Question about Hand Tools
Piston of a ts400 cutquik saw is seized in the housing
I ran the ts400 stihl cutquik Without measuring the right amount of oil and gas mixture. I did cut fare amount of concrete. But than one day it seized..The piston in the housing is seized badly..What do I do?
    Sergeant:
  • 384 Answers
What did you expect? Find a engine rebuilder and get ready to spend about 75% of a new replacement.
Posted on Jul 16, 2009
Does not having oil in saw cause sawnot to work
Not to my knowledge.....but why would anyone take a chance on running a saw with no oil in it?
I "could be" that if someone else used it and they didn't run it with the right mixture ratio of gas to oil that "running it without oil" could seize up the piston......THAT would then cause the saw not to start.
Jun 02, 2014 | Remington Electric Pole Saw
Which way does the arrow point on a stihl piston ts400
the arrows on all pistons face to the front of the engine
Apr 19, 2014 | Stihl Ts400 Cut Off Saw Piston Cylinder...
Chain saw frozen, removed cord starter the engine wont budge even with a large screwdriver in the cooling vanes, a poulan
some one ran it with out oil pull spark plug spray in some wd-40 let sit for a few days then try again if it dosent move its scrape
Feb 15, 2011 | Homelite Garden
Saw starts but wont build up any power it fouled two plugs back to back do i have gas mixture wrong
sounds like a rich mixture stihl and huskvarna oil has the same makeup dealers have test tubes for warranty service that tells them what oil was used and will not warranty if wrong oil is used with the proper oil your saw will last for a long time cheap oil does not have the additives needed too keep rings free and inhibit carbon buidlup
Jan 19, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
How do you fix as carborator for saw that has gas mixed to rich one of my employees thought it would be good to mix it 8 ounces to a gallon
First pour out all of the old mixture. Put in the right mixture. Pour an ounce or two of raw gas down the throat of the carb or inject it wit an eye dropper.(what ever works the best. The raw gasoline will run for a few seconds but will not hurt the engine. Let saw run for a while until the blue/white smoke clears. Running a saw on too much oil mixture is much better than running it on too lean as that is the way the piston is lubricated. The problem with too much oil is that the oil is sticky and clogs the exhaust ports of the 2 cycle engine, but running it on the correct mixture should correct that.
Jan 06, 2011 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Does the TS400 need engine oil apart from 2 stroke mixture
Hello. No, the oil mix is designed to do all that is necessary. Stihl 50:1 two stroke engine oil or equivalent is recommended for proper operation, cheap oil does not have the additives needed too keep rings free and inhibit carbon build-up. Also do not use BIA or TCW rated oils, or any others with duel purpose ratings.
Thank you
Aug 22, 2010 | Stihl Concrete Cutoff Chop Saw Clutch...
What is the gas/oil mix for a mccullach chain saw?
to be safe without operator's manual or signage on the machine;
32:1
Nov 08, 2009 | McCulloch Garden
2.0 Cubic Inch Montgomery Ward gas chain saw, 10 inch cutting bar
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 3 months old use up in a 4 cycle engine. HTH
Lou
Oct 26, 2009 | Garden
Fuel Mixture Husqvarna 455 Rancher Chain Saw
Page 17 of your Operator's Manual says 50:1.
Fuel/Oil Mixture
  2. Most gas in the US of A contains ethanol; not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Sep 25, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Hand Tools Logo
201 people viewed this question
Top Hand Tools Experts
Don Numinen
Don Numinen
Ivan
Ivan
Level 1 Expert
Bill Boyd
Are you a Hand Tool Expert? Answer questions, earn points and help others
