Question about Refrigerators
The condenser fan runs, 30 second later the compresor kicks in then 20 seconds later the compressor turns off while the condenser fan is still running
  • Bruce Volkers
    Bruce Volkers May 11, 2010
    Have you inspected the condenser coils under the box and cleaned them if needed?
  • Refrigerators Master
  • 1,606 Answers
You have either a bad overload/relay or a bad compressor . Remove the o/r from the compressor and make sure there is continuity between all 3 terminals . Also check from the terminals to a copper line to make sure there is no continuity . If ok , then replace the o/r and check the amps from a wire to the compressor . If high amps ( 2.7 or higher ) then compressor may not have long left .
Posted on Jul 16, 2009
Duo therm rv air conditioner repair
Sounds like thermostat is failing. There is a factory set resistor that helps the thermostat keep a 2 degree accuracy. Second possibility is that you have a fan or direct airflow from the cooling system, being devirted, that is allowing the cool air hit the thermostat on the wall.
Aug 17, 2013 | Heating & Cooling
TSSU4812 refregirator making clicking sound and not cooling
Without a compressor analizer you will need to check the winding
resistance. or you can just cross your fingers and hope the relay
and start capacitor are the problem. Sounds like the condenser coil was plugged so you could possibly have a locked up compresor.I doubt it is low on refrigerant charge.
Jan 15, 2013 | True TSSU-48-12-ADA Sandwich/Salad Unit,...
I have a woods freezer model # V17NAB I defrosted it and after all cleaned ou I plugged it back in. The compressor kicked on but shut back off about 30 Seconds later and will not stay running. It turns...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 22, 2010 | Woods Freezers
I have a Maytag 2651HEW . Seems to be cooling and
Thant must be checked out soon as that buzzing sound is the start relay struggling to start the compressor. The longer it goes on without repair to either the sart/run capacitor, start relay and overload the higher the chance there is for complete compressor failure. The condenser and evaporator areas should be cleaned and inspect both internal freezer fan and lower condenser fan that both run without stopping. Let me look for a service manual for your model and return soon, Thanks, Sea breeze
Jan 10, 2010 | Maytag MSD2651 HE Side by Side...
I turn it on (montana 5th wheel) and it sounds like it's tryin to kick in the compresor that is and the fan comes on and the compressor tries to kick in about every 30 seconds but cannot?? it's about 4...
The compressor is trying to start and cannot because it is broken inside and will need to be replaced. The compressor can be replaced by most anyone that is familiar with working on home central air conditioning units. I have replaced a few compressors for units like yours. Have a professional check it out. It could just be the start capacitor, but usually it is not.
Nov 15, 2009 | Dometic Rooftop RV Air Conditioner
Constant clicking sound coming from power box amana fridge
When you heard the click and the compresor stops ,check if it's very hot , if yes the compresor is of on overload and this could happend because 1 the condenser coil is dirty ,2 the relay is bad or 3 the compresor has a problem .Also check if behind the kick plate there's a timer (some units have it there or next to the cold control ) that could cause a problem too.
Aug 23, 2009 | Refrigerators
Where can I get a wiring diagram for an under-counter Beverage-Air cooler. The condenser runs then stops after a few seconds. Figuring a bad relay? The power runs but the condenser kicks off immediately...
If it's the condenser fan you are talking about you will not need a wiring diagram. The fan should be wired to the compressor and the thermostat. the thermostat is the relay to start the fans and compressor. I will continue to look for a wiring diagram. When the fan wears out they will stop causing the cooler to overheat. I think replacing the fan would be what you need. I believe that Beverage Air used the Copeland compressor with the condenser fan mounted on the one end of the the same slide in compressor. Check your voltage on the 2 wires going to the fan. When compressor is on the fan should also be running. I just have the feeling that condenser fan is defective.
Sea Breeze
Aug 19, 2009 | Refrigerators
Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Aug 04, 2009 | Amana PTH123B25AJ Heat Pump Air...
HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
Aug 02, 2009 | Frigidaire Freezers
Ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
May 28, 2008 | Ruud Matching Split Air Conditioner
Refrigerators Logo
98 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
