Question about GE JGRP17 Gas Single Oven
The screen ready f7 and beeps every minute, What does it mean
  • 234 Answers
F7
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel
Posted on Jul 16, 2009
My stove is beeping and is flashing F7. What does this mean, it is a built in oven.
The F7 error code means that a function key on the touchpad is shorted or stuck, the F7 can be cleared by pushing the clear/off button,if the error code returns the touchpad would need to be replaced.
GENE
Sep 10, 2011 | GE Ovens
The General Electric under the counter oven is beeping and only stops when I push the Clear/Off button. Then it resumes beeping 1-2 minutes later. Also "F7" appears to the left of the time...
The F7 error code means that a key on the touchpad has shorted and the touchpad needs to be replaced... sometimes it's a electronic anaomily, since you have pushed Clear/off and the F7 returns it surly means that touchpad is bad.
GENE
Sep 09, 2011 | General Electric Ovens
My oven is beeping and the F1 code and F7 code are appearing on the screen
Hi
F1 indicates a fault on the electronic oven controller (the clock) & F7 means a function key is stuck.
Check all the keys on the keypad if the fault remains you probably need a new clock.
Dec 19, 2010 | Thermador SC302T Electric Double Oven
Kenmore wall oven digital screen is blinking F7? it has a digital button screen. i can clear it but it comes on again a minute later. no other buttons work?
Here is the list of f7 codes for this oven and what they mean and what needs to be checked and fixed
F7 Function key shorted Replace touch pad
F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC
F7 Lock motor relay watchdog circuit is active when it should be off Microprocessor checking the operation of the EDC lock, relay failed. Replace EDC.
Oct 19, 2010 | Kenmore Ovens
Oven beeps and shows F7.
These codes mean that the oven's electronic control has detected a condition it needs to check. When you see a code, follow these steps:
  • Press "Stop/Clear" to clear the display and stop the beeping.
  • Reprogram the oven.
  • If the code still displays, turn off the power to the oven at your breaker box and wait five minutes before turning it back on
thanks.
Sep 29, 2010 | GE JGRP17 Gas Single Oven
Beeping and F7 when cleaning
F7 stuck keypad
If code does not recur, problem is with the Key Panel.
Jan 07, 2009 | Jenn-Air JJW8230D Electric Double Oven
F7 error steady beeping
short inthe key pad, thinks a button is being preesed for an extended period of time youll need to replace the keypad/ electronic control
Nov 17, 2008 | GE JKP45 Electric Double Oven
GE JKP15 Electric Single Oven - Code F7
If possible i will need the letter that come next after the JKP15.
Aug 19, 2008 | GE JKP15 Electric Single Oven
F7 message with beeping
The F7 represents a shorted matrix or start key. To determine whether it's the key panel or control itself, disconnect the ribbon cable of the key panel that goes to the control and power the oven up. If the F7 does not come back, it's the key panel, if it comes back, it's the control..
Jun 09, 2006 | GE JKP15 Electric Single Oven
GE JGRP17 Gas Single Oven Logo
173 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
