Question about HP Compaq Presario V2000 Notebook
External wifi card
Is there a high powerd external wifi card that i can plug an aerial into that would fit a usb or any port in this model laptop.
802.11 b/g
Its a HP Compaq Presario V3000 Laptop Despite what the product thing says.
  • 112 Answers
Re: external wifi card
Go to and look at wireless networks if it is available they will have it. BPCS
Posted on Dec 06, 2007
0 characters
3 Points
My dad gave my son an elderly (2001) HP Pavilion xf145 notebook with windows xp. We can't figure out if we need to add a wifi card of some sort, if it can even connect to our wifi or what. It seems to...
You can use either external wifi modem and connect it to the notebook by ethernet cable or (better) use PCMCIA wifi card (second-hand e.g. from eBay?) or wifi usb modem connected direct to usb port. Just check if choosen wifi modem supports your OS WIN XP (and service pack - e.g. WIN XP SP3). In the Reference guide of the notebook is not specified USB version - it seems to be v. 1.0, so it is necessary to get an USB wifi modem compatible with USB 1.0 standard.
Nov 11, 2013 | HP Pavilion xf145 (F3413HR) PC Notebook
I have toshiba Tecra 9000 laptop, its USB ports and Keyboard EXTERNAL port is not working. please help me
It's a common problem with the Tecra 9000's - either one or both USB ports and sometimes the external KB port along with it. The 2 USB's and external KB port (and the TV out port next to it) are all located on the same daughterboard that plugs into the motherboard, and in your case, more than likely the connector on the motherboard is bad (gotten loose). There's no easy fix for this unless you've got an ultra-fine soldering tip, good soldering skills....
How about a workaround? A PC card (PCMCIA card) that gives you 2 or 4 high speed USB 2.0 ports - it'll stick out a little on the right hand side, but in return you'll have fast USB ports, and you can use a USB keyboard with the thing.
Sep 14, 2011 | Toshiba Tecra 9100 Notebook
I purchased a wifi card for my N610c but don't see where it's installed
You don't say which operating system you are using.
You don't say which brand, type, format and model of Wifi Card you bought.
If it is an internal card, this cannot be installed without total disassembly of the notebook and, even then, might not fit because the motherboard might not support it or even have a slot for it. This card also requires internal aerial wires. Such a device also needs channels and LCD Panel sockets for the card's aerial wires.
What you should do is go back to where you bought the card from and exchange it for either a PCMCIA or USB Wireles LAN card, which fit simply into the notebook via its PCMCIA or USB ports. After you install the software and restart the PC, your notebook will be able to connect to your wireless router.
If this answer helps you, please take the time to rate it. This helps answerers better understand the needs and the point of view of the asker and helps us explore the best ways to provide useful, high quality answers.
If you need further help, please feel free to post another question or add a comment to this question.
Thanks for using FixYa.
Aug 30, 2011 | HP Compaq Evo n610c Notebook
Trying to get a wifi for an old HP Pavilion lap top and they ask for the conplete model name. Where do I find it.
Bellow laptop there's a sticker with this data, but the easiest way to add WiFi connection is buying an USB WiFi adapter, but before check if you have USB ports, it doesn't, it should have a PCMCIA (also called PC Card) slot, then you could get a WiFi PCMCIA adapter compatible with you operating system.
Feb 12, 2011 | PC Laptops
I have just bought a second hand compaq nc 4010 i have read that i can make it wireless using a pcmcia wifi card how do i install it as i have no disc drive on the nc4010?thank you
pcmcia is a card slightly smaller than the antique floppy disc that usually fits in a slot on the side of your laptop your model does have this slot, but personally I would go for a usb hsdpa modem as this provides faster broadband internet.
good luck
Jul 28, 2010 | HP Compaq nc4010 Notebook
I am looking to fit a mini pci wireless card in to my toshiba p10-382 but cannot seem to find an aerial inside the compartment, is there one fitted to the unit or do i need to obtain one, thanks.
Mini PCI wireless cards are usually equipped with internal antennas, so you don't need to worry about it unless you have an external plug in the card itself where you can attach an external antenna.
Oct 29, 2009 | PC Laptops
I want to know and identify the parts of my laptop
On the right hand side starting from the front to the back, the ports are
1. (2) USB Ports
2. TV/Cable jack if applicable, some models don't have.
3. RJ-11 Modem Jack
4. Security cable Slot
5. Power Connector
On the Left side Starting from front to back. the ports are.
1. Express Card Slot
2. Digital Media Slot (below the Express Card)
3. 1394 (firewire) slot (some models don't have)
4. USB Port
5. E-Sata Port
6. HDMI Port
7. RJ-45 Ethernet Port
8. Expansion Port Type 3 (attaching docking station etc.)
9. External Monitor Port
Oct 10, 2009 | HP Pavilion dv6-1030us Notebook
How can the usb port 1.1 be upgraded to 2.0?
There might be man options :-
1. if your laptop has a PCMCIA slot you can buy a USB 2.0 PCMCIA adaptor.
2. You can purchase one USB 2.0 PC card ( from sites like ebay etc) with four ports. This lets you swap it around from laptop to laptop, depending upon which one might happen to need it at any given time (for backups to external HD, camera downloads, etc.). For most other purposes, like moving stuff to and from flash drives, it's really ok with the old 1.1 port. The only disadvantage of this solution is that the card is so large that it doesn't allow simultaneous use of a wifi card. The solution to this problem was to buy a USB-WiFi card. This was a bit steep, but we only needed one of them -- just for whichever PC happened to be using the USB 2 adapter.
Jun 30, 2009 | HP Pavilion ze4420us Notebook
Usb port
No differences, you can use any one of them.
Jan 19, 2009 | HP Compaq Presario v3000z Notebook
HP Compaq Presario V2000 Notebook Logo
79 people viewed this question
Top HP PC Laptops Experts
Brian Sullivan
Brian Sullivan
Michael Thomas
Michael Thomas
Are you a HP PC Laptop Expert? Answer questions, earn points and help others
