC" button on the front of your Wii gaming system. The "Player" light on the gaming system stops blinking and stays on, the resetting process is complete
Oct 01, 2010 | Nintendo Wii Console
Can ball speed in Wii bowling vary from console/remote to another
Absolutely, every machine has slight differences, it maybe the setup and orientation of the sensor bar or maybe his carpet is a little more fluffy effecting the way you stand. Who knows? You have to expect that not every Wii will "feel" exactly the same every time.
Good luck, and have fun.
Mar 06, 2010 | Nintendo Wii Console
Wii remote not sensing
ahh. First im going to go threw the obvious:
1) Make sure that you see that little blue light on the WiiMote.
2) If you don't, try to sync it to your Wii.Press the red button under the little door on the front of you wii, at the same time press the button on the back of the wiimote.
3) make sure there are good battery's in it.
If that doesn't work go to this link: http://www.nintendo.com/consumer/systems/wii/en_na/ts/wiiremote.jsp
Feb 16, 2010 | Nintendo Wii Remote Controller
Can not connect wii remotes to console. I bought a new wii bar to solve problem, but the same result. Ultra sencer bar is the new one. Thanks!
open the sd card slot and hold down the red button then hold down the red button on the inside of the battery case and it should work.
Oct 30, 2009 | Nintendo Wii Console
WII Remote Problem-Since changing our TV to HD(Sharp Aquos
hi deborah, have you made sure the wii sensor bar position matches the wii sensor bar settings in the wii menu? have you placed the wii sensor in the same position as it was before? changing this may help, its not usually the batteries they tend to work well up until the wiimote switches off. hope this helps.
May 02, 2009 | Nintendo Wii Console
Wii remote will not follow command.
It's problem a radio interference, since the wii controller uses radio frequences to contact the device, try to resync the wii controller.
1. Turn the Wii console on and wait until the "Health & Safety" screen appears (don't press A).
2. Open the SD Card slot cover on the front of the Wii console, just below the disc drive, and press and hold the red SYNC button for 15 seconds. This will clear all synced Wii Remotes from the console.
3. Resync the Wii Remote by removing the battery cover and pressing the red "SYNC" button. Do this for all Wii Remotes you wish to use, and test for proper response.
4. If the steps above do not work, remove the batteries of the Wii Remote and leave them out for at least 2 or 3 minutes. Reinsert the batteries and sync the Wii Remote again. Test for proper response.
If after removing the batteries for several minutes, and resyncing the Wii Remote, your still unable to get the Wii Remotes to work, try syncing another Wii Remote if available.
* If another Wii Remote works, then your previous Wii Remote will need to be repaired.
Feb 09, 2009 | Nintendo Wii Console
Wii remote signal
try usin an other wiimote and is it is the same mabe u just need to buy a new one - click here
Apr 05, 2008 | Nintendo Wii Console
Wii remote controller not fully funtional
in baseball you have to hold it beside your head and in bowling you have to raise your WII control up and realese th B button(hold B button than do instruction)(not for the Baseball game)
Jan 02, 2008 | Nintendo Wii Console
Wii sprts bowling
All my friends have a bad habbit of doing this. Watch the instructional animation when it shows the instructions. This will help you. hold up wiimote hold B, keep holding B and swing back, then swing forward and release B button.
Dec 27, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
77 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
