Question about RCA RTD255 System
Confusion connecting my receiver to the RCA255 dvd receiver for cd use
Can I do this. I don't know what I am doing. I just bought an AVR 310 audio video receiver (harman/kardon) and I want to connect a cd player to it so I went to the local cash converters and got this RCA255 dvd receiver. Can I use this to play my CD's with my receiver or am I way off. Pls help.
  • 1,113 Answers
Re: Confusion connecting my receiver to the RCA255 dvd...
Ok is your cash converters purchase a RCA, RTD255 system or is the RCA255 you quote something else, I'll assume that we are dealing with the first, and that seems to be a All in one system that contains speaks amp etc
You also have your new AVR 310 which is amplifier that one would connect a stand alone DVD/CD player to, You wouldn't connect the cash converter purchase to it, it is a seperate system.
You could use your cash converter system alone without the AVR310 but not with it.
Posted on Nov 18, 2007
0 characters
3 Points
I am trying to connect ps3. (bought may 2012 with uncharted 3). To my denon 2313 via hdmi. No video at all or sound? Please help
You need to tell the PS3 to use the HDMI cable output. To test have you tried connecting the PS3 directly to the TV. Once you have that working then add in the AVR.
Jan 19, 2013 | Denon AVR-2313CI
Adding another device to the system
Well, if analog works for you connect the CD player's analog RCA cables to the VCR inputs.
Can you imagine why you NEED to have the TV audio coming into the receiver from the TV? Are the TV's audio system or speakers superior to the audio section of every other source of TV-related programming? We hope not. Does the TV receive any programming that the receiver can not? Maybe games. I imagaine this MIGHT justify running analog TV audio back to the receiver.
Your cable box and your DVD player have both digital and analog audio outputs. The gray area is what your TV has for audio inputs. It could survive with simple RCA analog audio in from both and none to or from the receiver. Then you could watch Lo-Fi cable and DVD's without the receiver turned on.
That would free up the TV analog audio input for other things.
I imagine your DVD player is using one of the digital inputs on the receiver. If you have one each optical and coaxial audio output among your DVD and Cable Box you could place them in the two available diigital inputs.
Now, what about the CD's digital output? For stereo music you're not likely to be able to hear any difference between it and the analog input BUT it can still be connected digitally IF it has a coaxial output. Coaxial digital inputs can be shared.
Get an RCA-splitter and join the two units entering the coaxial audio input just before they enter that connection. Either will work just fine if you TURN THE OTHER ONE OFF when you want to us it.
Mar 19, 2010 | RCA RT2760 System
Sound Problems with HD TV
This seems to be a problem that has to do with your HDMI audio output.
First check in your TV setting if audio out is selected on your correct HDMI port. Than check if your receiver is able to receive audio via HDMI (i assume you used the HDMI connection). Some receivers have HDMI IN connections but are not able to receive audio on it, the latest receivers/sets do have this feature. If your receiver doesnot support audio IN via HDMI you can only do one thing, connect the stereo audio-out of your TV to an AUX IN connection on your receiver.
Jan 18, 2009 | Samsung HT-Q100 System
Audio playback
1.bad rca jacks
2.could be connected to wrong audio lead rca jack
3.the settings in dvd player donot match the receivers example- dts or ntfs
4.make sure its regioned to your player some audio isnt on the disks
5.pc's usually have new cd formats that came out
cd's and dvd's for some reason in this age isnt being able to play fully in older equipment do to the change in cd/dvd formats which makes you go out and buy new equipment it happened to me not just 2 weeks ago bought a new dvd and found out it wouldnt play in my year old dvd deck had to go out and buy new dvd deck then disk and all my others played fine
May 11, 2008 | LG LH-D6230 System
Too many Cables??
Firstly, let me address audio cables. Optical audio is the same (essentially) as a coaxial digital audio cable, just in a different form. Since you just purchased a Bluray player, you'll see an HDMI out on the rear. This is a high definition video and audio cable rolled into one (however it looks like your receiver does not support this). I would recommend running an HDMI cable from the Bluray player right to the TV, then run an optical audio cable (or coaxial digital) from the TV to the receiver. This will give you the best picture on your TV, and the best available sound through your receiver.
Depending on your DVD player and Bluray player, you might want to consider using just the Bluray player for DVD's and Bluray discs. If your plasma supports 1080p (or really anything better than 480i), you would most likely get a better picture out of DVD's since the Bluray player will upconvert the video to the better signal (of course this depends on your exact model of Bluray player). This will help to eliminate some cabling also.
Other than that, you're not going to eliminate much more cabling. If you really want to get tricky with it, pick up some split loom wire management and wrap them up with that. Be sure to run the power and signal wires separately though! Best of luck, and hope this has helped.
Dec 20, 2007 | Home Theater Systems
AVR 1508 Reciever Setup Issue
AVR 1508 doesn't upconvert. Only components coming in on HDMI will go out HDMI.
Nov 28, 2007 | Home Theater Systems
HS-R430 System
Connect the audio cable (red & white) from DVD player to the Audio DVD in (L/R) of the receiver.
Change the source selector to DVD.
Incase of coaxial o/p from the player, connect it to the coaxial i/p of the receiver. Then select the digital i/p button twice located in the front of the receiver.
Nov 19, 2007 | Onkyo HT-S680 System
How do I connect the receiver and television together
Try to connect AUDIO OUT from your TV to AUDIO IN to your receiver.
Oct 05, 2007 | RCA RT2600 System
RCA RTD255 System Logo
60 people viewed this question
Top RCA Home Theater Systems Experts
Ismael Lopez
Level 1 Expert
Are you a RCA Home Theater System Expert? Answer questions, earn points and help others
