Question about Technics SL-1210M3D Turntable
Very low volume from my technics sl6 even when tuner is turn up to max. volume.
    Sergeant:
  • 357 Answers
Hello, here are a few things to try and maybe solve your problem. Firstly as stated in a previous post, make sure the turntable is connected to the "phono" input of the amplifier. Depending upon age of the amp, you may have the option of selecting "mm" or "mc". Assuming you're using a moving magnet type p-mount cartridge and stylus (the sl6 uses a p-mount fitting as opposed to the half inch fitting in a headshell as seen on a technics 1210 or 1200 for example), select "mm" if that option is available. Now try.
If you have a more recent amplifier, some companies such as Cambridge, do not fit the "phono stage" card in the factory and it is an optional extra you need to purchase (even though there are a pair of rca phono sockets on the back marked up as "phono". Check to make sure you have a phono card or phono "stage" fitted.
Check also that you have not left your headphones connected or that you have not left an addaptor in the headphone socket as you will be hearing the volume coming out of the headphones rather than the speakers. If you have left a hedphone adaptor in the socket, you'll be hearing any "bleed through" in the amplifier's different circuits and possibly the noise directly from the cantilever.
Some amplifiers have a "speaker select" switch or knob or a "speakers on/off" selector. Make you have selected speakers on and if applicable, the correct set of speakers.
Also make sure the rca connectors are firmly in place at the back of the turntable.
Try all these out and let us know your results.
Best of luck
Posted on Nov 11, 2009
    Scholar:
  • 113 Answers
Hiya, first and foremost, is it plugged into the amps correct sockets? Turnatables have to in the PHONO (turntable) Any others , CD, AUX, MIC etc will not work. (sorry if that seems obvious, wasnt sure on the info provided)
If that is OK then check the stylus, probably requires a new stylus or/and cartridge.
Best of luck
Posted on Jul 16, 2009
My tablet sound is low even when i have my volume settings at the max
This may sound silly, bit do you have your tablet in a sleeve or cover? If so, check that the cover is not covering the speaker outlet(s) on the back of the tablet. If it is, a hole or slot cut into the cover over where the speakers are located should fix the problem.
By the way, a quick test to see if this is the proble is to operate the tablet with the cover removed. If the sound is now OK, it's the cover causing the problem. This happens more often than you might think...
Also, some tablet do have really poor audio systems and both low volume and low quality sound. Hopefully your tablet is not one of them.
Jan 01, 2015 | Tablets & eReaders
Max volume to low
Check the settings of the monitor for audio volume. Also check the individual volume control setting for the applications and system sounds. Or call ViewSonic technical support for assistance.
Jun 15, 2014 | ViewSonic Computers & Internet
No volume from turntable, even with volume turned to max, are ther internal fuses ?
You don't state which model the turntable is. Without this we are working blind. If the turntable has a built in amp then that will have failed. A blown fuse would shut down everything. If it has no built in amp and you have it connected to a separate amp, then you have either connected it to the wrong socket - it needs a phono socket - or if the amp doesn't have one you need a magnetic cartridge preamp.
Apr 12, 2013 | Audio Players & Recorders
I have a technics ST-X933L tuner as part of a separates system and the volume on the amplifier has to be turned up to almost full volume to be heard. All other inputs are playing at the expected volume for...
You can answer the question by jacking the tuner's outputs into any other Line Level input on your amp/receiver. If it's still low, the tuner is at fault.
BTW: NEVER use full volume as a test unless you intend to blow up your speakers.
Mar 05, 2011 | Audio Players & Recorders
The receiver is muted when playing in tuner or cd the volume is not coming through the speakers. We can hear it muted when turning up to max its very low. Lost instruction manual can you help. I think my...
I can't find a manual either. Can I assume you really mean the sound is muted for EVERY source, not just tuner and CD?
I'd guess it's either MUTED or a Tape Monitor is active. Turn the volume down, select FM as the source, tune a station and use it as your test source. Look around for indicators that give a clue.
NEVER troubleshoot anything with the volume control turned way up. You'll blow up or damage the speakers and your hearing right after you discover and correct the misplaced control.
Aug 15, 2010 | Nakamichi AV-2 Receiver
My sharp aquos has low volume
my sharp aquos flat screen has a low volume, even when turned up to max. how can i increase the volume
May 24, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Volume is too low, even then it is turn up to the max.
Have you looked at the menu on your cable or satellite box to see if there is a seperate volume control for the box?
Usually it is found under
Settings>>Audio>>STB Volume
Apr 10, 2009 | Sharp Aquos LC-37D43U 37 in. LCD HDTV
Speakers playing low
open the disc tray and press setup and the speaker volume option will activate and also turn off the night mode for louder sound
Dec 15, 2007 | Philips HTS3440/37 System
Erratic volume on Technics SU-X911 amplifier (Class A)
its the ic that controls the + and - voltage and there are capacitors that have leaked all the caps on that board need changing could be expensive and time consuming but its the age of it . if i was going to do that job £200 plus\
Aug 24, 2007 | Technics SA-DX940
Technics SL-1210M3D Turntable Logo
556 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
