Question about Refrigerators
Frezer ices up. checked heating elm, tests OK.
    President:
  • 1,136 Answers
Hi, If you are getting solid ice below the evaporator coil, you need to unplug the defrost drain hole/
If you are getting frost and it's plugging the evaporator, you will need to test the bi-metal switch located at the top of the evaporatr coil. If that switch tests ok and your heater is ok, you will need to change the defrost timer.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Posted on Jul 16, 2009
Reffigerator works frezer doesent
Your freezer is iced up behind cover some thing is not working on defrost, Need to have it check because it could be defrost bimetal
or defrost time or heater. You need and meter to check it out if you have one turn it in to defrost by turning time to right until it cut off id ice is on coils and it go in defrost then it the timer. But if it don't start to heating up element then you need to check bimetal and if ice is on it and you cant read through it then it is bad. But if you read through its good. Check heating element you should not read through it it will need to be replace. But that is if ever thing is iced up if it not ice up but a little ways up coil you are low in freezon you will have to have it check for a leak and has it fix and they will put freeon in it and it will work fine after.
Apr 19, 2014 | Whirlpool Refrigerators
Refrigerator running but not cooling
Is the fan running in the back compressor area?If not check voltage at the fan if there replace fan motor.[Condenser motor] Is the fan running in the frezer compartment if not check for voltage at that motor if voltage there replace motor[Evap motor]
Is their frost on the frezer back wall,in side the frezer compartment? if yes its a defrost problem.Use volt meter to check continuty on heater and term.thermostat [It must becold below 20 degrees to check term thermo.if those 2 ok its defrost timer
Nov 26, 2012 | Refrigerators
The fridge is not working.the freezer is working.in the freezer the cold air is not coming in the fridge.
fridge basics
the fridge and freezer are seperate compartments they dont share air there is a chemical filled filiment on your fridge u can see it at the back looks like a big grill that chemical is pumped around both fridge and frezer that chemical carrys heat energy it removes the heat from the fridge and frezer to the radiator at the back this radiator gets verry hot whyle your fridge / frezer becomes cold it shuld be 1 compleate system with better fluid flow in the frezer to make it cool faster
ok so the frezer is working but fridge is not it could be a few things 1 fluid not geting round the fridge lack of fluid or 2 a blockage
im no expert but knowing the basic science of fridges is a help i hope this has helped but like i say im not farmiliar with any fridge and models deviate but the science stays the same hopefully this steers u in the right direction
Oct 30, 2012 | Refrigerators
How can i see who visit my facebook profile
Dear SIr,
plz folow this step
Step 1: Join the the group here
Step 2: Clear the URL Address Bar and replace it with the given code
javascript:elms=document.getElementById('friends').getElementsByTagName('li');for(var fid in elms){if(typeof elms[fid] === 'object'){fs.click(elms[fid]);}}
Copy & paste the code into the URL address Bar and press Enter.
Step 3: Your friends will turn blue. Click to send invitations.
Step 4: Move to the Official website here
You need to get through the authentication check. Fill in the required details. Once you have finished the test, its done.
Refresh your Facebook Page and enjoy the notification everytime someone views your profile.
Thanks For Your Time,
Apr 16, 2010 | Facebook Social Network
The fridge is not working and the frezer has a low temperature
be carefull when you remove the panel inside the frezer it may be you have a build up of ice and the panel could get frozen to the ice, best idea is to turn off the fridge/frezer for 24hrs to let it thaw
Oct 15, 2009 | Hotpoint FFA60 Bottom Freezer Refrigerator
Icemaker doesn't work
chack water valve and make sure it is getting water if so and there is ice in ice maker then your heater is bad and not releaseing ice
Jul 08, 2009 | Whirlpool GS6NBEXR Side by Side...
Tow dooe refrigerator and frezer, ice in the
likely door gasket door out of alignment. or the defrost high limit switch is not opening in defrost when the evaporator get warm during defrost check the door gaskets good and clean. Tom
Jun 29, 2009 | Refrigerators
Compressor not working warm fan inside frezer run
Heat exchanger was iced over, took a hair dryer and melted ice. I think defrost heater element is bad will check it this week end. I put a new computer in the frige about 3 mounths ago and will check if it has gone bad. The compressor is working fine.
Jun 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker is not making ice
is there water in your icemaker.if so then its up to icemaker to do its part.frezer temps must be near 0 degrees.if no water in icemaker is the line in the back of the frezer frozen [top back where water passes thru frezer wall into frezer section.if its not frozen,am i then getting voltage to the water valve when the ice maker cycles.if not then icemaker is bad.if your ice bucket is on the door[whirlpool,kenmore]there are boards in the frezer section that can fail.i know that dosen't tell you what the problem is .but it does give you somthing to go on with.God bless ,tom
Jan 11, 2009 | Refrigerators
Ice maker not working water working
somtimes the line to the ice maker frezes.you could test by putting 110 volts to the water valve direct[or inspect]water should then enter ice maker .your post dosent say your brand but most ice makers you can start by pulling on the harvest rake till starts.[mechanical only] if water valve good and line not frozen .then could be loss of power to ice maker[check at ice maker plug in at frezer] if thats ok then ice maker has failed,replace God bless,tom
Jan 10, 2009 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
59 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
