Question about ASUS P5GD1-VM Motherboard
Cleaned fan and now computer shuts off >1 min
I decided to clean CPU fan after I did my son's. All went well until I turned it back on. Less than a minute it shut off so I tried over and over and each time it shut down quicker. I never took motherboard out and did mine the same as my son's, Any clues?
  • tinkertoo Nov 18, 2007
    Daniel,
    I tried cleaning it w/o taking it off but finally had to take it off to get all the dust. On CPU and bottom of fan there is a discolored silver circle on top. I can scrap it off with my nail. If it is silicon where would I go to find it?
    Tinkertoo
  • 41 Answers
Hi Tinkertoo,
I had a few question that I wanted to ask you:
Did you separate the CPU fan from the CPU to clean it?
If so you need then you will need to put on a new coat of silicon in between the CPU and the fan.
Reason being is because the silicon becomes uneven when you separate it from the CPU.
Let me know how I can assist you further!
-Daniel.
Posted on Nov 18, 2007
  • daniel dao
    daniel dao Nov 19, 2007
    There are many different types of silicon that you can buy. Many come in different shapes and sizes, Myself i prefer the stick on silicon which is just like the ones that come with brand new CPU's (which is a square shaped sticker of silicon.)
    I'm pretty sure you can get it at your local computer store like Fry's Electronics, Comp USA, Micro Center. Ask one of the employee's they will point you in the right direction.
    Best Buy, Circuity City, and other retailers that don't specialize in computer accessories wont carry it.
    I hope your able to find what you need and that everything works out!
    -Daniel
  • daniel dao
    P.S:
    That discolored silver stuff is the silicon.
    Make sure also that you wipe off all the silicon from the top of the CPU prior to slapping on the new layer.
    and clean your hands all the way through, you can get sick off that stuff.
    -Daniel.
Why is my cpu shutting off?
Could be heat, software or hardware, will it boot to monitor ? Try starting in safe mode with networking press F8 after pressing start button, possible bad driver or missing driver error
Jul 27, 2014 | E-Machines eMachines Desktop PC
Gateway m465e laptop will not turn on
When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Mar 13, 2013 | Gateway M465-E Notebook
Thinkpad A22m 2628-3SU laptop premature shutdown
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
May 18, 2012 | IBM ThinkPad A22m 2628 Notebook
Toshiba TP50G90, makes a loud popping sound then shuts off. red light flashes
it sounds like its over heating.clean all the fans ,put new artic paste on the cpu
Jan 25, 2018 | Toshiba TP50G90 50" Rear Projection...
When i have it plugged in it will turn on and work for 5 minutes or so and then it will turn off and same thing with when it's unplugged. what the problem?
It sounds like your CPU is overheating. You've not mentioned whether a laptop or desktop PC.
Desktop - disconnect everything, take it outside if not raining and clean out all the dust and rubbish you can, I ( VERY CAREFULLY) use a dry paint brush. Pay particular attention to the CPU fan and heat dispersal block. More or less in the middle of the mother board, try and clean out the metal vanes. Also clean around the PSU fan assembly. Check all cables are good and home. Re-assemble and try again.
If it keeps on, its probably best to talk to someone who knows a bit more, or, as above, remove the CPU fan assembly and heat dispersal plate, clean CPU but leave it in the mother board, also clean the heat dispersal plate, (The goo is heat dispersal grease to ensure good contact between CPU and plate) Replace the grease and re-assemble.
A tip is to connect the power supply just before putting the case cover back on, powering up and checking that the CPU fan is working OK.
You can get loads of tips and videos from You tube.
If a laptop, the clear out the dust in the vents on the side and underneath, if that doesn't work, it means dismantling your laptop to clean it out. Your still trying to achieve what I've described above.
Sep 03, 2011 | Computers & Internet
Samsung r40 shuts down after running for about 20 mins, was told cooling fan was not working so stripped down laptop cleaned fan (was full of dust) reasemmbled and ran all day yesterday, switched on this...
The CPU fan may be faulty and not spinning freely.
If you had removed the heatsink off the CPU did you place new thermal grease/paste on the CPU before installing the heatsink back on the CPU?
Jun 02, 2011 | Samsung R40-K009 R40-K00A R40-K00D"...
So I have a Emachine t2984 model... It was working perfectly till out of nowhere I heard two beeping sounds coming out the computer then CPU shut completely off. So I went to tried to turn it back on but...
you have done the right thing by cleaning the dust from your computers fans you should continue cleaning the dust from your computer as dust will cause static which can cause a computer lots of unforseen problems
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
test or replace all the leads that attach to your hard drive make sure the connections are secure including electrical extensions + IDE,SATA the ones that attach from your
((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps keep up the good work
Mar 28, 2011 | E-Machines Computers & Internet
I have a hp slimline 3100. the cpu fan runs fast everytime i open a program or play a cd. it speeds up the slows down. sometimes it runs really fast, then the computer shuts down. whats going on?
This is an indication of overheating within the PC. Open the PC case and clean all the air vents. Take the heatsink and fan off the CPU and give it them a good clean. Put the heatsink and fan back on to the CPU and start up the PC. check that the fan on the heatsink is running smoothly.
Also, make sure the vents on the power supply are clear and the fan on the power supply runs well.
If you go into the BIOS setup, you may be able to monitor the fan and the CPU temperature.
Mar 18, 2011 | Computers & Internet
When the fan over heats it just shut down unexpectidly is it best just to buy a new fan or is there a way to solve this?
As you use your laptop, the CPU gets warm and the fan kicks in. If the CPU gets too hot, it will shut down as you have found.
Usually, the ventilation slots near to the CPU and CPU fan get clogged with fluff and dust. You need to clear this out.
Disconnect all power sources, turn the laptop upside down and remove any plate/covers that are easy to access.
Carefully blow/clear out any dust and fluff you can see, also try blowing into the ventilator slots. With luck this should clean it out well enough to keep your laptop running.
If not, you're getting into a dimantle scenario, taking more or less the whole thing apart and will neet CPU heat dispersal grease to re-assemble when clean.
Aug 21, 2010 | Computers & Internet
Windows 7 will run for a while then shut down by itself. Then the computer will not post up. Shuts down as soon as the CPU fan kicks in. will come to life every 5 min by itself and shut down again in a few...
Take special notice of the link.
I might have suspected a software issue but as you mentioned no post after the shutdown I do suspect a thremal issue
Your fan speeds up and slows down in response to temperature inside the computer. More so the CPU.
I would suggest getting a can of compressed air made for computers
Take it outside, take of the side and blow all the gunk out of there, Really go to town around the fan (you might want to wear eye protection)
While you are in there just check that the CPU cooler itself is not loose
(NOTE YOUR COOLRER MAY BE DIFFERENT)
If it is it will have to be re-seated.
If it needs re-seating don't just take it off and put it back on as that might make things worse with your temperature problem they have to be cleaned and new thermal grease put on ($2-5)
DON'T remove the CPU just the fan/cooler assembly.
You must clean both the surfaces without scraping anything off. Use isopropynol alcohol and cotton bud sticks until both surfaces are clean, you can use your finger nail to scrape harder residue if you wish but nothing else.
DON'T pour the alcohol over the CPU
Now apply some new thermal grease (most computer shops have it)
Be careful about how much you put on
Here are
some basic instructions
Once you have re-assembled your cooler and re-connected it check everything is OK and power up the computer.
If everything went to plan you should now be back in business
Hope this gives you the information you need
Bob
Moderator
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through fixYa.
Thank you
Dec 07, 2009 | Intel Motherboard Atx S775 ...
ASUS P5GD1-VM Motherboard Logo
62 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
