Question about Polaroid FLM-3201 Television
Audio problem The audio is staticky, noisy, and loud on one channel (HG-46) the most watched channel in our house. All other channels are just fine except this. The sound is so loud, noisy, and has kind of static in it. Tried tightening up the wires, disconnecting, turning off the TV and then again re-wiring everything all over again but nothing works. Any help will be great.Thanks.
  • 44 Answers
Re: Audio problem
Is this problem only on one channel? How is the sound on other tv's in the house? You may have a weak signal on this one channel
Lou Margo
Posted on Mar 06, 2008
0 characters
3 Points
Interment or no volume on certain channels.
make sure set not set to sap mode as this can blank audio on certain channels
Sep 03, 2012 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
On one channel...PBS we do not get any sound. Sound is ok on other channels and works on the other tv in the house
This television must have the ability to broadcast channels in SAP. Look for an SAP or MTS or AUDIO button on your Sylvania remote. The audio menu might be the place to find this setting as well. You want to remove the SAP and have the tv in either mono or stereo.
Sep 01, 2011 | Sylvania Flat Panel Televisions
I have a 19" magnavox
Do you have a digital converter box. If not, you need to get one to receive the analog channels.
Feb 06, 2011 | Flat Panel Televisions
Channel 2 (cbs) is fine. There is no sound. All other channels are fine. What is wrong and where can I take to have repaired. The TV is a 20" Norcent. I am in Summit,NJ, 07901
All the tv channels,work find and have sounds wright?Only channel 2 don't?Is not the tv,it channel 2 have broadcasting problems.U check around ur house the other tv channel 2 have sound?Tries go into the tv menu.Goto Audio Setting,go down to resetting the audio functions,now it going back to the factory setting,if it is the tv,that will help.
Nov 25, 2010 | Norcent Technologies TV2001 20 in. LCD...
I have a sony tv and cant get sound on 3 different channels..the other tv in the house is fine
that's a weird one. You might check your audio settings to make sure it is not on SAP (secondary audio programming) sometimes that will cause lack of audio on certain channels since some have it and some don't
Jul 05, 2010 | Astar LTV-3201 32 in. LCD Television
32 " Sharp AQUOS LCD
Go into your Menu under audio, and look for SAP, then turn it off. ( Second Audio Program )
Oct 05, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Audio with digital channels, no audio with analog channels
I was getting a constant mono setting for all channels with no option to set it to stereo. I called Sharp, and they said that in order to receive stereo sound, you cannot use a standard coaxial cable. You need an S-Video or HDMI cable. This not only resolves the mono audio issue but also resolves the analog (vs. stereo) issue. Hope this helps!!
Feb 10, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
No sound on four channels while all other channels sound is fine.
You most likely have the SAP1.gif mode activated. Look for a button on your remote or an item in the on-screen menus of your television1.gif called MTS or SAP. You want to set this to "Main" "Normal" or "Stereo" (or even "Mono") mode to hear the regular television sound.
If it is in SAP (Secondary Audio Program) mode, as I believe yours is, you may hear no sound or a different audio program. Often this is a translation to another language, such as Spanish, and other times (notably with PBS stations) it is an unrelated audio (often music) feed. On some stations there may be no sound at all with the audio mode set to SAP.
Feb 14, 2008 | Sharp Aquos LC-13SH3U 13 in. EDTV-Ready...
Loud buzzing
check your connections again, if you have the audio and video reversed you will get this exact problem no video/ fuzzy video, and squealy noise out of only one speaker (other will likely sound correct) You're watching the sound channel, and listening to the video channel basically... hehe
Aug 14, 2007 | Zenith P42W46X 42 in. Plasma EDTV
Polaroid FLM-3201 Television Logo
76 people viewed this question
Top Polaroid Flat Panel Televisions Experts
Dave Naylor
Dave Naylor
matt martin
matt martin
Are you a Polaroid Flat Panel Television Expert? Answer questions, earn points and help others
