Question about Samsung LN-S4692D 46 in. LCD HDTV
How do you turn on pip - Samsung LN-S4692D 46 in. LCD HDTV
  • Kenneth Klare
    Kenneth Klare May 11, 2010
    I thought I had PIP on my Samsung LED DLP HL-T5687, similar remote. But I also cannot find it now. I know that when I had it I could not use with 2 HD sources. You need one to be an antenna or other and the second can be any, IIRC. The fancier model 5689, I know, can do 2 HDMI sources.
    See same comment in Amazon reviews.
    Surprise, when looking for it found that I do not need 7 presses to go from HDMI2 to HDMI1 using source but can get there in less with HDMI button--that will save a few seconds and some overshoots.
    -Ken
  • 42 Answers
When using PIP on a Samsung TV, the main source you are viewing needs to be Component, HDMI or the PC Source before PIP can be used to view for example a digital cahnnels.
Posted on Jul 16, 2009
How do I do picture in picture
How to turn on PIP in Samsung TV SAMSUNG STEP 1. OPENING MENU SETTINGS
Click here to know about PIP in Samsung TV.
a). Press MENU key ( 20130724181903971_281z433j.jpg ) from TV remote.
b). Select Picture option and press ENTER key ( 20130724182110969_vyofsac0.jpg ) from TV remote.
c). Select PIP option and press ENTER key ( 20130724182110969_vyofsac0.jpg) from TV remote control.
20130724182409386_3o5go25e.jpg STEP 2. TURNING ON PIP SETTINGS
d). PIP window will open on TV screen. Select PIP and press ENTER key ( 20130724182948520_6zvcucfc.jpg ) from TV remote control.
e). Select On option and press ENTER key ( 20130724183213111_ln8iy22v.jpg ) from TV remote control.
f). Enjoy watching PIP screen.
Oct 19, 2014 | Samsung New 55"" Class 54.6"" Diag. Led...
Pip won't turn off. can the pip be removed or bypassed?
Some of the older sets with PIP require only the original remote to operate or turn on and off.
The PIP board usually develops problems with surface mounted caps and there is a "modification" where traces are cut and two 4.7 mfd caps inserted which will bypass the PIP board from the set--a model number would tell me if this is possible in your set or not--you missing the original remote? Almost any Mitsubishi remote of the era with PIP controls should do the job.
Dec 02, 2012 | Mitsubishi Televison & Video
I have a pip on my screen. Can't remove it
somw sets you need to set up in the set-up menu what signal source is shown in the pip box. to turn it off push the pip button on the remote once
Apr 26, 2010 | Sony KP-53XBR200 53" Rear Projection...
Black square on screen that covers half the picture appeared on my 42" sharp aquos tv.
sounds like you might have PIP turned one (picture in picture) .. if there is no input hooked up for the PIP . you will just get a black screen ... you should be able to move that PIP around and change its size .. indeed turn it off .. look for a menu item called PIP .. select PIP off ..
Nov 06, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a sony trinitron XBR 32 inch... The pip was turned on by accident, but i don't have the original remote. How do i turn off the PIP? Thanks in advance.
pls. use remot menu key and open main menu use DW key and select system menu see the PIP option is "ON" set option is"OFF" .
See the PIP screen is clear.
Oct 20, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Pip pictture doesn t turn off
I had the same problem many times, and I don't have the original remote. Go into your menu options and select Auto-Program. It will run through all your channels, but when it is done, PIP will be off !! I have PIP!
Jun 28, 2008 | Televison & Video
32 xbr vega trinitron PIP wont turn off
Just press any channel number and PIP will disappears :)
Dec 25, 2007 | Sony KV-36XBR400 36" TV
Turning off PIP on KP-61v45
have you try menu options if this does not work U need original remote
Dec 13, 2007 | Sony KP-53S35 53" Rear Projection...
PIP for Sony KV-27XBR45 television trouble shooting
If you have the original remote for this TV on the pip menu (left side slider on remote all the way up) there is a pip off button. If you unplug the unit long enough it should go back to normal. If you go into demo mode and then exit mode you will again be out of the pip. With out the original remote you cannot easily turn pip off.
Apr 13, 2007 | Sony KV-27XBR45 27" TV
I had this problem with a universal remote.I tried everything you can think of.Finally I got it.I hit the setup button on top of tv and the volue down button to start the demo.I dont know exactly how long it ran but after awhile I hit a button and screen was normal...Yeah
Mar 10, 2007 | Sony KP-61V45 61" Rear Projection...
Samsung LN-S4692D 46 in. LCD HDTV Logo
453 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
